| View Poll Results: Your preference for future Utah DLG 2-day regional contest schedules: | |||
| Have them all on Friday/Saturday |
12 | 36.36% |
| Have them all on Saturday/Sunday |
19 | 57.58% |
| Have Red Rock Friday/Saturday, and BSOUT Saturday/Sunday |
2 | 6.06% |
| Voters: 33. You may not vote on this poll | |||
| Thread Tools |
DX7 programming
Some guys in our group have Spektrum DX7 radios, and have had questions about programming them for DLG use. While most agree that this is not a great (full featured) DLG radio, it can be programmed to perform the basic necessary functions that will be sufficient to get you flying (same situation as the Airtronics RDS8000 that I currently fly with). I've been asked several times, but have never been able to help much with DX7 programming. If you are one of these then take a look at this post and links from Charlie Morris. He walks you through the process in good detail, including screen pics.
http://www.rcgroups.com/forums/showt...1#post16615073 |
Latest blog entry: Swith in battery chemistry for all my...
I've got both a DX7 and Futaba 9C and the DX7 is not the radio for a full house glider. I don't think there's enough mixes in the DX7 for 4 servo wing crow and different flight modes (camber adjustments). But most of the DLGs are just 2 servo wings aren't they? Should work out ok.
Plus both the 9C and 9303 (and their bigger brothers) have a lot of the different mixes already defaulted which makes programming a glider very easy. |
Latest blog entry: Testing..
http://www.hobbyking.com/hobbyking/s...idProduct=6310 I have had to remove the case for this last DLG, but I think you really need a 6ch receiver to get the mixing right. Do you still have a micro 1s receiver? I thought they had the micro servo connecors. |
I sold the micro to Cliff.
The micro connectors and a soldering iron work though if a guy wanted to use the 1S setup. Not alot of great servos for 1S operation though. |
I fly Assan in my DLGs same as Jim, but use the 6 channel long antenna which has worked great. The fiberglass pod on yours though might work with a shorter antenna version, but there is also CF routed on the sides of the pod.
1s might not be enough torque for those DLGs. If you run 1s you should use a 5v booster, but I'm finding that the best and simplest option is to take Dymond D47 or D60 that are 2s compatible and run a Rhino 360 or any other 2s with similar mah. |
I did alright with my 7202H (JR's 72mhz DX7, heli version) until I got a good deal on a EVO. Dave Jensen set me up with an appropriate momentary switch, which I tied to the gear channel, and mixed to elevator as necessary. The thing I missed most was independant flight mode trims. While I finally figured out how to adjust trims on the flap screen while flying, it wasn't exactly easy. Before getting the EVO, I didn't know any better, and it worked fine. I still have my blaster on the 7202, and wouldn't hesitate to use it for casual flying, or as a last chance back-up in a contest situation; otherwise, I'm spoiled by the newer radio.
It was added after the fact. I took out the two-way switch on the shoulder, and replaced it with the momentary switch. I swapped around the leads of some other switches, so that I could hook the gear switch to the momentary, them mix the gear function to elevator, for a launch rotation.
Nate,
You should try some of these wings on your TS1 since your wings are warped: http://www.rcgroups.com/forums/showthread.php?t=1343422 Another option would be to write Topsky and asked them for a deal on a replacement set. J |
| Thread Tools | |
| Discussion Colorado DLG Happenings... | djensen | Hand Launch | 5578 | Yesterday 06:19 PM |
| Discussion DLG event at "Soar Utah"? | like.2.fly | Intermountain Silent Flyers | 4 | Sep 09, 2010 11:58 PM |
| Poll DLG event at Soar Utah? | like.2.fly | Utah Flyers Organization | 9 | Aug 13, 2010 10:30 AM |
| Discussion DLG event at "Soar Utah"? | like.2.fly | Hand Launch | 0 | Aug 09, 2010 05:48 PM |
| Discussion Any Utah DLG fliers out there? | seerspaz | Hand Launch | 12 | Oct 09, 2009 11:41 AM |
