Old Oct 22, 2012, 05:06 PM
VelocityRC is online now
Find More Posts by VelocityRC
If it Works, You Better Fix It
VelocityRC's Avatar
United States, ID, CDA
Joined Feb 2011
NIce looking heli AS. What motor are you running in that ?
Happy Flying !!!
Bill S.
VelocityRC is online now Find More Posts by VelocityRC
Old Oct 23, 2012, 01:30 AM
spaaarky21 is offline
Find More Posts by spaaarky21
Helicopter Baron
spaaarky21's Avatar
United States, CO, Golden
Joined Feb 2012
Originally Posted by Atomic Skull View Post
Trex 500 with Microbeast and analog Hitec HS-225MG's on cyclic: [Vid]
I'm not saying that analog doesn't work. If something fly well, it flies well - digital or not. I'm just say that all things considered, digital is preferable. It's not necessary, but it's preferable, especially now that the price difference isn't what it used to be.
One interesting thing about analog servos, they are less likely to strip in a crash than a digital because they don't hold position as strongly.
You mentioned digital being more likely to strip because of the holding torque. Yeah, that sounds a little more likely but I'd rather build a heli to fly better, not crash better.
Originally Posted by rcjim11 View Post
The hotrod version sounds awesome! Did you need a beefier motor to compensate for the extra weight and do the 306s fit in the slots without trimming also?
The TGY-306G's do fit the stock slots. That was in a Pro V2 though, where the servo bodies stick out from the frame. I'm not sure about other 450 models. They weigh 21g each but the length and width is the standard "9g servo" size. For three cyclic servos, the TGY-306G's will add 23g over the stock Align DS410M servos. I don't imagine that adding 23g to a 450 would require a beefier motor but I couldn't say honestly. It was a 4S setup so I was already running a lower KV motor.
For the "hotrod" 450 Pro V2 setup, I was also using a Savox SH-0262MG tail servo, Phoenix Ice Lite 50 ESC for the governor and programmable BEC voltage, Spektrum telemetry, DFC head, the new double pivot tail assembly (Align H45181), slant/helical main gears, miscellaneous CNC upgrades and two-piece skids. I just like those skids better for some reason. It seemed like a nice setup once I got the cyclic gain worked out on the gyro but I bought a Gaui X5 around the same time and flying the 450 just wasn't the same.
spaaarky21 is offline Find More Posts by spaaarky21
Old Oct 23, 2012, 07:21 AM
2Doggs is offline
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
Originally Posted by spaaarky21 View Post
....the new double pivot tail assembly (Align H45181)
Wow, never knew this existed! I've always hated the sloppy single sided stock arrangement! Pity it comes at such a premium!
2Doggs is offline Find More Posts by 2Doggs
Old Oct 23, 2012, 09:30 AM
MikeHRC is offline
Find More Posts by MikeHRC
Team Mulikow 3D
Oxfordshire, UK
Joined Jan 2007
And with MKS not using chinese factories it's very unlikely that they are "unauthorized" relabels like what happened with the YGE ESC's.
AS - is there any info to support that? I have a number of YEP's (as well as an ICE from HIModel which is the same. I'm really really happy with them, but they are much larger than the equivalent YGE's.
I'm not trying to start an arguement - just wondering if this is for real or one of the urban myths that we get occasionally.
Cheers,
Mike.
MikeHRC is offline Find More Posts by MikeHRC
Old Oct 24, 2012, 06:45 PM
pitchp is offline
Find More Posts by pitchp
Retired
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
http://www.youtube.com/watch?v=krsb4AzkZ2k
One interesting thing about analog servos, they are less likely to strip in a crash than a digital because they don't hold position as strongly. The HS-65MG almost never strips while HS-5065MG strips so regularly in crashes that you're better off replacing the metal gears with carbon after the first crash because they're cheaper and the metal ones strip anyway. (The gear train in the HS-5065 is the same as the HS-65 so you can use the carbon HS-65 gear set)
very nice flying AS
pitchp is offline Find More Posts by pitchp
Old Oct 24, 2012, 06:54 PM
ahamay is offline
Find More Posts by ahamay
ahamay's Avatar
Australia, QLD, Gold Coast
Joined Jun 2012
Are the carbon gears the gearset for the HS-65HB ? I think hobbyking sells them ? I'm running 5065's so I might stock up on these if they are the right ones ?
Cheers
ahamay is offline Find More Posts by ahamay
Old Oct 24, 2012, 07:32 PM
DudeInMyrtleBch is offline
Find More Posts by DudeInMyrtleBch
United States, SC, Myrtle Beach
Joined Jun 2011
Do the new HK 450 Pro V2 FBL helis come with helical main gears and pinion?
DudeInMyrtleBch is offline Find More Posts by DudeInMyrtleBch
Old Oct 24, 2012, 07:42 PM
choopi is online now
Find More Posts by choopi
choopi's Avatar
New Brunswick
Joined Feb 2006
Not on mine!
choopi is online now Find More Posts by choopi
Old Oct 24, 2012, 07:59 PM
Atomic Skull is offline
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
Happy Flying !!!
Bill S.
2100kv Turnigy (one of the red and chrome Suppo relables). It's a 4S heli.
Atomic Skull is offline Find More Posts by Atomic Skull
Old Oct 24, 2012, 08:01 PM
Joined Dec 2011
Originally Posted by pitchp View Post
very nice flying AS
That isn't me, it's just an example of an FBL on analog servos I found on Youtube.
Old Oct 24, 2012, 08:02 PM
Joined Dec 2011
Cheers
I'm pretty sure that they are.
Old Oct 25, 2012, 08:20 AM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
Guys the robird fbl unit is now available at HK
http://www.hobbyking.com/hobbyking/s...ss_System.html
Our friend Zaihan testing the robird
Tarot Pro 450 V2 w Robird G31 (2 min 42 sec)
Old Oct 25, 2012, 08:50 AM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
Looks like Tarot is changing as well.
mhills51 is offline Find More Posts by mhills51
Old Oct 25, 2012, 08:54 AM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
Also new Devo FPV 7tx
Old Oct 25, 2012, 11:57 AM
jombo is offline
Find More Posts by jombo
Bad News Everyone
jombo's Avatar
United States, CT, Trumbull
Joined Dec 2007
I use this one and free shipping . I hate to pay for crazy shipping
http://www.scaleflying.com/Black-Wid...SB_p_2600.html
jombo is offline Find More Posts by jombo
Help! HK 450 or HK 600 kilo2018 Beginner Training Area (Heli-Electric) 29 Apr 19, 2016 03:56 AM
Discussion 450 HK with Futaba EX radio and 3114 FASST servos SLOPPY? PaulGT3 Mini Helis 9 Sep 02, 2013 05:10 PM
Sold HK 450 head/tail/frame/canopy/motor - $20 shipped RobDog Aircraft - Electric - Helis (FS/W) 5 Nov 09, 2010 10:07 AM
Discussion Vendo HK 450 com Radio HK 7canais baratoooo !!! nino_sdk Brazil 0 Jul 26, 2010 08:42 PM
For Sale hk 450, exi 450 or copterx 450 HeliStyle Aircraft - Electric - Helis (FS/W) 5 May 15, 2010 11:57 AM
