This thread is privately moderated by Herb, who may elect to delete unwanted replies.
Old Nov 26, 2010, 02:02 PM
jonnyspeed is offline
Find More Posts by jonnyspeed
jonnyspeed's Avatar
North Royalton, Ohio
Joined Jan 2002
Originally Posted by Steph280 View Post
They just dropped the price on this kit to $137 now! Time to pick up another one so I can have two damaged ones?
I wish I would have know they were gonna drop the price that far before I ordered mine a week ago. That is a stupid deal for $137 !! I agree it needs better packing, but mine arrived undamaged so I can't gripe.
jonnyspeed is offline Find More Posts by jonnyspeed
Old Nov 26, 2010, 02:21 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
... I can see why though : plane in stock, but no fan in stock, no retracts in stock, nobody's flown it a whole lot either - yet ...
Still seems like a good deal to me - we'll see who in the next round gets the returned crushed ones
Herb is offline Find More Posts by Herb
Old Nov 26, 2010, 02:39 PM
CryHavoc is offline
Find More Posts by CryHavoc
UAS Pilot - FAA# *******HRK
CryHavoc's Avatar
United States, TX, Copperas Cove
Joined Apr 2000
Buy a new one (or two) at this price, then return to damaged one for a refund at the original price. Of course, that's provided they arrive okay.
I guess I was lucky as your just around the corner and it was damaged but mine was fine down here in SD. Makes me wonder if it was damaged before it even made shore.
CryHavoc is offline Find More Posts by CryHavoc
Old Nov 26, 2010, 04:06 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
The Het 9305-700 90mm fan has finally arrived ...
http://www.highendrc.com/index_ecat.php?cPath=4_30
It seems to fit nicely in the T-45, the outer diameter of the fan is ca. 1mm larger than the WeMoTec Midifan, 93.3 mm vs. 92.2 mm.
The large hole pattern in the Het shroud fits the Het 700 motor cooling holes nicely ... the motor still needs to be supported at the back though.
The inner diameter of the plastic shroud is such that a number of different rotors fit, including the Midifan & CS one, and even the heavy Haoye (tightly).
On mine the back opening seems large enough to take motors up to ca. 39.98 mm diameter.
Old Nov 26, 2010, 04:12 PM
sherlockshah is offline
Find More Posts by sherlockshah
Joined Feb 2006
I bought one today too, and I have the same system
You mentioned early who will crash first, I usually break everything, THE f-86 went up in flames when the rotor came off that 90mm fan and sliced my xps 5s 4000 and caused a huge fire that could took down my house. MAKE sure you tighten the living day light out of that rotor so it does not come off!!! I paid 165 shipped. I will stay on this thread to get pointers. I am thinking this set up for it, het 90mm fan with 700-60-1480kv motor on 10s xps 3200mah with castle hv80, your thoughts? Oh and YES I will try to handlaunch if the weight to thrust is more than 1 to 1
sherlockshah is offline Find More Posts by sherlockshah
Old Nov 26, 2010, 04:14 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
The Het 93-05 700 fan is slightly heavier than the MidiFan but quite strong - ready for some major abuse
Old Nov 26, 2010, 04:18 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
The Het 700 90mm fan fits well in the T-45,
Old Nov 26, 2010, 10:06 PM
balistc1000 is offline
Find More Posts by balistc1000
balistc1000's Avatar
Chandler, AZ
Joined Nov 2008
Nice, I have the same set-up. So how are you going to support the back of the motor?
balistc1000 is offline Find More Posts by balistc1000
Old Nov 27, 2010, 03:43 AM
RO1 is offline
RO1
Find More Posts by RO1
RO1
Joined Nov 2010
Here another motivation to get your bird ready to fly , Herb
http://www.youtube.com/watch?v=K7l5J8cCvw4
RO1 is offline Find More Posts by RO1
Old Nov 27, 2010, 04:08 AM
RO1 is offline
RO1
RO1
Joined Nov 2010
Originally Posted by Herb View Post
I tested the length of the nosegear strut ... it came out a bit short, so ended up lengthening it by about 1 cm.
