Old Jan 15, 2013, 04:35 AM
MikeHRC is offline
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Originally Posted by tonyastro View Post
I landed a little hard on my 450 Pro and stripped the TT gear. I was wondering if I could take the whole tail setup from my V2 belt and use it to convert my Pro. Will it fit? I'm not liking TT at all.
Tarot used to sell a kit to convert the Pro to belt
MikeHRC is offline Find More Posts by MikeHRC
Old Jan 15, 2013, 10:36 AM
shahram72 is offline
Find More Posts by shahram72
United States, SC, Irmo
Joined Sep 2011
I am also contemplating converting my 450FBL to belt when I get around to building it. But I did already get a 500 carbon fiber tail fin for it so that might be enough to keep it off the ground, but man that thing is huge!
shahram72 is offline Find More Posts by shahram72
Old Jan 15, 2013, 11:07 AM
Border Lord is offline
Find More Posts by Border Lord
South London United Kingdom
Joined Jun 2003
Hi shahram72
How about using a 500 undercarriage? I had a problem with grass getting tangled up in the tail mechanism, so I modified a 500 (Gooch, IIRC) u/c to lift the body further off the ground.
Quite pleased it doesn't look too out of place. I would think that plus your 500 tail fin would keep everything out of the kitty litter.
Just a thought
Borderlord
Border Lord is offline Find More Posts by Border Lord
Old Jan 15, 2013, 11:45 AM
Joined Jun 2003
Hi All
Looking for a pair of 450 SE (non-fbl) main blade grips. I need them in black, but all the shops I look at are either blue or titanium.
Any ideas?
Borderlord
Old Jan 15, 2013, 12:03 PM
Joined Sep 2011
Originally Posted by Border Lord View Post
Hi All
Any ideas?
Borderlord
Get plastic ones, they are quite strong. I have them on my cheaper kits. They hold two outer 3x8x4 bearings and one inner 3x6x2.5 bearing. You would need 4x8x4 and 4x6x2.5 bearings for the 4mm feathering shaft. Not sure how these would interface with the pro head block, if at all. There are spacers as well on the SE (V1) head. Check the SE manual for an exploded view.
Border Lord, I don't like how that looks, kills the low profile look. I suspect mt 500 tail won't look to nice either. I'm hoping mine looks like a Tarot or Align PRO FBL when it's built. The HK canopy is going straight in the trash. Yuck!
Old Jan 15, 2013, 12:29 PM
Joined Jun 2003
shahram72
Beauty is in the eye, etc. I quite like it, mainly because I don't have to spend hours untangling grass from the tail mechanism.
Plastic holders would do, but the rest of the head is metal and I need blade grips to match.
The search continues
Thanks anyway
Borderlord
Old Jan 15, 2013, 12:34 PM
R_Lefebvre is offline
Find More Posts by R_Lefebvre
R_Lefebvre's Avatar
Joined Oct 2010
Hey guys, thought you might like to see this. Arducopter on a Franken-450 flying a waypoint mission. She's a heavy beast carrying a fair amount of UAV equipment for such a small heli. The APM board which is mounted on a entire subframe I made, LED lighting, and a GPS and Magnetometer on a new mount where the gyro would normally sit. Plus the avionics are running off their own 2S 370mAh battery. The 3S 2200 only runs the motor.
Arductoper 2.9 Waypoint Demo (2 min 52 sec)
On the subject belt conversion, I converted my HK450Pro FBL to belt using this gearbox:
http://tarot-rc-heli.com/Tarot_RC_He...l-Box-Gear-Red
And this boom mount:
http://tarot-rc-heli.com/Tarot_RC_He...l-Transmission
I think that boom mount is intended for a TT, but I'm using it with a belt and it seems to work fine.
R_Lefebvre is offline Find More Posts by R_Lefebvre
Old Jan 15, 2013, 12:35 PM
Paul 1968 is offline
Find More Posts by Paul 1968
Mildly Confused
Paul 1968's Avatar
UK
Joined Oct 2008
BL, I don't know if it helps but I have a complete KEEP 450Pro fly bar head you can have for free. It feels quite tight but could me made to work if you want it.
Paul
Paul 1968 is offline Find More Posts by Paul 1968
Old Jan 15, 2013, 12:41 PM
Joined Jun 2003
Hi Paul
Thanks for the offer, would like to take you up on it.
For free doesn't sound fair, at least something for postage, or is there anything you need for a swap?
Borderlord
Old Jan 15, 2013, 01:06 PM
Mildly Confused
Paul 1968's Avatar
UK
Joined Oct 2008
Just trying to help a fellow modeller mate, PM me your address and I'll bung it in the post. Don't worry about postage it'll not be much mate.
Old Jan 15, 2013, 01:42 PM
tonyastro is offline
Find More Posts by tonyastro
3D VFX Artist
tonyastro's Avatar
USA, CA, Monrovia
I didn't know they sold just the TT front gears without the metal shaft: http://www.ebay.com/itm/2-Set-T-rex-...item2ec33302e4
Can you just remove the damaged gear from the shaft? Do you attach it with ca glue?
tonyastro is offline Find More Posts by tonyastro
Old Jan 15, 2013, 01:52 PM
Kam Arrow is online now
Find More Posts by Kam Arrow
Citizen #302
USA, OR, Canby
Joined Oct 2007
Put a spacer between the frame and the rear of the landing gear to lift the tail off the ground more.
No need for oversized gear, cheap(may need longer bolts), adjustable (thicker spacer = taller tail)
Bill
Kam Arrow is online now Find More Posts by Kam Arrow
Old Jan 15, 2013, 02:47 PM
Joined Sep 2011
Bill
Now THAT is a good idea!
Old Jan 16, 2013, 03:52 PM
3D VFX Artist
tonyastro's Avatar
USA, CA, Monrovia
Are the TT umbrella gears inside the boom mount exactly the same as the ones in the tail casing?
Old Jan 16, 2013, 08:03 PM
jombo is offline
Find More Posts by jombo
Bad News Everyone
jombo's Avatar
United States, CT, Trumbull
Joined Dec 2007
I think so .Its been a while since I tore one up
jombo is offline Find More Posts by jombo
Help! HK 450 or HK 600 kilo2018 Beginner Training Area (Heli-Electric) 29 Apr 19, 2016 03:56 AM
Discussion 450 HK with Futaba EX radio and 3114 FASST servos SLOPPY? PaulGT3 Mini Helis 9 Sep 02, 2013 05:10 PM
Sold HK 450 head/tail/frame/canopy/motor - $20 shipped RobDog Aircraft - Electric - Helis (FS/W) 5 Nov 09, 2010 10:07 AM
Discussion Vendo HK 450 com Radio HK 7canais baratoooo !!! nino_sdk Brazil 0 Jul 26, 2010 08:42 PM
For Sale hk 450, exi 450 or copterx 450 HeliStyle Aircraft - Electric - Helis (FS/W) 5 May 15, 2010 11:57 AM
