Old Dec 28, 2012, 08:15 AM
perdification is offline
Find More Posts by perdification
Joined Dec 2012
Originally Posted by pmackenzie View Post
Earlier you said that the weight of the blades would affect how much torque the tail would have to overcome.
That is only true for a few seconds while they are spinning up.
Once the head is up to speed the only forces resisting rotation are aerodynamic loads. They would be higher for the longer blades, but the weight of the blades would have no effect.
Pat MacKenzie
Ah! I see, thanks for the clarification.
perdification is offline Find More Posts by perdification
Old Dec 29, 2012, 01:53 AM
1101 is offline
Find More Posts by 1101
New Zealand, Auckland
Joined Dec 2008
DX6i & gyro: HH mode works, rate mode doesnt
Hi guys. I flew my newly rebuilt 450 heli today. In HeadHolding mode it flew nicely (no 3d: just beginner stuff)
In rate mode the tail just wanted to spin in 1 direction, needing full rudder on the radio to try & compensate.
Now I will fly it in HH mode, but would like to know why rate mode doesnt work.
DX6i, tarot GY550 gyro, henge MD922 servo
gyro settings on the radio are 67.5% (HH), 45.5% (rate)
I know that on the DX6i, below 50% is rate mode, so is 49% the max sensitivity
for rate mode or is max at 10% end of the scale ??
Cheers
1101 is offline Find More Posts by 1101
Old Dec 29, 2012, 01:59 AM
Paul 1968 is offline
Find More Posts by Paul 1968
Mildly Confused
Paul 1968's Avatar
UK
Joined Oct 2008
You need to set the tail up in rate mode so that the model maintains its heading. A good starting point would be approx 8 degrees of pitch on the tail to compensate for the direction of rotation of the head. With this done you will be able to toggle between rate mode and heading hold without drift. This can be done by moving the servo along the boom, unless it's a 450 pro with a fixed servo position, in which case you need to be adjusting the length of the control push rod.
HTH
Paul 1968 is offline Find More Posts by Paul 1968
Old Dec 29, 2012, 03:15 AM
Harrow is offline
Find More Posts by Harrow
Yes, I know it's upside down.
Sydney, Australia
Joined Dec 2008
Cheers
The 49% is the minimum RATE gain, with 0% being the maximum. Since you have 67.5% for HH, the equivalent gain for RATE would be 32.5%. I would increase the gain on RATE mode (ie. reduce the number below your current 45.5%), but this will not fix your problem. As just mentioned, you need to adjust the length of the tail control rod (or slide the tail gyro along the boom) to change the pitch of the tail blades until the heli stops spinning in RATE mode. It will take a few goes to get it right, and no need to get it exactly perfect.
Harrow is offline Find More Posts by Harrow
Old Dec 29, 2012, 07:15 AM
ridge_racer is offline
Find More Posts by ridge_racer
United States, NY, New York
Joined Nov 2010
I had a great experience yesterday flying with a set of VCTRC 3G blades on the Tarot 450 Pro FBL. They have matching CGs and only needed a little balance tape. They track very nice in flight. Cyclics and collective felt good and gyro performed flawless. Also with the black carbon fiber with white they are easy to see in the air.
ridge_racer is offline Find More Posts by ridge_racer
Old Dec 29, 2012, 01:13 PM
Black_heart is offline
Find More Posts by Black_heart
Texas NewB
Black_heart's Avatar
United States, MD, Princess Anne
Joined Dec 2011
Cheers
I thought 0 was the deviding point for rate and HH on Spectrom?
0-100 HH and 0-(-)100 rate
That is how i set my gy250 with my DX8
Black_heart is offline Find More Posts by Black_heart
Old Dec 29, 2012, 03:44 PM
1101 is offline
Joined Dec 2008
DX6i & DX8 have different setup/settings for gyro
Old Dec 29, 2012, 05:46 PM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
For anyone that's interested, I've done a mini review on the Hobbywing Skywalker 40A UBEC ESC here:
http://www.rcgroups.com/forums/showthread.php?t=1797769
beenflying is offline Find More Posts by beenflying
Old Dec 29, 2012, 06:31 PM
1101 is offline
Joined Dec 2008
just FYI guys...
be carefull with hobbywing esc's.
