Old Feb 16, 2013, 06:42 AM
MikeHRC is offline
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Originally Posted by sp00fman View Post
I think your Receiver would feel pretty disconnected also without its antenna.
Youd be lucky to get any range at all. You really think the antenna is just for show?
Best thing to do is open up your receiver and solder on the part you cut off directly to the cirquit board.
Yeah - I meant to mention that, it's actually a specific length and shouldn't be changed
MikeHRC is offline Find More Posts by MikeHRC
Old Feb 16, 2013, 08:10 AM
tsakali is offline
Find More Posts by tsakali
Joined Dec 2012
Originally Posted by MikeHRC View Post
tsakali,
As well as dropping the dead-bands, what expo do you have - too much expo can make your heli un-responsive, as can too little headspeed.
Good luck,
all three are set to D/R 100 expo 20
tsakali is offline Find More Posts by tsakali
Old Feb 16, 2013, 08:14 AM
tsakali is offline
Joined Dec 2012
LOL I don't know what i was thinking when I cut that off. Really, I just rationalized from seeing other receivers with just small little stubs , that it would be ok to cut, sicne it looked oddly large in comparison to others.... can i just solder it back on to the end of the cut wire? getting into where my receiver is could be tricky.. I had to remove this 8 channel RX from its casing (came with the TH9X) wrapped it in electrical tape and squeeze it under the main gear space on a 45 degree angle...I was pretty nervous about doing that but I really didnt want anything on the outside of my frame
Old Feb 16, 2013, 08:20 AM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
No. It is not a simple wire. The part you cut off was the actual antenna, all that is left is the feeder wire which won't work by itself.
It is a coax cable with an inner conductor and outer metallic shield, separated by an insulator.
So there are two connections to be soldered. You will only be able to do that on the circuit board, and even then it will not be easy
Good news is that a new receiver is only ~$9
pmackenzie is offline Find More Posts by pmackenzie
Old Feb 16, 2013, 08:25 AM
tsakali is offline
Joined Dec 2012
but if I remove the little stub remaining on my RX and solder the cut part on there, wouldn't the shorter cable now be an issue? I guess what you're saying is that I better solder the cut off piece directly on the board instead of soldering it at the end of the small piece of wire that is left?
And if I had to buy a new receiver, do I also need to replace the transmitter? don't those things go hand in hand? are you saying that I should replace it with the exact same RX model?
Old Feb 16, 2013, 08:42 AM
pmackenzie's Avatar
Joined Dec 2002
The length of the coax is not important, the length of the part at the end is.
So if you can get both the inner and outer conductor re-soldered to the board without any short circuit it will work.
A new receiver can be bound to your module, no problems there.
It won't work out of the box, but binding is quite simple.
Pat MacKenzie
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
Is that a Turnigy 9X stock receiver antenna? Without it your range will be very bad. And if you lose the signal the heli could become unresponsive and fly away. The stock receiver does not have failsafe so it'll hold the last received value before it lost the signal. DO NOT FLY without the antenna! Re-attach it somehow. You'll probably have to open up the receiver and solder the antenna to the board. (You can usually find two spots on the board, one for the inner core of the coax cable and one the outer shield goes to)
WiseDuck is offline Find More Posts by WiseDuck
Old Feb 16, 2013, 08:51 AM
2Doggs is offline
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
Do the pitch pumps have to be in flight, or can i just do it on the ground or in a low hover? It's going to be difficult to tune that in if I have to go to a field as I don't have a portable programmer. Great info btw, I'm looking forward to having a much better session tomorrow
Best to fine-tune it in the field, in flight - but you could start off with a nominal value, 5 - 10 or so for collective pre-comp - the main thing being that you check the sense of the tail slider movement before you fly. The slider needs to move towards the tail boom with any movement of the collective or cyclic sticks away from neutral. I just set my cyclic pre-comp to 50% of the collective value - I'm not a good enough flyer to actually figure out the optimum setting.
2Doggs is offline Find More Posts by 2Doggs
tsakali is offline
Joined Dec 2012
k thank you!
Old Feb 16, 2013, 10:26 AM
tsakali is offline
Joined Dec 2012
k so I got to properly connect the antenna back on the board... I see what you meant by challenging , but I was able to do it! it seems to be working but i will do some long range checks when I'm at the field!
Old Feb 16, 2013, 10:45 AM
pmackenzie's Avatar
Joined Dec 2002
You will have to do a full range check.
The "Range test" button on the module only works to enter bind mode.
It does not reduce the output at all
Old Feb 16, 2013, 05:13 PM
sp00fman is offline
Find More Posts by sp00fman
Looptastic!
sp00fman's Avatar
Enschede, Netherlands
Joined Nov 2009
Good job!
You just earned you Kong-Fu black soldering batch!
I see a few relplies that might not be 100% accurate. The Rx wont necessarily keep giving the same output signal without failsafe option. The Turnigy Rx just stops its PWM output when signal is lost, making servos go limp and the ESC shut down power.
Soldering two coax cables together wont always make it work as well as it did if you dont fully recover the outer shielding. We are talking high frequency's here and a lot of signal strength could bleed out of the bad solder joint. These cables dont really act like conductors, more like a long string of small capacitors.
sp00fman is offline Find More Posts by sp00fman
Old Feb 16, 2013, 05:24 PM
ridge_racer is offline
Find More Posts by ridge_racer
United States, NY, New York
Joined Nov 2010
Be careful reconnecting and using a Turnigy rx with the antenna pulled out. First off, the ant is a co-axial shielded cable. The inner core wire that is insulated must not make contact with the shielded outer part. I have had this happen twice due to a bad crash (one in a delta wing plank and second in my heli) and both my attempts were not successful. I ended up with bad glitches from as close as 40 feet away. Considering how cheap the rx's are, I just buy new ones....
ridge_racer is offline Find More Posts by ridge_racer
Old Feb 16, 2013, 05:28 PM
Joined Nov 2010
Good job!
You are correct on this. I have crashed once because of a bad solder job on the HK/Turnigy rx ant lead. I had alot of random glitches that caused the ESC to momentarily go to 0% and the servos locked out/ no control momentarily. Lets just say the rx was quickly disposed off..
Old Feb 16, 2013, 05:33 PM
pmackenzie's Avatar
Joined Dec 2002
FWIW, I never told him to solder the cable back together for just that reason.
I told him to re-solder it to the board.
(It is more like a long string of capacitors and inductors. The actual signal travels in the insulator, the wires merely servo to guide it along the way. )
Help! HK 450 or HK 600 kilo2018 Beginner Training Area (Heli-Electric) 29 Apr 19, 2016 03:56 AM
Discussion 450 HK with Futaba EX radio and 3114 FASST servos SLOPPY? PaulGT3 Mini Helis 9 Sep 02, 2013 05:10 PM
Sold HK 450 head/tail/frame/canopy/motor - $20 shipped RobDog Aircraft - Electric - Helis (FS/W) 5 Nov 09, 2010 10:07 AM
Discussion Vendo HK 450 com Radio HK 7canais baratoooo !!! nino_sdk Brazil 0 Jul 26, 2010 08:42 PM
For Sale hk 450, exi 450 or copterx 450 HeliStyle Aircraft - Electric - Helis (FS/W) 5 May 15, 2010 11:57 AM
