Old Jan 21, 2013, 10:01 PM
shahram72 is offline
Find More Posts by shahram72
United States, SC, Irmo
Joined Sep 2011
Originally Posted by Black_heart View Post
I would be taking a look at your servos and How far out are the balls on the servo horns?
Yeah, for sure, but it should have been right from the factory. That's why I bought it, oh well. Another $100 down the drain. I really could have bought something nice that works by now. No more cheap RTF's for me. They are a waste of time.
shahram72 is offline Find More Posts by shahram72
Old Jan 22, 2013, 12:34 AM
Atomic Skull is offline
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
Originally Posted by gs550t1981 View Post
Damn servos just crapped out!!!! My hitec elevator servo just crapped out one me. The hs65mg. I am very low on cash these days. What servos are you guys running on a fbl setup that are cheapys but are pretty decent and will last. These hitecs have been through hell and back. Anyone know of a cheapo servo that will do the same. Remember. running it fbl. Thanks!!!!
Here's three price ranges.
http://www.hobbyking.com/hobbyking/s...11s_1_5kg.html
Ino-Labs are actually very good servos. You have to be logged in to see the real price on these. Helidirect has the gear sets, but they sell the servos for almost twice what HK sells them for. The metal gear version has more torque and less speed and so needs to be ran at 6v to be fast enough.
http://www.hobbyking.com/hobbyking/s...g_0_10sec.html
These are relabeled Henge MG933 servos and are said to be fairly good. The gear sets are available a few places (I can't recall where I saw them) They usually sell from US vendors for about twice what HK sells them for.
http://www.hobbyking.com/hobbyking/s..._0_10sec_.html
http://www.hobbyking.com/hobbyking/s...g_0_14sec.html
The Corona 929 / Corona 939 (same servo, different gear set) and their relabeled HK counterparts are the best of the ultra cheap servos and the only ones I would trust in a high vibration environment like a helicopter. (they have good wiring and soldering) They have some gear backlash, and the resolution is only decent compared to better servos. There are no replacement gears available (and the main output gear is press fit onto the pot shaft so you can't replace it anyway) so you just toss them and replace if they strip or when the gears wear too much. They are so cheap it would probably cost as much as a new servo just for the gear set anyway.
The tabs on the 929 and the 939 are brittle and you should take precautions to prevent them from cracking. In my old beater HK450GT (SEv2 clone) I epoxied some of these to the tabs to reenforce them.
http://www.hobbyking.com/hobbyking/s...ing_Parts.html
I glued them on to the servo tab between the frame and the tab with the raised cylindrical bit pointing into the screw hole (in the tab not the frame). The problem was that because of the raised bits on the top of the tabs they weren't flush with the frame so they would bend and eventually crack. By gluing this plastic piece to the tab it prevented this from happening.
Depending on how your servos are mounted you'll have to change which side of the tab you glue the plastic bit to.
Atomic Skull is offline Find More Posts by Atomic Skull
Old Jan 22, 2013, 07:22 AM
Black_heart is offline
Find More Posts by Black_heart
Texas NewB
Black_heart's Avatar
United States, MD, Princess Anne
Joined Dec 2011
I'f I remember I told you that you needed to take it apart and go threw that bird from the start.
RTF Realy only means it comes with every thing needed to fly!
Now your going to think you can get a perficly built Helicopter for less then $300 and not have to fix something?
If you wanted a true RTF that you dont have to fix to fly should have got a Blade 450.
I have gotten 2 RTF birds one I stell fly that is my Scale 450 and the other was my 500 I just sold Both where taken apart and reassembled Before I ever tried to fly them.
Both turned out to fly greate and i well buy another,
Black_heart is offline Find More Posts by Black_heart
Old Jan 22, 2013, 08:08 AM
jombo is offline
Find More Posts by jombo
Bad News Everyone
jombo's Avatar
United States, CT, Trumbull
Joined Dec 2007
What radio are you using? Like black heart said , their not RTF , more like RTCrash .
Post up a video of what it's doing and show us the radio settings , we an probably help.
jombo is offline Find More Posts by jombo
Old Jan 22, 2013, 09:23 AM
Joined Sep 2011
I went through the heli thoroughly beforehand. It should have flown. It did stable hover for a short time so something was right. The issue was control authority and I could not see that on the ground. There are dozens of people here and on you tube that fly these things out of the box as well as many more similar RTF's. I saw a vid the other day of some new guy flying a King 4 and that can't be an easy bird to fly. Mine is still in it's box (it was a gift). I see no reason to try to fly it. I have built a 450 from a kit before, that one does not fly either. Tail servo is very delayed in movement and tail will not hold connected to gyro.
Old Jan 22, 2013, 05:21 PM
dceng888 is offline
Find More Posts by dceng888
I can fly!
dceng888's Avatar
Australia, TAS, East Launceston
Joined Aug 2010
I would recommend to go back to the basics with the mechanical setup. Disconnect the motor and watch the movement of the head components to make sure all the travels are correct and no binding, a good drop if oil or a silicone spray won't hurt. I am also a noob and thought my setup was great but after a rebuild I found my pitch slider set wrong which threw out the pitch setting completely. My point is I picked this problem up by looking at the movement of the head components.
