Old Jan 28, 2013, 07:29 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Originally Posted by psguardian View Post
Headspeed aside (can buy motor for desired HS), what pinion has the best mesh with the main gear?
~psguardian
Not exactly sure what you are asking, but in general you want more teeth to get a better mesh.
But given the size of the motor the typical pinions are bordering on too small to properly mesh. 15 tooth is the generally accepted minimum number of teeth for any pinion,
but usually a 450 will use 11 or 12 to properly match the torque of the motor to the load.
Changing the Kv will not change the torque capability of the motor, only the current that it will take to produce that torque.
pmackenzie is offline Find More Posts by pmackenzie
Old Jan 28, 2013, 07:43 PM
psguardian is offline
Find More Posts by psguardian
If I build it, it will fly
United States, NY, East Rochester
Joined Jan 2012
The teeth on a 15T pinion look soo much smaller than those of a 10T/11T pinion, it didn't seem like the higher pinions are a better fit at all.
I'm trying to find the pinion that best fills the space between teeth on the main gear. I know the motor mount has slide holes for fine adjustment, I just wanted to see which commonly avail pinion fits best.
~psguardian
psguardian is offline Find More Posts by psguardian
Old Jan 28, 2013, 09:27 PM
pmackenzie's Avatar
Joined Dec 2002
The teeth should be the same height from root to tip.
Are your sure your 15 tooth is the correct pitch? Should be 0.5 module
Here is a set of pinions from 11 to 13 for example, and the teeth are all pretty much the same
http://helidirect.com/rhino-gear-ste...0g5-p-6754.hdx
Old Jan 29, 2013, 04:05 AM
sp00fman is offline
Find More Posts by sp00fman
Looptastic!
sp00fman's Avatar
Enschede, Netherlands
Joined Nov 2009
you can get away with a bigger pinion if you run a governor on your ESC. I feel the 11T pinions wear out quickly. I got a set of steel 12T pinions and have not looked back since. I might get a 13T soon for a little more overhead on my governor power range.
linky
sp00fman is offline Find More Posts by sp00fman
Old Jan 29, 2013, 05:38 AM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Align playing catch up to Tarot. Thrust bearing 450 tail:
http://www.infinity-hobby.com/main/n...ewsdesk_id=961
beenflying is offline Find More Posts by beenflying
Old Jan 29, 2013, 08:18 AM
2Doggs is online now
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
What next? A split-lock Align DFC head?
2Doggs is online now Find More Posts by 2Doggs
Old Jan 29, 2013, 09:14 AM
skyeblu is offline
Find More Posts by skyeblu
banging head on wall
skyeblu's Avatar
Joined Feb 2010
~psguardian
Most all the pinions available for the 450 size motors all have the same pitch, the same number of teeth per inch? be it a 10 or 14 tooth if that is in your question. I have heard the slant gears mesh better and run smoother haven't treid them yet but have a set coming to try.
skyeblu is offline Find More Posts by skyeblu
Old Jan 29, 2013, 01:23 PM
Joined Jan 2012
Yes that was my question. Thank you for rewording it properly LoL. I must have gotten a 15t with a different pitch, the teeth were shorter than my 12/13t & it fit the shaft but had horrible mesh issues. The main gear teeth filled the pinion gaps, but the pinion teeth couldn't fill the main gear gaps.
So with that strait, my next question is: To obtain steady headspeed is it better to go higher kv + lower pinion or lower kv with higher pinion?
My own thought is that higher pinion will bog a motor down more on heavy pitch loads. Am I right?
~psguardian
Old Jan 29, 2013, 01:57 PM
skyeblu is offline
skyeblu's Avatar
Joined Feb 2010
Sounds like that pinion was machined badly. With the head speed it more depends on your helicopter setup, motor, and flying style. You can achieve the same head speed with different kv motors, If you are bogging going down one tooth is where I would start. the smaller the pinion the more torque and less top end speed. think of it as shifting down a gear if your car bogs it's easier to start off in first than second gear.
Old Jan 29, 2013, 02:17 PM
Joined Jan 2012
That sounds right. I have a turnigy 2836 3700kv, I want to set my next 450 up for normal flight & MAYBE light aerobatics.
~psguardian
Old Jan 29, 2013, 02:37 PM
Atomic Skull is offline
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
Originally Posted by beenflying View Post
Align playing catch up to Tarot. Trust bearing 450 tail:
Oh wow they literally cloned Tarot lol.
Atomic Skull is offline Find More Posts by Atomic Skull
Old Jan 29, 2013, 02:57 PM
Joined Jan 2012
I didn't even know they made a 20t pinion atomic skull, thanks LoL.
~psguardian
Old Jan 29, 2013, 03:01 PM
Joined Jan 2012
Unfortunately a 20t on my motor would cause a good solid meltdown @ over 125amp draw LoL.
~psguardian
Old Jan 30, 2013, 05:29 PM
Two helis flying
2Doggs's Avatar
Joined Nov 2009
I think if you need to run a 20t pinion on a 450 you're using the wrong battery pack!
Old Jan 31, 2013, 09:25 PM
jombo is offline
Find More Posts by jombo
Bad News Everyone
jombo's Avatar
United States, CT, Trumbull
Joined Dec 2007
Has anyone else noticed that with a higher headspeed these things are really stable
I went from a 4400kv motor to a 3800kv and what a difference . I am buying more of the 4400kv motors
jombo is offline Find More Posts by jombo
Help! HK 450 or HK 600 kilo2018 Beginner Training Area (Heli-Electric) 29 Apr 19, 2016 03:56 AM
Discussion 450 HK with Futaba EX radio and 3114 FASST servos SLOPPY? PaulGT3 Mini Helis 9 Sep 02, 2013 05:10 PM
Sold HK 450 head/tail/frame/canopy/motor - $20 shipped RobDog Aircraft - Electric - Helis (FS/W) 5 Nov 09, 2010 10:07 AM
Discussion Vendo HK 450 com Radio HK 7canais baratoooo !!! nino_sdk Brazil 0 Jul 26, 2010 08:42 PM
For Sale hk 450, exi 450 or copterx 450 HeliStyle Aircraft - Electric - Helis (FS/W) 5 May 15, 2010 11:57 AM
