This thread is privately moderated by Herb, who may elect to delete unwanted replies.
Old Jul 15, 2012, 08:51 PM
mongo ea6b is offline
Find More Posts by mongo ea6b
United States, FL, Orlando
Joined Dec 2010
Herb, I've been going thru pg 1-46 of the posts, and don't see any advice on the vortex generators. I was wondering if you recommend putting those on for problems with stall characteristics of the wing. I know it's only a rc airplane, but wondered if it might help out by having them on.
Your opinion, and any install tips? Shapes, easy designs?
Really appreciate all your input ove rthe building and updating of your 45, hope mine is going to fly as well as yours!
Thanks again!
Steve
mongo ea6b is offline Find More Posts by mongo ea6b
Old Jul 16, 2012, 03:33 AM
Boostoman is offline
Find More Posts by Boostoman
Boostoman's Avatar
Oman, Masqat
Joined Apr 2010
mongo, search "wing fence" you will get details of location and design
Boostoman is offline Find More Posts by Boostoman
Old Jul 16, 2012, 12:22 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Originally Posted by mongo ea6b View Post
... vortex generators. I was wondering if you recommend putting those on for problems with stall characteristics of the wing. I know it's only a rc airplane, but wondered if it might help out by having them on.
Your opinion, and any install tips? Shapes, easy designs? ...
Hi Steve, I would not try to fly a Hawk without wing fences, every half-decent kit (edf or turbine) has them too for good reason. Besides the CMP T-45 wing has no washout, whereas say the flyfly one has.
http://www.rcgroups.com/forums/showp...postcount=1007
I installed Hawk-style wing fences on mine, those T-45 style stubby VG generators are tiny and I doubt they do anything useful in a model - besides causing extra drag. But I could be wrong
So in view of the generally vicious stall characteristic of the CMP wing I would try to keep this particular T-45/Hawk LIGHT.
Herb is offline Find More Posts by Herb
Old Jul 17, 2012, 06:32 AM
Joined Dec 2010
Thanks for everyone's input, makes this much more enjoyable!
Old Jul 17, 2012, 09:08 AM
heychas is offline
Find More Posts by heychas
"My grandma wants to fly jets"
heychas's Avatar
Richmond, VA
Joined Feb 2008
Wikipedia also gives a nice overview of the function and purpose of wing fences that I found useful. After looking at the picture of the SU-22, it made me think about putting a second one on their since the hawk is so prone to tip stalls!
heychas is offline Find More Posts by heychas
Old Jul 17, 2012, 12:44 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
... the FlyFly Hawk has a nice wing twist (washout), that's how the CMP T-45 / Hawk's wing should have been designed There is zero washout in the CMP wing.
Old Jul 17, 2012, 11:27 PM
Boostoman's Avatar
Oman, Masqat
Joined Apr 2010
herb,
can you point our were is the wash out on the wing. I can only see the wing fences.
Old Jul 18, 2012, 02:16 AM
DeeCee 57 is offline
Find More Posts by DeeCee 57
Life's short - Enjoy!
DeeCee 57's Avatar
Zurich, Switzerland
Joined Nov 2009
Boostoman go get your glasses
And look at the trailing edge line vs the leading edge line... the washout is continuous, e.g. from the root to the tip.
Which typically makes the build of a wing more complicated, more expensive and therefore rare in models
DeeCee 57 is offline Find More Posts by DeeCee 57
Old Jul 18, 2012, 03:34 AM
clive45 is offline
Find More Posts by clive45
It should fly at least once
clive45's Avatar
Australia, NSW, Grenfell
Joined Mar 2006
You only need to pack the trailing edge up when laying the wing out and voila washout. Not rocket science and easy if the jig is set up for it, not much harder than a straight wing jig.
clive45 is offline Find More Posts by clive45
Old Jul 18, 2012, 07:07 AM
DeeCee 57's Avatar
Zurich, Switzerland
Joined Nov 2009
no rocket science for sure... but a bit more complicated still...
You could have a twisted spar(s), good luck with that!
Or the ribs have to be very carefully angled to the spar(s). Or most probably shaped to the washout Then the skin has to be worked on a 3 iso 2 dimensional pattern.
To make the matter slightly more challenging, most real A/C don't have a linear washout. Many a designer goes for the washout to be more pronounced behind the ailerons to alleviate tip stall, and less pronounced at the roots to provoke a warning buffeting in that area, though I guess this part does not apply to models (yet)
Probably explains why HK et al don't have it on theirs...
Old Jul 18, 2012, 12:58 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
They could have had washout in the wing ... it's not that hard, they just need to build the wing in a suitable mold, with ribs tied down with rubber bands until the glue sets.
I think they (CMP) maybe figured it would be nice in the Hawk but not necessary ? Most straight wing planes (ie warbirds) don't really need it.
Just a little bit of washout is needed in the Hawk, not much. I can see the difference in the slow flying characteristic between the FlyFly and the CMP Hawk, it really has an effect ! The FlyFly Hawk is rock solid at slow speed, the CMP one is ready to flip over. Washout is easier to do in an aluminum mold for foam.
Old Jul 18, 2012, 01:12 PM
heychas is offline
heychas's Avatar
Richmond, VA
Joined Feb 2008
Wouldn't flying around w/ a little bit of reflex in the ailerons also create washout? I know people w/ the Eflite hawk who have done that.
Old Jul 18, 2012, 01:23 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
... Yes that has a similar effect, "poor man's version" of washout
The wing airfoil isn't just as clean then ...
Old Jul 18, 2012, 03:47 PM
pulsery2k1 is online now
Find More Posts by pulsery2k1
6 months to finish a rtf
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
Herb
may I ask the RTF weight of your Fly Fly hawk and the set up
I'm Just finishing mine which I covered with tissue and finish
cure epoxy .
pulsery2k1 is online now Find More Posts by pulsery2k1
Old Jul 18, 2012, 04:47 PM
heychas is offline
heychas's Avatar
Richmond, VA
Joined Feb 2008
Thanks Herb! I'll probably put in a little reflex... I'm hoping to maiden soon. I may hit you up w/ some questions about my LVC and my ESC. My Turnigy Superbrain 80A appears to have it low voltage cut-off during some bench testing I haven't had to a chance to trouble shoot due to my work schedule... I hate it when that gets in the way
Question CMPro T-45? gp125racer Nitro Planes 5 Dec 22, 2010 06:42 PM
Discussion Nitroplanes CMP 90MM T-45 Hawk FlyBoyTha1 Electric Ducted Fan Jet Talk 216 Nov 10, 2010 12:24 PM
Discussion Im In love with this T-45 Goshawk mikes68charger Electric Ducted Fan Jet Talk 3 Nov 06, 2010 12:23 PM
Cool New CMPro Composite T-45 90mm chalmrast Electric Ducted Fan Jet Talk 5 Nov 03, 2010 10:54 PM
Off Site Sapac T-45 Goshawk Composite TokageWeasel Aircraft - Electric - Jets (FS/W) 3 Oct 06, 2010 10:24 PM
