Old Jan 10, 2011, 04:22 PM
Big Weed is offline
Find More Posts by Big Weed
What was I looking for??
Big Weed's Avatar
Harrisville Utah
Joined Nov 2007
Ok, but is the offset up or down
Big Weed is offline Find More Posts by Big Weed
Old Jan 10, 2011, 04:31 PM
J_Arner is offline
Find More Posts by J_Arner
Limbo with 30,000V...
J_Arner's Avatar
United States, UT, Roy
Joined Apr 2008
you want them down I believe, because that is the direction you want more travel in.
J_Arner is offline Find More Posts by J_Arner
Old Jan 10, 2011, 04:52 PM
carlsoti is offline
Find More Posts by carlsoti
hass-alfed and bass-ackwards
carlsoti's Avatar
United States, AZ, Chandler
Joined Jun 2008
Originally Posted by flyingj View Post
Some have mentioned a mini blaster, but I don't think you can get them anywhere.
Overheard at Sunday's AZ DLG contest:
Steps for Mini-Blaster Assembly.
1. Buy Blaster.
2. Build Blaster.
3. Trim Blaster in Flight.
4. Crash Blaster spectacularly.
5. Collect broken Blaster pieces.
6. Cut Blaster wings.
7. Reassemble Blaster wings.
8....you get the idea.
carlsoti is offline Find More Posts by carlsoti
Old Jan 10, 2011, 05:19 PM
like.2.fly is offline
Find More Posts by like.2.fly
Mike M.
like.2.fly's Avatar
United States, UT, Eden
Joined Jan 2010
Hey Greg, did you ever see the writeup that Charlie Morris did on programming the DX7 for DLG? Great tips. Once you get your flap servo throw worked out then this will get your throttle stick set up to deploy the flaps proportionally (very good thing to do IMO) rather than just fixed positions like you have it on a switch. And also help set up your speed, cruise, and thermal flight modes on a switch. You also need to work out that issue where your ailerons turn off when flaps are deployed. Moving flap control to the throttle stick might help fix that too. This will give you much finer approach control which is very important. Look back at post #212 in this thread for the link.
like.2.fly is offline Find More Posts by like.2.fly
Old Jan 10, 2011, 05:39 PM
flyingj is offline
Find More Posts by flyingj
Jeremy D Stott
flyingj's Avatar
Ogden, Utah
Joined Nov 2004
... Now I see...
flyingj is offline Find More Posts by flyingj
Old Jan 10, 2011, 06:01 PM
Extremeace is offline
Find More Posts by Extremeace
Always Twirling for Freedom!
Extremeace's Avatar
Utah, planet earth
Joined Mar 2009
Howdy boys... So, what did I miss on Saturday?
Extremeace is offline Find More Posts by Extremeace
Old Jan 10, 2011, 06:06 PM
J_Arner is offline
J_Arner's Avatar
Joined Apr 2008
Check out the video... you missed the freeze fly and the "Rodeo".
Old Jan 10, 2011, 06:35 PM
Mike M.
like.2.fly's Avatar
Joined Jan 2010
How you feeling Ace?
Old Jan 10, 2011, 06:40 PM
Extremeace's Avatar
Utah, planet earth
Joined Mar 2009
I'm feeling OK... the pain is more annoying than it is bad. Adrian threw the Alula at the hill and I did 45min of ridge soaring yesterday (from sitting in the car ). Sure do miss spinning in circles. I'm really kicking myself about missing the freeze fly, how many people showed up? Did you guys get any tasks in?
Old Jan 10, 2011, 06:51 PM
Mike M.
like.2.fly's Avatar
Joined Jan 2010
We only had 4 guys show up, so flying & timing tasks wasn't very practical. We just had fun flying for a couple of hours until it got too cold. I did test out the sound system and it worked great. Next one will be a full blown contest with tasks, so get your launch help lined up...
Old Jan 10, 2011, 06:58 PM
Mike M.
like.2.fly's Avatar
Joined Jan 2010
Here's some good news to make you feel better...
I've been talking to Larry Romberger, the president of the Remote Possibilities RC club in St. George, the guys that put on the President's Day fly-in down there. I asked about giving us a time slot for an official DLG flight demo, and sent him some video clips. He's all for it and said that would be great. He gave us the 12:00 noon spot on Saturday. Prime time. So hopefully a few of you will be able to make it down for the fly-in. Bring your DLGs and fly the demo in front of all the power junkies. Maybe we could even throw together a little contest somewhere down there that weekend, and call it our February monthly. Don't want to take away from our spring break contest down there in March though...
Old Jan 10, 2011, 07:06 PM
gopherhunter is offline
Find More Posts by gopherhunter
excelling at mediocrity
gopherhunter's Avatar
Franktown, CO. USA
Joined Mar 2009
Originally Posted by Big Weed View Post
On the Vandal wing is there any special setting on the servos, I cant seem to get very
much flap, about (23deg) with a diamond D47 set at center . when I push them much past the 23deg they grunt and groan and don't sound very happy.
when the servo is at center move a tooth or 2 down or up or down????
any help there, or do I just center them and install and go with what I get?
Thanks in advance.
Greg, First, reliably center your D47s, the flaps should be matching at 15 to 20 degrees down when you install the servos. If the yoke and servo arm don't match up, remove the servo arm and replace it to more or less match the position of the yoke when the flaps are down 15-20. You probably can't get it perfect because the wipers are fixed in the shafts. I don't know how many degrees down the flaps are set at when the Vandal wipers are glued in. Just make sure they match at servos centered.
This will give you lots of flap and a little reflex that you can mix with the ailerons.
Hope this helps.
John
PS- That's me and ShawnC in the background of your profile picture.
gopherhunter is offline Find More Posts by gopherhunter
Old Jan 10, 2011, 07:16 PM
Extremeace's Avatar
Utah, planet earth
Joined Mar 2009
Hmmm... Does that mean it'll be in the next 6 weeks while I can't put weight on my leg?
Old Jan 10, 2011, 07:23 PM
Extremeace's Avatar
Utah, planet earth
Joined Mar 2009
SWEET! Adrian and I already have my parents condo booked for that weekend! Damn right we'll be there! Also, we may be able to accomidate a couple of folks for sleeping quarters, if someone wants to stay in the condo. I'm not sure who is goin' yet, but time to start planning.
Old Jan 10, 2011, 07:37 PM
J_Arner is offline
J_Arner's Avatar
Joined Apr 2008
Aren't you still going to be laid up? I may be interested in one of those slots for sleeping accommodations.
Discussion Colorado DLG Happenings... djensen Hand Launch 10369 Today 10:53 AM
Discussion DLG event at "Soar Utah"? like.2.fly Intermountain Silent Flyers 4 Sep 09, 2010 11:58 PM
Poll DLG event at Soar Utah? like.2.fly Utah Flyers Organization 9 Aug 13, 2010 10:30 AM
Discussion DLG event at "Soar Utah"? like.2.fly Hand Launch 0 Aug 09, 2010 05:48 PM
Discussion Any Utah DLG fliers out there? seerspaz Hand Launch 12 Oct 09, 2009 11:41 AM
