Old Nov 01, 2012, 02:36 AM
J.Richert is offline
Find More Posts by J.Richert
Israel
Joined Apr 2009
Originally Posted by sp00fman View Post
Check if the voltage of the center pin reaches the pin on the chip.
Yes, sure does. That's what I checked before posting.
J.Richert is offline Find More Posts by J.Richert
Old Nov 01, 2012, 04:21 AM
MikeHRC is offline
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
Originally Posted by VelocityRC View Post
Super Nice Video !!!
Thanks for taking the time to do that. I'm interested in geting one of these. I noticed when you were checking cyclic with the circle near the end of the vid that you have a mode 2 TX. As you know cyclic is on the right stick. I fly mode one where elev is on the left stick and aile is on the right stick.
Is there a mode one setting in the programming menu on the Robird setup software ??
Bill S.
Don't worry - your Radio will sort all of that out, it will work fine Mode 1
MikeHRC is offline Find More Posts by MikeHRC
Old Nov 01, 2012, 04:48 AM
Harrow is offline
Find More Posts by Harrow
Yes, I know it's upside down.
Sydney, Australia
Joined Dec 2008
Bill S.
Bill, it doesn't matter if you are using mode 1 or mode 2. The receiver simply sends aileron and elevator signals to the flybarless unit. It doesn't matter how your radio is programmed.
Harrow is offline Find More Posts by Harrow
Old Nov 01, 2012, 09:50 AM
VelocityRC is offline
Find More Posts by VelocityRC
If it Works, You Better Fix It
VelocityRC's Avatar
United States, ID, CDA
Joined Feb 2011
Thanks, this FBL is all new to me. It will probably be my X-Mas present to myself.
Happy Flying !!!
Bill S.
VelocityRC is offline Find More Posts by VelocityRC
Old Nov 01, 2012, 10:45 AM
rcjim11 is offline
Find More Posts by rcjim11
rcflyer
UK
Joined Jun 2010
Does anyone know how this slides along?
http://www.hobbyking.com/hobbyking/s...o%5FMount.html
Cheers
Jim
rcjim11 is offline Find More Posts by rcjim11
Old Nov 01, 2012, 10:50 AM
rcjim11 is offline
rcflyer
UK
Joined Jun 2010
Also, what main blades do you guys use?
Old Nov 01, 2012, 04:06 PM
sp00fman is offline
Find More Posts by sp00fman
Looptastic!
sp00fman's Avatar
Enschede, Netherlands
Joined Nov 2009
I really like the hobbyking 335 mm blades. both in fiberglass and carbon. Actual 325mm from bolt hole to tip. Stiff blade,Chord is wider than the 325mm but about same thickness, weight and price. Will never buy anything else for my 450.
Comparing it just gives more pop on collective, loops and continuous flips and rolls are easier as it tends to transition smoother with less collective input through he move, even with relative low headspeed. Nicer sound also.
I can understand why some like to stretch the 450 and run even longer blades.
sp00fman is offline Find More Posts by sp00fman
Old Nov 01, 2012, 04:56 PM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
I have fell in love with the ALZRC FBL blades. They are cross woven strong always perfect balance and the blemished ones can be had for $13
mhills51 is offline Find More Posts by mhills51
Old Nov 01, 2012, 05:01 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
That servo mount is just like the others that break. The best I found is just the standard plastic or if you want metal it will cost you in weight.
Old Nov 01, 2012, 09:06 PM
DudeInMyrtleBch is offline
Find More Posts by DudeInMyrtleBch
United States, SC, Myrtle Beach
Joined Jun 2011
I've got one coming in on Tuesday of next week. I'm installing a Henge 922MG. I'll let you know how it goes.
Cheers
Jim
DudeInMyrtleBch is offline Find More Posts by DudeInMyrtleBch
Old Nov 02, 2012, 12:55 AM
pitchp is offline
Find More Posts by pitchp
Retired
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
nice blades
pitchp is offline Find More Posts by pitchp
Old Nov 02, 2012, 01:53 AM
fishfiend is offline
Find More Posts by fishfiend
Joined Jun 2008
I want one of these http://www.oomodel.com/alzrc-devil-4...t-p-64103.html
And you can use 360mm blades on this one, and fit the fbl controller on the boom too! Just need to convince the wife.........
fishfiend is offline Find More Posts by fishfiend
Old Nov 02, 2012, 03:43 AM
clicky is offline
Find More Posts by clicky
UK
Joined May 2007
When mentioned 360mm blades - any recommendation for good ones? I need a set for my stretched MT O : )
clicky is offline Find More Posts by clicky
Old Nov 02, 2012, 04:40 AM
Harrow is offline
Sydney, Australia
Joined Dec 2008
I started using genuine Align 325D Pro blades a while ago and love them. At around $15 I think they are not too expensive, and worth the extra cost.
Old Nov 02, 2012, 04:49 AM
rcjim11 is offline
rcflyer
UK
Joined Jun 2010
They look like a good cheap option, the reason why I'm changing from the stock ones is that I've heard they blow off the blade grips!
Do flybarless blades work on fb?
Cheers
Jim
Help! HK 450 or HK 600 kilo2018 Beginner Training Area (Heli-Electric) 29 Apr 19, 2016 03:56 AM
Discussion 450 HK with Futaba EX radio and 3114 FASST servos SLOPPY? PaulGT3 Mini Helis 9 Sep 02, 2013 05:10 PM
Sold HK 450 head/tail/frame/canopy/motor - $20 shipped RobDog Aircraft - Electric - Helis (FS/W) 5 Nov 09, 2010 10:07 AM
Discussion Vendo HK 450 com Radio HK 7canais baratoooo !!! nino_sdk Brazil 0 Jul 26, 2010 08:42 PM
For Sale hk 450, exi 450 or copterx 450 HeliStyle Aircraft - Electric - Helis (FS/W) 5 May 15, 2010 11:57 AM
