Joined Dec 2012
Hi Velocity, I actually have a mini vise, so all I would need is the snap ring pliers. and if this is something that can happen over time and easily remedied by tightening it, it might just be better in the long run.
UPDATE: Also Border Lord, I tried what you suggested reset the screws, added some more grease in the bearing, and now the gears have only 20% of the original wobble! It's almost perfect now, the difference is embarrassing really :P. Not sure if it was just setting the hub right, or if it was that i could have over tightened the bold screw too tight in the first place, but taking it all apart and putting it back together def. helped! I guess this is a question for ridge_racer if he's not bored with me yet :P , I also have a 121T slanted main gear and a slanted 12T motor gear. I'd like to use them as it will supposedly allow the motor to run more efficiently. I used a HS calculator to figure out the resulting RPM, but the values I'm getting seem wrong...how should I translate your curve settings to this new gear setup? |
I received and build up my Tarot Pro FBL head on my HK450SE V2. Its the $15 black (non-DFC) one that passed along here some weeks ago on sale. I'm impressed by the quality and how smooth it went together. Its says "Tarot limited edition nitro pro" on the headbutton. Was Tarot really attempting a 450 sized nitro heli?
Once assembled i measured it up. Its a bit wider than the stock hub, 0.5cm each side. I run the Thrust-bearinged tarot pro tailgrips+hub, Hobbyking 335mm CF blades, and i still have 2mm of space between the mainblades and the square pro tailblades left if the mains would flex down. It SHOULD be enough right? I'll let you know how it goes
HS and gearing
With your 3800kv motor on 3s, 12/121 gearing is way too fierce - it would be trying to get up to HS4000, far too high. I know they do 10t helical pinions, and maybe even a 9t. With 10t onto the 121t slant gear, I'd expect you to see HS3200 or so, quite high, but within safe limits. For learning to fly, I'd suggest HS2600 - 2800 as giving a good balance between responsiveness and flight duration. There's an almost cubic relationship between HS and power - so doubling the HS increases required power by eight times, so unless you are an out and out stick banger, go for a moderate HS. The slant gears run a bit quieter, but they're not more efficient, since there's more sliding contact between the teeth. In fact I think you pay a small penalty in terms of flight duration for any given HS using the slant gears. |
South London United Kingdom
Joined Jun 2003
Hi SpOOfman
I am running an HK450V2 with a Pro head, and clearance between the main and tail blades is fine. Could it be that the thrust bearing tail hub is wider, and/or bigger tail blades? If you are unhappy about the clearance on yours, an Outrage G5 boom and belt are a drop in replacement, and will give you an extra 30mm of boom length. Should take it well into the 'safe' category. Worth a thought Cheers BL |
Joined Dec 2012
You might be able to get it to work with either one, and if you could find the right washer, maybe it would be easier with the 10x4x3. Otherwise it might just be a case of having the shaft fit just a bit shy of the end of the can if you use the 10x4x4, but I reckon that would be OK.
Happy Flying !!! ![]() ![]() ![]() Bill S. P.S. About 85-90 trouble free flights on my Tarot Pro FB 450. I've only replaced one see saw bearing that got sloppy. Finally confident enough to fly around others and the first time was with my new girlfriend. She had to ask, ever crash one of these ?? LOL Not sure if I dumb thumbed, probably did, but all the electrics still work and range test OK. The parts bill was not too bad, Tarot carbon blades, main shaft (feathering shaft is still straight replaced the bolts and checked the bearings though) main gear, main bearings, both front tail box gears, boom, TT, boom struts and landing skids and a minor chip on the canopy. It's all together again, blades tracked on a swivel stand I rigged up and ran wide open for 4 min and still in one piece with no vibes. I'm ready to hover test tomorrow and make any final trim adjustments.
Joined Dec 2012
Yeah, I can appreciate the pointy of stability. I'm not trying to slow it down, I just want the higher % setting on ESC that way it runs more efficiently, and in order to do that I think I need to lower the teeth so the faster spinning motor balances the head speed out to what it is now.
Oh FFS!
So I guess the postal service decided to play football with my package. The torque tube arrived severly bent. Couldn't Hobbyking pick a harder material for these?! These are SO easy to bend! Time to order some Align parts from a local store then. *sigh* At least I can use the bearing to reduce the vibrations on the one I have in my HK450.
I always use align TT I swear I had a copterx 500 one I could bend with my jeti mind!
Latest blog entry: Logo build
| Thread Tools | |
| Discussion 450 HK with Futaba EX radio and 3114 FASST servos SLOPPY? | PaulGT3 | Mini Helis | 8 | Nov 28, 2012 11:34 PM |
| Sold HK 450 head/tail/frame/canopy/motor - $20 shipped | RobDog | Aircraft - Electric - Helis (FS/W) | 5 | Nov 09, 2010 10:07 AM |
| Discussion Vendo HK 450 com Radio HK 7canais baratoooo !!! | nino_sdk | Brazil | 0 | Jul 26, 2010 08:42 PM |
| For Sale hk 450, exi 450 or copterx 450 | HeliStyle | Aircraft - Electric - Helis (FS/W) | 5 | May 15, 2010 11:57 AM |
| Help! HK 450 or HK 600 | kilo2018 | Beginner Training Area (Heli-Electric) | 21 | Feb 25, 2010 12:48 PM |
