This thread is privately moderated by Herb, who may elect to delete unwanted replies.
Old Nov 23, 2010, 03:43 PM
balistc1000 is offline
Find More Posts by balistc1000
balistc1000's Avatar
Chandler, AZ
Joined Nov 2008
Chad, which retracts?
Wayne
balistc1000 is offline Find More Posts by balistc1000
Old Nov 23, 2010, 05:12 PM
Pied727-200 is offline
Find More Posts by Pied727-200
east coast
Joined Oct 2008
chalmrast
I have the one in the photo below, I was trying to find a
1900 kv motor , but could not - I found that one at electric
jet factory - it's for a HET 90 mm fan - would that fan and motor be a
good choice for this jet? or do you know where to get a 1900 kv
motor for the fan in photo?
sorry to ask , but I'm still new to edf's
thank you
Pied727-200 is offline Find More Posts by Pied727-200
Old Nov 23, 2010, 05:29 PM
Chandler, AZ
Joined Nov 2008
Get the new 9305v2 fan for 700 series motors. The new 700-68 motor in either the 1680kv or 2100kv, I'm sure Herb would know which would be better for 6s.
Old Nov 23, 2010, 05:32 PM
rvincent is offline
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
Well I just left Air Sally's house and he fixed up my ducts for me. So by the end of this weekend I hope to have a flight report and video
rvincent is offline Find More Posts by rvincent
Old Nov 23, 2010, 05:40 PM
Chandler, AZ
Joined Nov 2008
Stop holding out, show us some ducts! (second request)
Old Nov 23, 2010, 07:00 PM
rvincent is offline
rvincent's Avatar
Joined Jul 2004
Just for Wayne
Old Nov 23, 2010, 07:17 PM
chalmrast is offline
Find More Posts by chalmrast
Gilbert, AZ
chalmrast's Avatar
Gilbert, AZ
Joined May 2007
Originally Posted by Pied727-200 View Post
chalmrast
thank you
No problem... fairly new myself to EDF's.
As Wayne said, you can either get a new fan, or a new motor. The motor I would recommend is the Hyperion 3026-1900.
http://www.allerc.com/hyperion-hs302...or-p-4827.html
Looks like it may be cheaper to just by the HET fan but I still don't know if that motor is good for the HET fan on 6S. I know the Haoye 7 bladed fan will load up the 1600kV motor on 6S but that's not the greatest fan in terms of effeciency..
chalmrast is offline Find More Posts by chalmrast
Old Nov 23, 2010, 07:18 PM
Gilbert, AZ
chalmrast's Avatar
Gilbert, AZ
Joined May 2007
Bob, nice to briefly meet you on Saturday. Funny, I'll be in your neck of the woods this weekend. Where & when do you think the maiden will happen?
Chad
Old Nov 23, 2010, 07:47 PM
Gilbert, AZ
chalmrast's Avatar
Gilbert, AZ
Joined May 2007
Wayne
Wayne,
I'm taking a chance with the Freewing units as reviewed here:
http://www.rcgroups.com/forums/showp...5&postcount=46
For $63.00 plus shipping I figured the gamble was worth it. They come with trailing link struts but they will be too long. I'll have to modify them but at least it's something. No others come with struts except the EPF units. The problem with the EPF's though is that each mounting area will have to be hacked apart because the struts are offset to the retract body.
It's easy to do in foam but not so easy on this one!
I went ahead & printed out one of the photos to scale to see how they fit....
Old Nov 23, 2010, 09:09 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
the stock Ducts are made with ployester resin and what appears to be @5oz cloth with a different weave then im used to seeing .i added C/F tow rings to stiffen them up for the big Power Bob will use.there not the best shape but i think if guys Mod them like herb or i did they will work find for 6s 8s set ups
AIR SALLY is offline Find More Posts by AIR SALLY
Old Nov 23, 2010, 09:39 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
All good info ...
I ended up using a short aluminum tube for the interior rudder linkage ... I split it up with a scissor, slid it over the rudder actuator, and then crimped it back a bit.
Herb is offline Find More Posts by Herb
Old Nov 23, 2010, 09:43 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
At least the wing is done ... I added an airline connector so the wing can be removed easily.
Still waiting for the HET 700 motor from EJF ...
Old Nov 23, 2010, 09:49 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
I tested the length of the nosegear strut ... it came out a bit short, so ended up lengthening it by about 1 cm.
If the nosegear strut is too short, the T-45/Hawk will have a tendency to get glued to the ground on takeoff. A hard pull on the elevator in inexperienced hands can then result in a stall ...
It is better - or I should say, I prefer - to have the nosegear strut a bit longer than scale ... That way the Hawk will come off the ground more or less by itself.
Old Nov 23, 2010, 09:53 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Coiled Springair 1/8 steel struts maybe not for display, but for everyday grass field operations.
Old Nov 23, 2010, 10:01 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Question : to get a little more power would this be a good motor
Typhoon EDF-600-37 1600W motor for 90mm fans its for 5-6 cells
and 1600 watts , it the correct size and will bring the power
to what herb said, approx 1500 watts
Probably in the kv=1900 range if you are aiming for ca. 2000W max on 6S ... Maybe kv=1800 if you are aiming for a bit less .
The Het 9305v2 fan is NOT yet listed here:
http://www.s4a.ch/eflight/fancalc_e.htm
so you have to use the WeMoTec Midifan (90mm) fan as aguide, keeping in mind that the HET fan is a bit softer (less pitch) and will draw something like 10% less current ...
Maybe somebody else here has more exprience with the HET-9305-v2 vs. Midifan load comparison.
Question CMPro T-45? gp125racer Nitro Planes 5 Dec 22, 2010 07:42 PM
Discussion Nitroplanes CMP 90MM T-45 Hawk FlyBoyTha1 Electric Ducted Fan Jet Talk 216 Nov 10, 2010 01:24 PM
Discussion Im In love with this T-45 Goshawk mikes68charger Electric Ducted Fan Jet Talk 3 Nov 06, 2010 01:23 PM
Cool New CMPro Composite T-45 90mm chalmrast Electric Ducted Fan Jet Talk 5 Nov 03, 2010 11:54 PM
Off Site Sapac T-45 Goshawk Composite TokageWeasel Aircraft - Electric - Jets (FS/W) 3 Oct 06, 2010 11:24 PM
