Old Oct 21, 2012, 02:49 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
I could use one of my Eagle Tree loggers to log receiver,servos and FBL loads,amp.volts etc but simple fact is that if the tattle tale shows that voltage drop is with in the safe range all is good.
No Spektrum 2.4 brownouts no FBL gyro reboots / glitches are all that I am concerned about. I really do not care if the ESC sees a short spike over its' rating as liong as voltage at the receiver is still good.
A month or so back my son had his Tarot ZYX-S reboot on the ground during spool up a couple of different times. I installed a DE Sports BEC (3.5A) and no more issues. His latest acquired heli a Trex 450 which he put a ZYZ in was flying OK then all of a sudden in FFF and a hard banked turn the tail started twiching extremly fast and then the heli slid hard over and he had to use full opposite cyclic to get it leveled enough to land it. Swash remained full tilt after touch down. I believe he has parked it until he gets another ESC or a ESC wiith a good switcher BEC built in.
He had the same ZYX-S in the T rex that acted up in his B450 before installing the DE Sports BEC. This same unit back in his B450 and he flew it this morning and it is working fine again. Guess I should note that I always hard wire the BEC to the ESC so those stayed in the B450 and he was using a common Sense 45A ESC in the Trex. Neither one of use could find BEC specs. for the CS ESC's .
Underlining issue is that FBL heads and gyros do in fact place more loads on the servos and from what i have read DFC heads are even worse.
Charles
Old Oct 21, 2012, 06:09 PM
Atomic Skull is offline
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
Got some pics of my 450 sport today.
Atomic Skull is offline Find More Posts by Atomic Skull
Old Oct 21, 2012, 06:33 PM
2Doggs is offline
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
Collective range?
Looks good! I like that canopy, and I see you're using the Pro one-piece landing gear. How are you getting on for servo travel using that RJX head? I have to use 15mm arms on my 450 Pro, but on the Sport the lower servo arm can hit the main gear.
2Doggs is offline Find More Posts by 2Doggs
Old Oct 21, 2012, 06:53 PM
Joined Dec 2011
Balls are 12mm out (straight links in relation to the swash arms), I clipped off the ends of the arms after that. Robird G31 says I have enough pitch range (the setup would complain about if if the arms were too short) I get +/- 12 degrees with plenty to spare for cyclic. The arm actually has about 3mm to spare at 100% travel before it would hit the gear. I'm using Ino-Labs HG-D260's for cyclic servos which causes a tiny bit of outward angle on the links because they are oversized for a 450. However this is approximately equal to the sideways skewing on the elevator link, and in any case the FBL setup seems to be able to figure out the geometry because the swash is completely level throughout it's travel range and I didn't need any subtrim at min/max collective to correct for an unlevel swash.
Tarot sells the one piece skids with the holes pre drilled for the 450 sport. thinking about getting some neon yellow Gorilla Gear though.
The canopy is higher quality than your typical clone canopy but I think I might give it a clear coat over everything. It's not as good as the simplified Fusuno canopies Hobbyking sells but with a clear coat it would be. Fiberglass seems equal though.
Old Oct 21, 2012, 07:36 PM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
Here is a pic of mine from this weekend. With my HB800 gyro
mhills51 is offline Find More Posts by mhills51
Old Oct 21, 2012, 07:49 PM
pitchp is offline
Find More Posts by pitchp
Retired
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
very nice AS. that looks hot!
pitchp is offline Find More Posts by pitchp
Old Oct 21, 2012, 08:24 PM
epoweredrc is offline
Find More Posts by epoweredrc
27 yrs. of Aircraft flying.
epoweredrc's Avatar
United States, GA, Tallapoosa
Very nice looking bird Atomic Skull, I like the canopy, man that looks just like my trex450 sport frame. I like the aluminum batt tray however. Very nice wiring I like that Orange mesh I need to get me some of that, was looking today not sure what MM need. I myself Like my Trex 5oo gear the grass where i fly is like normal front yard grass so anything to give me more height is good.
Anyone know what size dia. the Trot 450 boom is?
Was going post a pic but my phone being stupid. And EDF is right, The trex is in the garage until next week I just ordered a CC10A BEC never heard anything bad about them.
epoweredrc is offline Find More Posts by epoweredrc
Old Oct 21, 2012, 09:46 PM
2Doggs is offline
Two helis flying
2Doggs's Avatar
Joined Nov 2009
All that orange bling on the rear, and a yellow main gear with a white auto gear?
