![]() And finally that he should do a range check to make sure it all worked. First thing I said was that a new one was $9 |
Latest blog entry: er9x heli 450 heli set up (flybar)
There are some differences between signals at 60 hz and those at 2.4 ghz.
You could in theory use a waveguide for 60 hz , it would only be about 40 million times larger in the critical dimensions ![]() You can't just have the insulator of course, the signal is guided by the conductors. |
got a question, been flyin for a while , aint great but aint bad either.
What is the rotation of the tail rotor on a belt drive, flip it it and it reverses, best pull on the belt comes up to counter clockwise. At least that is what i see. but then the tail is torquing backwards. I just wanna know . |
The main blades spin clockwise and the tail blades spin up into the blades .
Latest blog entry: NH airshow
Joined Dec 2012
I think pmackenzie did a good job in laying out my options. Atleast 80% of the outer strands is making contact with its PCB plate, and the core cable is securely soldered to its relative spot. I then wrapped the bare PCB in electrical tape (sticky part on PCB) that should keep any loose outer strands from traveling and making contact with the main core.
Anyway, the fun part! It flue great today! A lot more responsive to my input and felt more comfortable those dead band settings really made the difference... Matter of fact it was a windy day, with gusts of 25 mph from what I could tell, and that kind of interrupted my ability to really test the waters. But even in the wind it was a blast, and now I'm much happier with it! my collective mix settings are still at 0 but I didn't notice any tail drift...maybe the windy conditions didn't make it clear to notice , or possibly because I didn't really push it around too much for it to glitch out. Thanx for all your help! Unfortunately, I messed up yet another set of tail gear (the ones that make contact with the main gear set) I have been flying on grass fields and I'm starting to think that I either need to raise my bird off the ground, or I'll have to look around harder for a cemented alternative. Spending 30 minutes making gear replacements every time I fly is not something I'm looking forward to...Especially without even crashing!....basically the simple act of landing can ruin my day. It's just about the worst thing that can happen, in terms of getting to the part . I have to remove the boom, disconnect the rear tail ball link, then remove the Gyro plate, and have to manage all the wires again as they all end up right over the tail boom holder. then removing the tail boom holder, and dealing with the often tough to take out gear bearings, etc... what a mess!. Where do you guys fly your birds? Any ideas for places to look for other than a proper RC field would be appreciated...closest RC field is about 40 min. away. |
South London United Kingdom
Joined Jun 2003
Hi tsakali
I fly from a field where they never seem to cut the grass. Haven't blown the tail gears yet, but I seem to spend ages untangling grass from the tail mechanism. My solution was to modify a 500 size u/c to fit. ![]() Also gives a slightly wider footprint for landing. Posted this picture before, opinions were mixed as to the aesthetics, but I like it. I haven't, but you could also fit a larger tailfin. Keeps everything out of the muck. Cheers BL |
Joined Dec 2012
Also, Border Lord that's def. an option. I'm not too concerned with aesthetics just yet, although that does matter to me
![]() also lol @ the " Kong-Fu black soldering batch" I will wear it proudly!...and prolly have to put it through another test when I start moding my 9x I sure hope they are not too serious with me needing a grounded soldering gun to work with :/
Joined Dec 2012
k one more question! (lies) I got to push the pitch/throttle a little more today (pitch pump?), and I noticed some rapid tail bounce (back and forth about 2-3 times )...is the mixing or the tail gain the culprit? I hope it's not my tail servo (Henge MD922 Digital) on Head Hold mode
| Thread Tools | |
| Discussion 450 HK with Futaba EX radio and 3114 FASST servos SLOPPY? | PaulGT3 | Mini Helis | 8 | Nov 28, 2012 11:34 PM |
| Sold HK 450 head/tail/frame/canopy/motor - $20 shipped | RobDog | Aircraft - Electric - Helis (FS/W) | 5 | Nov 09, 2010 10:07 AM |
| Discussion Vendo HK 450 com Radio HK 7canais baratoooo !!! | nino_sdk | Brazil | 0 | Jul 26, 2010 08:42 PM |
| For Sale hk 450, exi 450 or copterx 450 | HeliStyle | Aircraft - Electric - Helis (FS/W) | 5 | May 15, 2010 11:57 AM |
| Help! HK 450 or HK 600 | kilo2018 | Beginner Training Area (Heli-Electric) | 21 | Feb 25, 2010 12:48 PM |