I also do a preflight check every time before I fly. That is move all control surfaces and make sure they respond in the right direction.
Also my heli would not get any tail authority until the head speed was up. Make sure the tail blades are spinning the right way.
Good luck, don't get degected when you get it running right it will all be worth it.
dceng888 is offline Find More Posts by dceng888
Old Jan 23, 2013, 02:52 AM
1101 is offline
Find More Posts by 1101
New Zealand, Auckland
Joined Dec 2008
miracle mart : excellent service
Hi guys.
I thought I'd give a heads up for Miracle Mart
Not only are their Tarot 450 Flybarless the cheapest price I could find anywhere, the heli arrived in NZ in 7 days on the cheapest shipping option !!!
I was nervous buying from them as cheapest sometimes could mean bad service.
But pleasantly surprised , well dome Miricle Mart.
If that was HobbyKing it would still be sitting in a warehouse somewhere after a week.
Of course now that this new heli arrived, my crappy old heli is getting more reliable.
2 full 5minute flights with no issues,a 1st ever
1101 is offline Find More Posts by 1101
Old Jan 23, 2013, 03:03 AM
ASTREA1 is offline
Find More Posts by ASTREA1
A&P in training
ASTREA1's Avatar
United States, CA, Vacaville
Joined Dec 2008
Originally Posted by 1101 View Post
Hi guys.
As is my case right now
I wish I would have known about that website before! They sure do have some very reasonable looking prices along with free shipping..May be going through them from now on..Thanks for the heads up!
ASTREA1 is offline Find More Posts by ASTREA1
Old Jan 24, 2013, 02:07 AM
Harrow is offline
Find More Posts by Harrow
Yes, I know it's upside down.
Sydney, Australia
Joined Dec 2008
Do you know any experienced heli pilots? I think you need to get someone experienced to check your set up, test fly it and tune it.
Harrow is offline Find More Posts by Harrow
Old Jan 24, 2013, 04:03 AM
Joined Sep 2011
Yeah there is one at our field, but he has way high end stuff. I think I met another rcgroups member nearby who has heli experience. I'll have to ask him.
Old Jan 24, 2013, 04:16 AM
2Doggs is online now
Find More Posts by 2Doggs
Ask Mike
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
You could post pictures here - since a picture is often worth a thousand words. It can be pretty disheartening being a lone hand and trying to learn helis, and armed with a humble clone, I can understand your reluctance to approach the local hotshot stick banger. Don't give up, and when you get it right, I'm sure you'll enjoy it!
2Doggs is online now Find More Posts by 2Doggs
Old Jan 24, 2013, 05:02 PM
R_Lefebvre is online now
Find More Posts by R_Lefebvre
Arducopter Developer
R_Lefebvre's Avatar
Joined Oct 2010
Originally Posted by Hellysmack View Post
In time you will find the wind a challenge.
The biggest trouble with wind and flying is coming in for a landing, up high you surf it but coming in slow 3 or 4 feet the wind could drop out from under it.
Back when I was concerned with wind I would strap on the training gear and practice hovering tail in, sideways and nose depending on how windy.
just keep it low, an if you have some kind of wind block helps too.
Must get that adrenaline rush / fix.
Wind no longer a problem with Arducopter. Winds were blowing 30-40 km/h
Arducopter 2.9 Testing (3 min 53 sec)
Well, just watch out for that tree!
R_Lefebvre is online now Find More Posts by R_Lefebvre
Old Jan 24, 2013, 06:18 PM
ASTREA1 is offline
A&P in training
ASTREA1's Avatar
Joined Dec 2008
Oh no! That scared me, wasn't expecting a greeting with the tree there!
Old Jan 24, 2013, 06:46 PM
R_Lefebvre's Avatar
Joined Oct 2010
Neither was I!
Mostly a bummer because I wrecked the Spinblades so I can't test them anymore.
I did get 4 flights in, and was not impressed. Basically zero increase in endurance. I still had to try lowering the head speed, but I was told they get some benefit, even at full speed.
Old Jan 24, 2013, 11:25 PM
jombo is offline
Bad News Everyone
jombo's Avatar
Joined Dec 2007
Very impressive !!! I hate when the trees just jump out at me too
Help! HK 450 or HK 600 kilo2018 Beginner Training Area (Heli-Electric) 27 Dec 24, 2015 06:02 PM
Discussion 450 HK with Futaba EX radio and 3114 FASST servos SLOPPY? PaulGT3 Mini Helis 9 Sep 02, 2013 06:10 PM
Sold HK 450 head/tail/frame/canopy/motor - $20 shipped RobDog Aircraft - Electric - Helis (FS/W) 5 Nov 09, 2010 11:07 AM
Discussion Vendo HK 450 com Radio HK 7canais baratoooo !!! nino_sdk Brazil 0 Jul 26, 2010 09:42 PM
For Sale hk 450, exi 450 or copterx 450 HeliStyle Aircraft - Electric - Helis (FS/W) 5 May 15, 2010 12:57 PM