Old Oct 21, 2012, 09:56 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
Kinda sticks out lol! Our local photographer was at the park. I kept hovering nose in and going inverted. I wanted him to get some good inverted pics. I even hovered around right over the pad only a couple of feet from us, but I guess he thought the going inverted looked cooler. That is what you get when your photographer is also one of the best pilots at the park lol!
Old Oct 21, 2012, 10:58 PM
epoweredrc's Avatar
I feel you, had a local newspaper come out interveiw some of us took pics i was knife edging my 42" ajslick 3 foot off ground whole runway and they put a pic of me flying upright with my micro bipe in the paper
Old Oct 22, 2012, 12:28 AM
spaaarky21 is offline
Find More Posts by spaaarky21
Helicopter Baron
spaaarky21's Avatar
United States, CO, Golden
Joined Feb 2012
Originally Posted by rcjim11 View Post
Ok, are those corona servos good for 3d, cause I want to buy the kit to allow me to do 3d even if not at the moment.?
I was looking at these as decent fast servos.. http://www.hobbyking.com/hobbyking/s...06sec_21g.html
All round?
Thanks again
Jim
I like the Corona DS-929MG servos. I use them in a lot of different things. They've always worked well for me and the specs compare well to stock Align cyclic servos.
For the tail, you would want something faster. Possibly a DS-919MG, which is faster than the stock DS520 and nearly as strong.
I used Turnigy TGY-306G's as cyclic servos on a "hot rod" 450 Pro V2 I built. I only flew that helicopter a handful of times before selling it but the servos seemed good. I had a Savox tail servo on that heli but I sold a spare 306 to a friend for his 450 and it's been working really well for him. People suspect that the TGY-306G's are rebranded MKS DS95's. Their specs, case design and the fact that they are made in Taiwan seems to support that.
spaaarky21 is offline Find More Posts by spaaarky21
Old Oct 22, 2012, 01:15 AM
Helicopter Baron
spaaarky21's Avatar
Joined Feb 2012
Originally Posted by everydayflyer View Post
Using analog servos on a helicopter is unappealing, especially a flybarless one.
Why is that ? I know some FBL units require all digitials but most let you select all analog all digitial or mixed.
Most FBL gyros give you an option use analog cyclic servos but in principle, I would prefer digital cyclic servos for the same reasons that digital tail servos are practically universal at this point. With the gyro constantly making small adjustments (much smaller and more frequent than any pilot input), I would prefer digital servos for their precision, narrower deadband, greater torque when moving small distances and their tendency to not overshoot the target position and "bounce" back as much as analog servos. Obviously those are all generalities about analog vs digital, but those are some of the main benefits of digital servos.
Old Oct 22, 2012, 01:27 AM
Joined Dec 2011
Trex 500 with Microbeast and analog Hitec HS-225MG's on cyclic:
T-rex 500 with Micobeast (4 min 13 sec)
One interesting thing about analog servos, they are less likely to strip in a crash than a digital because they don't hold position as strongly. The HS-65MG almost never strips while HS-5065MG strips so regularly in crashes that you're better off replacing the metal gears with carbon after the first crash because they're cheaper and the metal ones strip anyway. (The gear train in the HS-5065 is the same as the HS-65 so you can use the carbon HS-65 gear set)
Old Oct 22, 2012, 02:33 AM
rcjim11 is offline
Find More Posts by rcjim11
rcflyer
UK
Joined Jun 2010
The hotrod version sounds awesome! Did you need a beefier motor to compensate for the extra weight and do the 306s fit in the slots without trimming also?
Jim
rcjim11 is offline Find More Posts by rcjim11
Old Oct 22, 2012, 01:54 PM
Joined Dec 2011
Those are MKS clones, not relabeled MKS. MKS does not sell relabeled versions of their servos.
http://rc-trader.co.uk/blog/mks-servo-cloned
And with MKS not using chinese factories it's very unlikely that they are "unauthorized" relabels like what happened with the YGE ESC's.
Help! HK 450 or HK 600 kilo2018 Beginner Training Area (Heli-Electric) 29 Apr 19, 2016 03:56 AM
Discussion 450 HK with Futaba EX radio and 3114 FASST servos SLOPPY? PaulGT3 Mini Helis 9 Sep 02, 2013 05:10 PM
Sold HK 450 head/tail/frame/canopy/motor - $20 shipped RobDog Aircraft - Electric - Helis (FS/W) 5 Nov 09, 2010 10:07 AM
Discussion Vendo HK 450 com Radio HK 7canais baratoooo !!! nino_sdk Brazil 0 Jul 26, 2010 08:42 PM
For Sale hk 450, exi 450 or copterx 450 HeliStyle Aircraft - Electric - Helis (FS/W) 5 May 15, 2010 11:57 AM
