Espritmodel.com Heli Air
This thread is privately moderated by Herb, who may elect to delete unwanted replies.
Old Nov 21, 2010, 05:50 PM
Designer/Scratch Builder
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Nice work Herb!
Hysol is a VERY good epoxy.
Kevin Cox is offline Find More Posts by Kevin Cox
Old Nov 21, 2010, 06:13 PM
speedin n da weeds :)
sikky's Avatar
USA, AZ, Glendale
Joined Feb 2008
Originally Posted by Kevin Cox View Post
Nice work Herb!
The kind you don't find at the local hobby shop ???
sikky is offline Find More Posts by sikky
Old Nov 22, 2010, 01:45 PM
Rochester, New York
Joined Jan 2006
Guys, if this is not the place or time, just correct me, but..........
what makes that Dyn-E-Max sound so TURBO-like?????? Is it more
blades, less blades, little blades, big blades, straight blades, really
curved blades, WHAT IS IT??????? It's making me crazier than I
normally am!
Papajeff is offline Find More Posts by Papajeff
Old Nov 22, 2010, 01:51 PM
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
I don't think Herb will mind one or two posts about it but..... Yes it is the number of blades. Same with the Stumax fans
rvincent is offline Find More Posts by rvincent
Old Nov 22, 2010, 01:55 PM
Gilbert, AZ
chalmrast's Avatar
Gilbert, AZ
Joined May 2007
Can someone tell me what "k" carbon tow is best to order from CST for strengthening the ducts as Herb and Marvin did?
I have no experience with the stuff!
Thx,
Chad
chalmrast is offline Find More Posts by chalmrast
Old Nov 22, 2010, 02:16 PM
balistc1000's Avatar
Chandler, AZ
Joined Nov 2008
It looks like Herb used the 12k.
balistc1000 is offline Find More Posts by balistc1000
Old Nov 22, 2010, 02:24 PM
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
http://www.cstsales.com/
Qty Name Item # Each Subtotal
1 12k Carbon Fiber Tow, 25 ft. pkg. CF706 $4.95 $4.95
1 Unidirectional Carbon Fiber0.005" thick, 3.7 oz./sq. yd.1" Wide, Webbed Binder4 ft. pkg. CF373 $3.95 $3.95
1 Carbon Fiber Bias Woven Tapes1" Wide, 1-9 Ft.CFTB211 $1.90 $1.90
Subtotal $10.80
Tax Total $0.89
Grand Total $11.69
Payment type: Visa
Herb is offline Find More Posts by Herb
Latest blog entry: BAe Hawk 90mm EDF
Old Nov 22, 2010, 02:28 PM
Chandler, AZ
Joined Nov 2008
I've been waiting to order to see what you are going to do with the other carbon?
Old Nov 22, 2010, 04:15 PM
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Actually not much for now ... I felt silly ordering just $4 worth of stuff, so I added a few items I thought I could use in the near future.
Yesterday I glued in the elevators ... really no issues there either, everything fits nicely.
I would not ever use double sided tape for securing servos though
I used 30-min epoxy mixed with microballons (ca. 1:1 by vol), the microballons help getting better glue joints
since the foamy thicker slurry kinda fills all the gaps nicely. Nowadays I rarely use epoxy just by itself.
Old Nov 22, 2010, 04:25 PM
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
The rudder is next ... the hole in the rudder does not match the correct location, the 3.5 cms mentioned in the instructions.
If you use the pre-drilled hole, the actuator arm ends up almost touching the duct inside ... not good.
After drilling a new hole higher up in the rudder, I glued the actuator in, with epoxy and microbaloons + tape over the whole assembly.
Now everything fits nicely after installing the CA hinges.
Old Nov 22, 2010, 04:28 PM
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
The rudder linkage from the inside, everything seems easy so far.
The setup sofar is quite tight and slop-free. I added a small wood block to limit possible future play in the rudder actuator rod.
If you try to put a z-bend in the supplied rods, they will break !
Old Nov 22, 2010, 04:37 PM
rvincent's Avatar
Joined Jul 2004
I noticed mine was too long as well (rudder linkage). I am going to copy your wood block idea too But I will go one step further and add a block to te backside too. I didn't like that much linkage exposed and no support. Just hadn't thought of a way to deal with it. Good stuff! Thanks Herb!!
Old Nov 22, 2010, 09:17 PM
jonnyspeed's Avatar
North Royalton, Ohio
Joined Jan 2002
Looking good Herb. Did you scuff up the case of the servos before you siliconed them in?
jonnyspeed is offline Find More Posts by jonnyspeed
Old Nov 23, 2010, 11:01 AM
east coast
Joined Oct 2008
Hi I ordered and recived these 2 pilots
http://parkflyerplastics.com/cart/in...1ef12b3ec8f764
they fit perfect and only weight 5 grams each compared to 40
gram's from the CMP pilots , just need some painting ,
Question : to get a little more power would this be a good motor
Typhoon EDF-600-37 1600W motor for 90mm fans its for 5-6 cells
and 1600 watts , it the correct size and will bring the power
to what herb said, approx 1500 watts
thank you ,
Pied727-200 is offline Find More Posts by Pied727-200
Old Nov 23, 2010, 01:42 PM
Gilbert, AZ
chalmrast's Avatar
Gilbert, AZ
Joined May 2007
Pied,
It's hard to say because we don't know exactly what fan you have. If it is the changesun fan, that motor you just posted to the link to still has too low of a kV. You need 1900kV if you're going to run 6S.
Looks like assembly for me will start after Thanksgiving. I'll get the Carbon Tow ordered tonight and hopefully it will be here early next week. The retracts should be here by then too.
I have the motor/fan, the ESC, the servos, the linkages, the ParkZone pilots, and the wires all in hand.
Question CMPro T-45? gp125racer Nitro Planes 5 Dec 22, 2010 06:42 PM
Discussion Nitroplanes CMP 90MM T-45 Hawk FlyBoyTha1 Electric Ducted Fan Jet Talk 216 Nov 10, 2010 12:24 PM
Discussion Im In love with this T-45 Goshawk mikes68charger Electric Ducted Fan Jet Talk 3 Nov 06, 2010 12:23 PM
Cool New CMPro Composite T-45 90mm chalmrast Electric Ducted Fan Jet Talk 5 Nov 03, 2010 10:54 PM
Off Site Sapac T-45 Goshawk Composite TokageWeasel Aircraft - Electric - Jets (FS/W) 3 Oct 06, 2010 10:24 PM
