Joined Jun 2008
Just do what i did, and change your belt to a TT .It usually takes a week from rc711 to the UK but Chinese new year is looming...
http://www.rc711.com/shop/alzrc-devi...th=166_216_354 |
South London United Kingdom
Joined Jun 2003
Hi Mike
You may well be right about the tail. I am going with the standard set up to start, and see. Easy to change if needed. Proportion is a subjective thing. Haven't flown the 400 yet, but did a quick spin up in the flat. Looking from above, all you see is rotor disc. That looked out of proportion to me, but I may well change once it is flying. What power set up did you use? Meanwhile AS That's the same picture they use at Infinity, and they list as a Tarot kit http://www.infinity-hobby.com/main/p...ff7579daaa288e Wonder whether STO make them for Tarot, or vice versa. That side frame looks like a Pro/SE hybrid. Single sides but with the servo mounts in the frame. Interesting. mhills No, hadn't seen the Alzrc kit, thanks for the link. Little pricey for me, looking to see what can be done on a budget. Thanks anyway. Wonder why they didn't include the rear part of the body. Might have made it more attractive for the money. Meanwhile, still looking for a 250mm flybar. Anyone help? Cheers BL |
What to do with ond gyro's
Sorry, the LH520 topic is to old to reply. Il will just dump my post here as some of you might have this Leadershobby gyro.
Have not used this gyro some time, all my birds have FBL controllers now..... so i put two LH520's on my little HK Parkjet ! Stripped of the cases the Gyro /rx unit weights in under 20 grams. Let her rip!!
Joined Dec 2012
hello fellow RC'ers!
so after what felt like months of reading and learning about helis and all the various components/electrical/ etc, I finally got all my parts in for a tarot build and I'm about 90% done with it. However I have a few questions that I'd like to get to the bottom of before I turn my maiden flight into only flight :P A concern of mine is the way the tail is acting... after my zyx -s setup, it seems that when I adjust the HH and rate settings with very minimal rudder input, the control link moves all the way to the ends. with not even half a stick worth of input... if I completely remove any HH and rate bias, then it acts normally with much better range of the rudder stick movement. How can fix this? the servo arm ball is set to 8mm distance. One more noob question. I have the 9X stock firmware, how do i set up my throttle as a stand alone input from one of my TX's knob controls? as it is right now, when I adjust the pitch the throttle also revs up...I can't seem to find any setting for that under the zyx setup program on the PC. In general I have no idea how to set up my 9X TX with all the necessary settings to be ready for flight, (idle up, I know throttle hold already) any instructions or links for noob setup for a 6 channel heli would be appreciated. |
Bench vs in the air
For learning to fly, you might set up special pitch and throttle curves that soften the pitch response and extend the hover time. If you don't have anyone near you to help you with your setup, make sure you ask lots of questions on this forum! Good luck! |
Joined Dec 2012
thank you for the quick reply! I live in in New Orleans, and from the looks of it, there are proly 4 of us all together in this hobby (atleast it feels that way :P ) And I don't know anyone who does any type of RC'ing so I am flying solo
...I will look around for pitch and throttle curve settings!
Joined Nov 2010
| Thread Tools | |
| Discussion 450 HK with Futaba EX radio and 3114 FASST servos SLOPPY? | PaulGT3 | Mini Helis | 8 | Nov 28, 2012 11:34 PM |
| Sold HK 450 head/tail/frame/canopy/motor - $20 shipped | RobDog | Aircraft - Electric - Helis (FS/W) | 5 | Nov 09, 2010 10:07 AM |
| Discussion Vendo HK 450 com Radio HK 7canais baratoooo !!! | nino_sdk | Brazil | 0 | Jul 26, 2010 08:42 PM |
| For Sale hk 450, exi 450 or copterx 450 | HeliStyle | Aircraft - Electric - Helis (FS/W) | 5 | May 15, 2010 11:57 AM |
| Help! HK 450 or HK 600 | kilo2018 | Beginner Training Area (Heli-Electric) | 21 | Feb 25, 2010 12:48 PM |
