Old Nov 15, 2012, 01:33 PM
kidlat is offline
Find More Posts by kidlat
Joined Aug 2011
I got it! $62 shipped from US! Anyone know if you can cut out V2 canopies to fit the Pro? I got a bunch of V2s.
kidlat is offline Find More Posts by kidlat
Old Nov 15, 2012, 02:19 PM
mkipness is offline
Find More Posts by mkipness
Joined Aug 2012
Originally Posted by mhills51 View Post
This is cheap and in the states to get you a pro. http://www.valuehobby.com/helicopter...ue-tube-1.html
I had never heard of them before, but after looking around I see this which looks very interesting:
http://www.valuehobby.com/helicopter...rless-arf.html
It's out of stock, but claims they will have it tomorrow.
I also had been looking at getting the FBL HK-450. But I've always read the Tarot are better quality clones.
I've been following this thread as I want to build my own 450 clone. I'm getting bored of my 4 channel helis. However I'd like to build something that can do good 3D. Most build recommendations here seem to be more for sport flying. What components make a big difference between sport flying and 'Alan Szabo Jr' style 3D flying. Some posts say skip the clones and get an actual Align.
Or should I just get enough to so basic 3D and then change out certain electronic parts later?
Thanks - Max
mkipness is offline Find More Posts by mkipness
Old Nov 15, 2012, 02:45 PM
2Doggs is offline
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
I'm using a V2 canopy on my Pro at the moment - I just tuck the front edge of the canopy under the front canopy retainer, rather than into it, and it seems to work ok, though it helps to have a bit of foam on the inside of the canopy to bear against the battery pack.
2Doggs is offline Find More Posts by 2Doggs
Old Nov 15, 2012, 03:31 PM
jombo is offline
Find More Posts by jombo
Bad News Everyone
jombo's Avatar
United States, CT, Trumbull
Joined Dec 2007
I picked up a TT tail from HK and it didnt sit right . The gears barely meshed , but still worked .
I took off all was well , then the tail was acting weird . Brought it down and then it happened , it stopped moving all together and with a weird sound . Took the tail assembly apart and found that the shaft barely going into the gear. Good thing I didn't strip anything .
The fix was to grind some of the tube stop off so it slid the tube into the block more. After that it was a nice tight fit and the gears meshed perfectly . Now i have another problem , since i moved the tube in more , now i need to adjust the tail from spinning
jombo is offline Find More Posts by jombo
Old Nov 15, 2012, 06:59 PM
kidlat is offline
Joined Aug 2011
My servos from the V2 should fit the Pro right? I know I ask to many questions
Old Nov 15, 2012, 07:41 PM
Atomic Skull is offline
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
Originally Posted by tonyastro View Post
Is the V2 convertible to Pro?
No, but you can convert to FBL easily enough. If you have a V2 that flies great then I think it makes more sense to just upgrade that to FBL than to start over with a whole new kit that might not turn out as well as the machine you have now.
Atomic Skull is offline Find More Posts by Atomic Skull
Old Nov 15, 2012, 07:48 PM
2Doggs is offline
Two helis flying
2Doggs's Avatar
Joined Nov 2009
The eye of the beholder
Never really seen the attraction of the Pro, it's just uglier, harder to work on and costs more in a crash because of the torque tube.
but the belt pro, on the other hand - durable tail, along with the super strong main frames of the Pro. As for ugly - what could be uglier than a big lump of a tail servo at the front of a tail boom? The Pro is certainly a bit more awkward to work on, but not hard - and you get used to taking the cyclic servos out in a lump with the bearing blocks. I like it's simplicity - you could hardly build a heli with less parts, especially if it's FBL. The V1 Pro canopy isn't particularly inspired, but there are more elegant, more pointy variants available. I guess it's just a case of horses for courses.
Old Nov 15, 2012, 08:13 PM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
the pro is not bad once you realize you need to take half the frame off to work on. Once you know that tho it's much easier to fix because taking half the frame off is 100x easier than removing half the sport.
mhills51 is offline Find More Posts by mhills51
Old Nov 15, 2012, 08:38 PM
pitchp is offline
Find More Posts by pitchp
Retired
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
each to their own, this is so true.
pitchp is offline Find More Posts by pitchp
Old Nov 15, 2012, 08:40 PM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
no need to be embarrased by your point of view AS, you have the right to say your opinion about the pro, some will agree like myself and some wont. That's just the way it is
Old Nov 15, 2012, 09:32 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
Also it's hard to be a critic if you have not owned both.
Old Nov 16, 2012, 10:43 AM
jombo is offline
Bad News Everyone
jombo's Avatar
Joined Dec 2007
I will go with fly what your use to . I have both also and after going to the pro all Ican say is it flys more stable in the air . there is proof of this too . the head on the flybar cage and blade grips have more mass , meaning more centrifugal force making it more stable.
this is why on flybarless blade grips on most helis are a lot bigger than the standard blade grips . this will make it easier to convert to flybarless too.
the SEv2 i found to be more agile for 3D . When i was learning to fly i wish i had the Pro , even a not so good setup it will still fly well .
i must have around 6 pro's and 7 SEv2 , about 4 of each still in the box waiting to be built . Since getting the bigger birds , these mostly sit and wait for a turn in the air
Old Nov 16, 2012, 11:39 AM
kidlat is offline
Joined Aug 2011
I don't remember where I read it but the reason I'm switching to Pro is it has better aerobatics? I just read it somewhere.
Old Nov 16, 2012, 12:51 PM
2Doggs is offline
Two helis flying
2Doggs's Avatar
Joined Nov 2009
The Pro was designed to be simple, with single piece main frames, but also to centralise mass as much as possible - hence the tail servo is tucked between the frames at the rear, rather than being mounted further out along the boom. The cyclic servos all use the same length links, which results in a purer linkage geometry, minimising unwanted interactions. The head uses slightly longer grips, giving a small increase in rotor diameter, and the mainshaft and swash were designed to give -13 to +13 pitch range. The tail rotor to main rotor gear ratio is reduced, when compared with earlier models, since the Pro is optimised for higher HS, anything up to 3500 or so.
Old Nov 16, 2012, 01:16 PM
kidlat is offline
Joined Aug 2011
Thanks again 2Doggs!
Help! HK 450 or HK 600 kilo2018 Beginner Training Area (Heli-Electric) 29 Apr 19, 2016 03:56 AM
Discussion 450 HK with Futaba EX radio and 3114 FASST servos SLOPPY? PaulGT3 Mini Helis 9 Sep 02, 2013 05:10 PM
Sold HK 450 head/tail/frame/canopy/motor - $20 shipped RobDog Aircraft - Electric - Helis (FS/W) 5 Nov 09, 2010 10:07 AM
Discussion Vendo HK 450 com Radio HK 7canais baratoooo !!! nino_sdk Brazil 0 Jul 26, 2010 08:42 PM
For Sale hk 450, exi 450 or copterx 450 HeliStyle Aircraft - Electric - Helis (FS/W) 5 May 15, 2010 11:57 AM
