Old Nov 18, 2012, 10:29 PM
Windows 8 PRO User
Australia, VIC, Coldstream
Joined Aug 2010
I don't buy those blades. I never have. I buy the pro 3D blades just like zaihan's video.
http://www.hobbyking.com/hobbyking/s...ade_205mm.html
spot on everytime for me. I recently bought the 205d (align) it's a little bit better not by much
join us in the hk250 forum to be upto date with the latest trends on your 250
http://www.rcgroups.com/forums/showthread.php?t=1120372
pitchp is offline Find More Posts by pitchp
Latest blog entry: ...
Old Nov 18, 2012, 11:23 PM
Windows 8 PRO User
Joined Aug 2010
New TT Drive Gear Coming Soon!
ALIGN New Torque Tube Drive Gear Coming soon! (7 min 7 sec)
thank god for align
Old Nov 18, 2012, 11:39 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
http://www.youtube.com/watch?v=KZtdM...ayer_embedded#!
thank god for align
Thanks, pitchp. Great to see, but I felt sorry for those tail blades.
beenflying is online now Find More Posts by beenflying
Old Nov 19, 2012, 01:17 AM
If I build it, it will fly
United States, OR, Portland
Joined Jan 2012
That was a great tail... not a 450 though. Any word on full line release or 500 soon & others to be announced?
~psguardian
psguardian is offline Find More Posts by psguardian
Old Nov 19, 2012, 03:27 AM
dceng888's Avatar
Australia, TAS, East Launceston
Joined Aug 2010
Hi team thanks for the advise regarding the blades. I will change them over to the stock blades tonight.
I put another pack through my her today. Fiddled with the gyro gain to get the tail to stop wagging. Also had to put in a lot of trim in rate mode to stop the drift. Is this the right way to fix the drift or should I do some mechanical adjustment.
dceng888 is offline Find More Posts by dceng888
Old Nov 19, 2012, 04:03 AM
Yes, I know it's upside down.
Sydney, Australia
Joined Dec 2008
You should not use trim to stop rate mode from drifting. If you do this, then when you switch to heading hold, it will see the trim as a rudder input and will start to rotate the heli.
The correct way to do it is to set the rudder trim to zero, and then mechanically adjust the length of the tail control rod to get minimal drift in rate mode.
Harrow is offline Find More Posts by Harrow
Old Nov 19, 2012, 05:15 AM
dceng888's Avatar
Joined Aug 2010
Thanks Harrow, I have made some adjustment to the push rod, will try it out tomorrow.
I did notice my radio (hitec optic 6) has separate trim adjustments for rate and hh mode.
Old Nov 19, 2012, 01:51 PM
United States, NY, New York
Joined Nov 2010
thank god for align
Would be great if they could do the same for the 450 Pro...Might have a crash proof tail setup...well less the boom and tail blades...
ridge_racer is offline Find More Posts by ridge_racer
Old Nov 19, 2012, 02:09 PM
just gotta mess with it!
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
thank god for align
I hear they're also coming out with carbide tipped tail blades, so your heli can do double duty as a table saw.....
2Doggs is offline Find More Posts by 2Doggs
Old Nov 19, 2012, 04:40 PM
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Originally Posted by 2doggs View Post
i hear they're also coming out with carbide tipped tail blades, so your heli can do double duty as a table saw..... :d
Hehe, good one!
Old Nov 19, 2012, 04:41 PM
Windows 8 PRO User
Joined Aug 2010
thank god for align
Old Nov 20, 2012, 08:19 PM
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
So seeing that video on these new super durable tail gears makes me wonder if the Align 450 Sport belt drive gear (front vertical one) noted for being fragile? I had one to strip doing front flips and I was completely unaware of excess wear on it. I did purchased the heli used but no excess play was noticed and I had not crashed it or stuffed the tail.
While browsing I noticed that just the nylon gears are sold as replacements which makes me think that they must be problematic. Pulling the tail drive gear / boom block is not a big deal and replacing the assembly or refreshing it with a replacement gear is not a big deal but I have never had to replace one on my Blade 400 which I had had for 4 years and it has been crashed numerious times.
Charles
Old Nov 21, 2012, 11:21 AM
Joined Aug 2011
Is there such a thing as a FBL and flybarred swashplate or is there no difference?
kidlat is offline Find More Posts by kidlat
Old Nov 21, 2012, 11:47 AM
Mildly Confused
Paul 1968's Avatar
UK
Joined Oct 2008
Just compared both my flybarred T-Rex 450 Pro and my FBL 450 Pro, both swash plates are the same mate.
Paul 1968 is offline Find More Posts by Paul 1968
Old Nov 21, 2012, 12:00 PM
Looptastic!
sp00fman's Avatar
Enschede, Netherlands
Joined Nov 2009
The DFC swashplate is different. it has only 2 balls on the inner plate. Just useless bling IMHO.
sp00fman is offline Find More Posts by sp00fman
Discussion 450 HK with Futaba EX radio and 3114 FASST servos SLOPPY? PaulGT3 Mini Helis 8 Nov 28, 2012 11:34 PM
Sold HK 450 head/tail/frame/canopy/motor - $20 shipped RobDog Aircraft - Electric - Helis (FS/W) 5 Nov 09, 2010 10:07 AM
Discussion Vendo HK 450 com Radio HK 7canais baratoooo !!! nino_sdk Brazil 0 Jul 26, 2010 08:42 PM
For Sale hk 450, exi 450 or copterx 450 HeliStyle Aircraft - Electric - Helis (FS/W) 5 May 15, 2010 11:57 AM
Help! HK 450 or HK 600 kilo2018 Beginner Training Area (Heli-Electric) 21 Feb 25, 2010 12:48 PM
