Old Dec 16, 2010, 10:50 PM
rishalkant is offline
Find More Posts by rishalkant
Joined Nov 2010
Originally Posted by Harrow View Post
I use blue loctite so that I can get parts open again. Red loctite is very hard to get undone. If I need to undo red loctite, I use my soldering iron to heat up the part. Can you press a soldering iron on the end of the screw?
hi
ended up tearing up the plastic blade grip on both side and using a plier to twist it out
it was tought but came out
and yes feathering shaft was bent
thanks
rishalkant is offline Find More Posts by rishalkant
Old Dec 16, 2010, 10:58 PM
Joined Nov 2010
hi
i need help with my gyro
its a hk401 gyro and it keeps on spinning
i also reversed the gyro but still spinning issue
Trex 450 clone hk 450 need help (0 min 57 sec)
Hk 450 trex 450 clone first build and hover hk401 gyro (1 min 42 sec)
let me know
thanks
Old Dec 16, 2010, 11:03 PM
rocketscience is offline
Find More Posts by rocketscience
Not a six pack
rocketscience's Avatar
USA, IL, Chicago
Joined Jul 2008
Originally Posted by rishalkant View Post
hi
let me know
thanks
If you tried reversing the gyro it looks like you are not in HH mode.
If you hold the tail by hand (0 throttle!) and move it to the right does the leading edge of the top tail blade point to the left? It should.
rocketscience is offline Find More Posts by rocketscience
Old Dec 16, 2010, 11:30 PM
Joined Nov 2010
its not on HH mode and i have no clues how to put it to HH mode
if I face from heli from back and move rudder right the tail moves right
let me know what should i do
thanks
Old Dec 16, 2010, 11:43 PM
Joined Nov 2010
after few research on HHmode
i never did settings for revo, mix 1 , 2
I have a dx6i
and on mix 1 i have
gyro aile
rate L + 100% R+ 100%
SW gyro TRIM act
before this used to off
also what should i put on mix 2
also on
swash mix is all 100percent
let me know
thanks
Old Dec 17, 2010, 12:24 AM
EatAtJoes is offline
Find More Posts by EatAtJoes
Yes I looped the MSR post 5388
EatAtJoes's Avatar
Joined Nov 2008
hi
http://www.youtube.com/watch?v=ILNrbn2o7kw
http://www.youtube.com/watch?v=RAwQavGZJJ4
let me know
thanks
Set the gain to below 50% so the gyro is in rate mode
Check and ensure that the servo is centered
move the stick left and right and ensure it travels changing the pitch on the blades
then increase the gyro to 75%
now with the tail facing you push the tail to the right
Check the blades have increased in pitch to compensate and push against the direction they are moving
now repeat but move tail to left
Things to check
Make sure gyro setting for gain is set to 0 on the gyro itself
Make sure that the travel doesnt bind the the servo at full travel, if it does adjust the second pot to ensure it doesnt bind
Ensure your servo arm is at 90 deg when you have it in rate mode
Let us know what you find, if you can show video of the pots, show video of moving the tail and show video of the pitch of the tail blades at that position
Alos one other thing to check is the direction of the blades rotation
please show that on video too
Elias
One important thing, make sure the gain wire is in the correct spot and not in the rudder channel, you can simply verify this by checking that when you change from HH mode to Rate mode that the LED will go out on the gyro
EatAtJoes is offline Find More Posts by EatAtJoes
Old Dec 17, 2010, 01:06 AM
whiskykid is offline
Find More Posts by whiskykid
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
turn off revo mix! dosn't work with a gyro! tells the gyro your giving it rudder when you throttle up!
whiskykid is offline Find More Posts by whiskykid
Old Dec 17, 2010, 01:51 AM
skyeblu is online now
Find More Posts by skyeblu
banging head on wall
skyeblu's Avatar
Joined Feb 2010
+1 turn off revo mix! and make sure belt is twisted the right direction if slider is moving right for blade pitch direction had my belt belt running wrong and tail didnt work and scratched my head a coulpe of hours before the light came on
skyeblu is online now Find More Posts by skyeblu
Old Dec 17, 2010, 05:56 AM
bymannan is offline
Find More Posts by bymannan
Joined Aug 2010
Just got my HK450GT, very cool!