If the nosegear strut is too short, the T-45/Hawk will have a tendency to get glued to the ground on takeoff. A hard pull on the elevator in inexperienced hands can then result in a stall ...
It is better - or I should say, I prefer - to have the nosegear strut a bit longer than scale ... That way the Hawk will come off the ground more or less by itself.
When you look at the start sequence of my T45 you will see the relative negative angle of attack of the nose - due to the power I have in this Goshawk there is no problem with take off by its own lift . Since you also put a lot of watts in yours the front strut length will be secondary .
For those who put in a power level below a thrust to weight ratio , let`s say of around 0.7, however, it will become vital !
I did a little calculating of the wingloading on mine - she has 150g/dmsquare . According to your measurement being 24 dmsquare correlated to my max. weight you theoretically should still be flying with an AUW of 3600 g / 7.94 lbs
At your projected AUW you should be able to " hand-launch" your T 45
Rolf
Old Nov 27, 2010, 09:40 AM
Joined Feb 2006
I will handlaunch mine :)
I will have close to 10lbs of thrust!
Old Nov 27, 2010, 04:37 PM
pulsery2k1 is offline
Find More Posts by pulsery2k1
6 months to finish a rtf
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
I ordered one ( sale price too good) and read through the tread lot of great info:
To answer the question from back at post #19
the sign is to warn not to paint over the static port's for the instruments
they how ever left the decal for the port off
http://en.wikipedia.org/wiki/Pitot-static_system
Question I have the het 90mm 600 with the het 1600 watt motor
do you think on 6s the ducking would be strong enough
or would it need to be reinforced?
I could set it up (duct work ,fan) on the bench and test it
and if it works ok would it then be ok in model?
pulsery2k1 is offline Find More Posts by pulsery2k1
Old Nov 27, 2010, 10:33 PM
zaskarkid is offline
Find More Posts by zaskarkid
what it do everybody?
zaskarkid's Avatar
a swamp naturally
Joined Mar 2008
I wasn't sold by the low price alone. But after looking at the details in this blog I couldn't resist. nitro is sold out so hopefully we'll have some flight reports soon.
zaskarkid is offline Find More Posts by zaskarkid
Old Nov 27, 2010, 10:39 PM
chalmrast is offline
Find More Posts by chalmrast
Gilbert, AZ
chalmrast's Avatar
Gilbert, AZ
Joined May 2007
Alex at AK Models has 6 left!
http://ak-models.com/mm5/merchant.mv...Store_Code=AKM
Reputable vendor... bought many ARFS from him and have used his laser cutting service.....
chalmrast is offline Find More Posts by chalmrast
Old Nov 28, 2010, 08:46 AM
vanderbrander is offline
Find More Posts by vanderbrander
Just an Earth bound misfit - I
vanderbrander's Avatar
Canada, ON, New Tecumseth
Joined Nov 2010
Herb,
I just joined this thread. Thanks for all the great info.
I purchased the T-45 from Nitro Planes. They were having a Black Friday sale ($137 instead of regular $199). It was such a great deal I couldn't resist.
I have a wemotec 90mm fan, ARC 36-65-1 (2080kv) motor, 6S 4700mAH batteries and 120A ESC left over from my crashed F-86 foamie.
From the info on this tread it should be enough for a light set-up??
vanderbrander is offline Find More Posts by vanderbrander
Question CMPro T-45? gp125racer Nitro Planes 5 Dec 22, 2010 06:42 PM
Discussion Nitroplanes CMP 90MM T-45 Hawk FlyBoyTha1 Electric Ducted Fan Jet Talk 216 Nov 10, 2010 12:24 PM
Discussion Im In love with this T-45 Goshawk mikes68charger Electric Ducted Fan Jet Talk 3 Nov 06, 2010 12:23 PM
Cool New CMPro Composite T-45 90mm chalmrast Electric Ducted Fan Jet Talk 5 Nov 03, 2010 10:54 PM
Off Site Sapac T-45 Goshawk Composite TokageWeasel Aircraft - Electric - Jets (FS/W) 3 Oct 06, 2010 10:24 PM
