Old Feb 03, 2011, 01:41 PM
J_Arner is offline
Find More Posts by J_Arner
Limbo with 30,000V...
J_Arner's Avatar
United States, UT, Roy
Joined Apr 2008
There is such a slow discharge of the battery when used like this that it should not need to be balanced. Like the others have said, just charge through the switch jack or main power lead.
How much weight do you need? Any battery you put in will need to be charged at some point during a full day of competition.
J_Arner is offline Find More Posts by J_Arner
Old Feb 03, 2011, 01:46 PM
thecirque is offline
Find More Posts by thecirque
thecirque's Avatar
Cottonwood Heights
Joined Jul 2005
I purchased 3-4 Rhino 360mah lipo packs from Hobby-King for less than $5 each. They are EXACTLY the same size as those RCBUILDER.com lipos I've seen some guys using. I bet the source is the same.
I love the lipo stuff. But I bought a charger long ago for the other crap I'm flying.
I like to see how much charge goes back in after a day of flying. Helps me know health condition of a battery.
thecirque is offline Find More Posts by thecirque
Old Feb 03, 2011, 02:04 PM
J_Arner is offline
J_Arner's Avatar
Joined Apr 2008
Looks like it might be time to do another group buy on switchjacks. How many of you would be interested in something like this?
Old Feb 03, 2011, 02:25 PM
like.2.fly is offline
Find More Posts by like.2.fly
Mike M.
like.2.fly's Avatar
United States, UT, Eden
Joined Jan 2010
Originally Posted by thecirque View Post
I purchased 3-4 Rhino 360mah lipo packs from Hobby-King for less than $5 each...
I'm using those same exact Rhino 360's as well.
The ZIPPY Flightmax 350mAh 2S 20C is also similar, for only $2.87 from HK.
Dang, I just ordered some a couple weeks ago...
like.2.fly is offline Find More Posts by like.2.fly
Old Feb 03, 2011, 02:42 PM
Extremeace is offline
Find More Posts by Extremeace
Always Twirling for Freedom!
Extremeace's Avatar
Utah, planet earth
Joined Mar 2009
Hmm... I dunno. We're using 4 AAA 100 mhA Nicd batteries in the longshots, and they last FOREVER.. Bet they'd be good for a full day! Also, was I correct? You CAN NOT charge thru the switchjack with anything other than a Lipo charger (normal cheapy JR TX/RX charger won't work)?
Extremeace is offline Find More Posts by Extremeace
Old Feb 03, 2011, 02:55 PM
J_Arner is offline
J_Arner's Avatar
Joined Apr 2008
are they really 100mAh or 1000mAH or 1100mAH? Those are not typical DLG batteries, are they? If you need the weight up front then sure, that's all good.
Correct, you need to supply the correct voltage. Do you have a lipo charger that doesn't have to have the balance leads to charge with?
Old Feb 03, 2011, 03:00 PM
extremewing is offline
Find More Posts by extremewing
A different attitude to RC
extremewing's Avatar
Draper, Utah
Joined Sep 2008
Alex, I said you cannot use a normal NiCd charger through the switch jack or otherwise. You must only use a LiPo type charger to avoid over charging the pack. I also said that periodically you may need to check the balance of the cells but it seems like that will be a small problem or not needed...
We will need to find you a battery that has maximum capacity for the size and weight available including the lead weight...
extremewing is offline Find More Posts by extremewing
Old Feb 03, 2011, 03:04 PM
Extremeace's Avatar
Utah, planet earth
Joined Mar 2009
They're 1000mAH (boy I've been mixing up all sorts of letters), We bought them from Walgreens, just normal AAA rechargables, then we solder them into a 4 pack. I think a 3 pack would fit into the nose of the Vandal. Seriously, we don't even top them off before flying. We just fly on them for a few days, then charge them when they're dead, and they take a WHILE to kill.
Is there a HUGE advantage, other than the need of topping off a charge, for LiPo? Seems LiPo's advantage is they give more endurance for weight. I just don't see a reason not to use Nimh, other than it's not as new of tech.
I'm sure AD has a charger that'll work, I'm just thinking of convenience.
JONBOYLEMON is offline
Find More Posts by JONBOYLEMON
Full disclosure, not sponsored
JONBOYLEMON's Avatar
United States, UT, American Fork
Joined May 2002
I could use 2 of them.
JONBOYLEMON is offline Find More Posts by JONBOYLEMON
Old Feb 03, 2011, 04:17 PM
Mike M.
like.2.fly's Avatar
Joined Jan 2010
...Is there a HUGE advantage, other than the need of topping off a charge, for LiPo?...
LiPo's are just lighter. But if you need the nose weight then it makes sense to go to something heavier with more capacity. NiMH or LiPo, it doesn't matter. I would actually prefer the NiMH chemistry if everything else was equal. But I do like the way LiPo holds a charge over time.
Old Feb 03, 2011, 04:38 PM
Big Weed is offline
Find More Posts by Big Weed
What was I looking for??
Big Weed's Avatar
Harrisville Utah
Joined Nov 2007
I will take 3 if we decide to do it.
Big Weed is offline Find More Posts by Big Weed
Old Feb 03, 2011, 04:54 PM
flyingj is offline
Find More Posts by flyingj
Jeremy D Stott
flyingj's Avatar
Ogden, Utah
Joined Nov 2004
I might be in on a switchjack order as well... Maybe?
flyingj is offline Find More Posts by flyingj
Old Feb 03, 2011, 08:20 PM
rollinsrus is offline
Find More Posts by rollinsrus
Joined May 2010
People fly DLG here?!
I moved to Logan from the Seattle area a few years ago. Maybe it's time to dust off my SGII?
BTW.... where can I guy get some 60psi foam around here?
-Michael
rollinsrus is offline Find More Posts by rollinsrus
Old Feb 03, 2011, 09:11 PM
J_Arner is offline
J_Arner's Avatar
Joined Apr 2008
-Michael
Welcome to the group Michael! Yes, we fly DLG but it's a recent undertaking for most of us. Dust off the SGII and join us for the Red Rock F3K Challenge next month in St. George (March 19th-20th).
Not sure where you'd pick up 60psi foam.
-Jim
Old Feb 03, 2011, 09:16 PM
thecirque's Avatar
Cottonwood Heights
Joined Jul 2005
Wanna sell your SG II? ;0).
Discussion Colorado DLG Happenings... djensen Hand Launch 10423 Jul 22, 2016 06:17 PM
Discussion DLG event at "Soar Utah"? like.2.fly Intermountain Silent Flyers 4 Sep 09, 2010 11:58 PM
Poll DLG event at Soar Utah? like.2.fly Utah Flyers Organization 9 Aug 13, 2010 10:30 AM
Discussion DLG event at "Soar Utah"? like.2.fly Hand Launch 0 Aug 09, 2010 05:48 PM
Discussion Any Utah DLG fliers out there? seerspaz Hand Launch 12 Oct 09, 2009 11:41 AM