I have a few questions:
1. The head feels a bit stiff, is that normal or should I oil it a bit? The align manual does not say anything about oiling the head.
2. Do you automatically disassemble everything and loctite or just the screws that are easy to open? I noticed that some screws have loctite on them and they are hard to open. The ones that don't are quite easy to open.
3. Do you open the fathering shaft to loctite it?
Thanks! This is going to be so much fun!
bymannan is offline Find More Posts by bymannan
Old Dec 17, 2010, 06:32 AM
sandos is offline
Find More Posts by sandos
Sweden
Joined Jan 2010
I usually "try" every screw, if it seems to be hard to get out or tighten I usually leave them.
I would really recommend undoing the featchering shaft. You want to be sure that its good. I dont always re-loctite both screws if one of them is hard to get out, but I always try. My GT was loctitet pretty good.
sandos is offline Find More Posts by sandos
Old Dec 17, 2010, 07:15 AM
rikybob is online now
Find More Posts by rikybob
AMA # 949551
rikybob's Avatar
USA, FL, Orlando
Joined Oct 2009
Put some grease on the thrust bearings.....you will find they are as dry as a desert!
b
rikybob is online now Find More Posts by rikybob
Old Dec 17, 2010, 07:17 AM
AMA # 949551
rikybob's Avatar
USA, FL, Orlando
Joined Oct 2009
Originally Posted by EatAtJoes View Post
Being that the average age of RC Helicopter pilots is 45yo (which is what I am) I am amazed that the entire heli's are fluro colours.
I have to agree! I am starting to replace with bright!!!
I think after 35yo most of us tend to have issues working out which way the damn thing is facing at times.
+1!
heck once I flew black carbon fiber blades, black tail blades, black paddles, and dark blue canopy, i did a flip and my daughter said is it still upside down or is it the right way up.... she confused me for a second so I took the heli down lower so I could see it clearly.... after that flight I didnt use the all black setup ever again, then I went to fluro and thought I love this, used all white carbon main blades and havent looked back.
Elias
Best to ya!
b
Old Dec 17, 2010, 03:35 PM
Harrow is offline
Find More Posts by Harrow
Yes, I know it's upside down.
Sydney, Australia
Joined Dec 2008
I thought the tail pitch control lever showed the Tarot symbol on it, but OK it's a Tarot one, as far as the fluro orange tail stuff I get it from helidirect I get all my fluro stuff from them, helps with the eyes.
Elias,
I spent half the morning trying to find the flouro stuff on helidirect, but with no luck.
Is it any particular brand I should be looking for?
Harrow.
Harrow is offline Find More Posts by Harrow
Old Dec 17, 2010, 03:48 PM
bymannan is offline
Joined Aug 2010
Elias,
Harrow.
These are nice:
http://www.helidirect.com/tail-rotor...17_121_975.hdx
But I think you can find better prices on ebay.
Old Dec 17, 2010, 06:16 PM
EatAtJoes's Avatar
Joined Nov 2008
Elias,
Harrow.
really? maybe their search engine was down? just type in neon and you will get pages and pages of stuff
But here are some 450 size items in Orange (the brightest neon)
Stabilizers
Frame
Paddles
Tail Blades
Thats just a short list
Elias
Help! HK 450 or HK 600 kilo2018 Beginner Training Area (Heli-Electric) 29 Apr 19, 2016 03:56 AM
Discussion 450 HK with Futaba EX radio and 3114 FASST servos SLOPPY? PaulGT3 Mini Helis 9 Sep 02, 2013 05:10 PM
Sold HK 450 head/tail/frame/canopy/motor - $20 shipped RobDog Aircraft - Electric - Helis (FS/W) 5 Nov 09, 2010 10:07 AM
Discussion Vendo HK 450 com Radio HK 7canais baratoooo !!! nino_sdk Brazil 0 Jul 26, 2010 08:42 PM
For Sale hk 450, exi 450 or copterx 450 HeliStyle Aircraft - Electric - Helis (FS/W) 5 May 15, 2010 11:57 AM