There are ALOT of fake hobbywing esc's out there, me & a friend have both been sold fakes in the past (unreliable and/or faulty )
Even Hobbywing know its a problem now, they have a serial no checking webpage to check for fakes , but Im sure the fakes will find a way around that as well.
so just be carerfull where you buy them
Old Dec 29, 2012, 10:50 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
It all depends on how you use the radio.
If you use the Gyro Sens function then you get the "0-50 and 50 -100" thing.
I always simply use the gear switch combined the the Travel adjusts, and you get -100 to 0 and 0 to 100.
Gyro sens has different settings for each flight mode, but with an Electric heli you only really need one flight mode anyway.
edit - looking at the DX8 manual, it is not clear which method they are using for the gyro function. DX6,DX7 and most JR radios had Gyro Sens, DX8 might be different.
pmackenzie is offline Find More Posts by pmackenzie
Old Dec 31, 2012, 11:27 PM
1101 is offline
Joined Dec 2008
Which HobbyKing 2200 Lipo ?
Hi guys.
Whats the better HK lipo, for reliablity/long life.
Nanotech, Turnigy or Zippy ??
Im still in beginner mode so 25c sould be more than enough
I was going to get another nanotech 25c. (I have 3), I also have 2 planes that I fly with the 2200's so would prefer to keep all my 2200's the same weight to keep things simple with CG's.
Some of my nanos (not just the 2200's) seem to have 1 cell that drops to a lower voltage than the other 2 cells after use. Is this just the norm with cheap lipo's ??
Cheers
Old Jan 01, 2013, 02:36 AM
Harrow is offline
Sydney, Australia
Joined Dec 2008
Hi guys.
You forgot to include 'Rhino' in the list, which happen to be the ones that I use. I'm doubting you'll get any consensus on this. Everyone seems to have their own favourites.
Old Jan 01, 2013, 04:12 AM
ahamay is offline
Find More Posts by ahamay
ahamay's Avatar
Australia, QLD, Gold Coast
Joined Jun 2012
Hi guys.
Cheers
I think you just need to get some of each and make up your own mind, that's what most people will do. Ultimately they are all very similar but it will come down to how you treat them as to how long they last. At 12 to 15 dollars a pop it's no big deal to experiment with a few sorts.
ahamay is offline Find More Posts by ahamay
Old Jan 01, 2013, 04:30 AM
Joined Nov 2010
Hi guys.
Cheers
I'm not a fan of the Nanotechs... Stick with the Zippy or Turnigy packs but get 35c packs..
Old Jan 01, 2013, 08:39 AM
sp00fman is offline
Find More Posts by sp00fman
Looptastic!
sp00fman's Avatar
Enschede, Netherlands
Joined Nov 2009
Worn Pulley
Look what's left of the front and rear belt pulley....
Now im wondering how to prevent it, apart from landing in long grass
I might just run the belt a little tighter next. I do treat the belt with silicone spray before installing.
http://static.rcgroups.net/forums/at...4-DSCN7585.jpg
http://static.rcgroups.net/forums/at...7-DSCN7584.jpg
sp00fman is offline Find More Posts by sp00fman
Help! HK 450 or HK 600 kilo2018 Beginner Training Area (Heli-Electric) 29 Apr 19, 2016 03:56 AM
Discussion 450 HK with Futaba EX radio and 3114 FASST servos SLOPPY? PaulGT3 Mini Helis 9 Sep 02, 2013 05:10 PM
Sold HK 450 head/tail/frame/canopy/motor - $20 shipped RobDog Aircraft - Electric - Helis (FS/W) 5 Nov 09, 2010 10:07 AM
Discussion Vendo HK 450 com Radio HK 7canais baratoooo !!! nino_sdk Brazil 0 Jul 26, 2010 08:42 PM
For Sale hk 450, exi 450 or copterx 450 HeliStyle Aircraft - Electric - Helis (FS/W) 5 May 15, 2010 11:57 AM
