Old Feb 06, 2013, 05:49 PM
tonyastro is offline
Find More Posts by tonyastro
3D VFX Artist
tonyastro's Avatar
USA, CA, Monrovia
Trying to help out a friend. What's a good tail servo to go with a CX-3X1000 and fits in an HK 450 Pro tail servo mount? Preferably local and under $30
tonyastro is offline Find More Posts by tonyastro
Old Feb 06, 2013, 09:17 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
If local, probably an Align DS525, but it's a bit more than $30 ($33 from Infinity Hobby). Probably worth the extra for the reliability.
beenflying is offline Find More Posts by beenflying
Old Feb 07, 2013, 02:34 AM
Atomic Skull is offline
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
Originally Posted by WiseDuck View Post
Alright, I didn't listen to some of the recommendations here and started with a clone.
Nothing wrong with a clone, it's just what clone. Tarot, ALZRC good, Hobbyking bad
I'll try again to straighten it further, but it's quite difficult to do it by hand. :P
You'll never be able to get that straight enough to not cause unacceptable vibrations. It will have to be replaced. On clone kits a belt drive causes less problems than a TT.
Atomic Skull is offline Find More Posts by Atomic Skull
Old Feb 07, 2013, 02:43 AM
Joined Dec 2011
Originally Posted by 2Doggs View Post
It's simple enough to set up your pitch curves to use only 10 degrees. If you intend to do any autos, however, I would set up the collective range in the gyro to -12 to +12, in which case 10 degrees of pitch would amount to a hair over 80% pitch.
If the gyro expects to have +/- 12 degrees of collective then it's best to do that and limit the pitch on the radio or it can theoretically cause problems with the gyro.
With 12 degrees of collective pitch range 10 degrees is 83% and 11 degrees is 92%
Old Feb 07, 2013, 03:21 AM
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
Yeah, unfortunately this is an HK450TT Pro V2. I've been looking at Tarot kits and the step up to Align from that isn't particularly large, we'll see what happens with this build. Again, haven't gotten far, I couldn't continue with the build after I applied some strong glue to keep the ball links in place. (Not enough thread on the other side of the servo arm to attach a nut, so I put some glue there instead)
I've googled the whole problem with bent TTs and noticed that even TTs from Align come slightly bent, but it isn't a problem most of the time. Unless it's severly bent.
I've got extra parts on the way, including another TT.
WiseDuck is offline Find More Posts by WiseDuck
Old Feb 07, 2013, 01:28 PM
GadgetMart is offline
Find More Posts by GadgetMart
United Kingdom, England, Manchester
Joined Jan 2013
I'm running 8-9 degees as a beginner, that's with a Tarot ZYX-S.
Still climbs like a homesick angel when I need too.
GadgetMart is offline Find More Posts by GadgetMart
Old Feb 07, 2013, 02:06 PM
Border Lord is online now
Find More Posts by Border Lord
South London United Kingdom
Joined Jun 2003
Hi All
Got a puzzle for all you budding Sherlock Holmes' out there.
Looking to build a stretched 450 to swing 360mm blades. I know Tarot do a conversion kit, but this is expensive, and for some reason they include a new set of frame sides (why?)
Anyway, with the collection of spares I have, I figure all I need are
Boom
Belt
Long flybar
Boom I have coming
http://www.oomodel.com/tarot-480-par...k-p-64623.html
Belt
Infinity have these
http://www.infinity-hobby.com/main/p...oducts_id=7001
but for a $1.99 item, they want $8.18 postage.
I will if I have to, but there must be somewhere cheaper.
Flybar
This one has me stumped. Apparently I need a 250mm bar as opposed to the standard 220mm.
Align used to do one, as do Tarot, but neither is available at the moment.
Anybody know of a 250mm x 2mm dia flybar from another model that I can use?
Borderlord.
P.S. Just checked with Infinity about post for two belts. For the privilege of sticking another belt in the same jiffy bag, they propose to charge me another $5.45 Hmmmmm
B
Border Lord is online now Find More Posts by Border Lord
Old Feb 07, 2013, 03:14 PM
Joined Jan 2013
I am using a Blade 450x tail servo on my HK450 GT with Tarot ZYX-S and it is superb.
EFLRDS76T
Very fast, and enough torque to get the job done.
They are also very light, I am using a 9mm arm. Pirouettes are very fast!
Old Feb 07, 2013, 04:46 PM
sp00fman is offline
Find More Posts by sp00fman
Looptastic!
sp00fman's Avatar
Enschede, Netherlands
Joined Nov 2009
Hey, that is amazingly fast. Still only 0,8kg torque. I will keep it in mind for my HK250, but i have burned out low torque servos on that tail before. Going to test with the TGY-306G first, to see if i finally ironed out all the gremlins on it.
my pirouettes are also really fast with a burned servo. Its not really a servo property, but more one of the heli and gyro capability.
sp00fman is offline Find More Posts by sp00fman
Old Feb 07, 2013, 05:09 PM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
Originally Posted by Border Lord View Post
Hi All
Boom
Belt
Long flybar
Boom I have coming
Belt
Infinity have these
Flybar
Borderlord.
B
Have you looked at this kit? http://www.rc711.com/shop/alzrc-devi...th=166_216_354
mhills51 is offline Find More Posts by mhills51
Old Feb 07, 2013, 08:56 PM
Joined Dec 2011
Hi All
You mean this?
I'm pretty sure STO makes that not Tarot.
Old Feb 07, 2013, 09:04 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
He didn't mean that. Tarot extends the back of the frame.
Old Feb 07, 2013, 10:01 PM
Joined Dec 2011
HeliProz has a sale on the Mini Titan E325 right now, $99.
http://www.heliproz.com/TT-Mini-Tita...ctinfo/101472/
Old Feb 08, 2013, 02:11 AM
clicky is offline
Find More Posts by clicky
UK
Joined May 2007
Wow! That thing with new FBL head is fantastic deal! Shame I already have two
clicky is offline Find More Posts by clicky
Old Feb 08, 2013, 02:39 AM
Joined Dec 2011
It's the flybar version. Also has plastic main and tail grips but these are Thunder Tiger and not cheap clone plastic.
Help! HK 450 or HK 600 kilo2018 Beginner Training Area (Heli-Electric) 29 Apr 19, 2016 03:56 AM
Discussion 450 HK with Futaba EX radio and 3114 FASST servos SLOPPY? PaulGT3 Mini Helis 9 Sep 02, 2013 05:10 PM
Sold HK 450 head/tail/frame/canopy/motor - $20 shipped RobDog Aircraft - Electric - Helis (FS/W) 5 Nov 09, 2010 10:07 AM
Discussion Vendo HK 450 com Radio HK 7canais baratoooo !!! nino_sdk Brazil 0 Jul 26, 2010 08:42 PM
For Sale hk 450, exi 450 or copterx 450 HeliStyle Aircraft - Electric - Helis (FS/W) 5 May 15, 2010 11:57 AM
