Latest blog entry: NH airshow
South London United Kingdom
Joined Jun 2003
Hi tsakali
+1 for Jombo I used to have the same problem. I was using a linear throttle curve, which means that opening the throttle to climb had to speed up the rotors as well as increasing pitch. This produces a peak of torque which the gyro cannot cope with. Since going to a flat throttle curve (70% to 80% depending on gearing) the problem has almost disappeared. Not gospel, but this thread has some good ideas http://www.rcgroups.com/forums/showthread.php?t=1651066 Cheers BL |
Joined Dec 2011
That bare piece of wire at the end is the actual antenna. You should be able to fix it by stripping an equal length from what is left. You have to remove both the plastic insulation and the RF shield leaving the core exposed. Best bet would be to strip a section a few mm longer and then clip the stripped part to match the one on the piece you cut off. Quote:
![]() The antenna on the FlySky receivers is not just the core wire sticking out of the coax, it is a BODA style like Hitec uses. And also like what they use in most of the transmitters. You might be able to just strip the end as you say but probably at a reduced performance compared to the stock antenna. |
Latest blog entry: er9x heli 450 heli set up (flybar)
. Just in the last 2 months i spent 2g in this hobby . last year ... well i just dont want to talk about it
Happy Flying !!! ![]() ![]() ![]() Bill S. EDIT: Hey Jombo, I like the new avatar !! Way Cool !! |
| Thread Tools | |
| Discussion 450 HK with Futaba EX radio and 3114 FASST servos SLOPPY? | PaulGT3 | Mini Helis | 8 | Nov 28, 2012 11:34 PM |
| Sold HK 450 head/tail/frame/canopy/motor - $20 shipped | RobDog | Aircraft - Electric - Helis (FS/W) | 5 | Nov 09, 2010 10:07 AM |
| Discussion Vendo HK 450 com Radio HK 7canais baratoooo !!! | nino_sdk | Brazil | 0 | Jul 26, 2010 08:42 PM |
| For Sale hk 450, exi 450 or copterx 450 | HeliStyle | Aircraft - Electric - Helis (FS/W) | 5 | May 15, 2010 11:57 AM |
| Help! HK 450 or HK 600 | kilo2018 | Beginner Training Area (Heli-Electric) | 21 | Feb 25, 2010 12:48 PM |
