Old Aug 08, 2012, 04:42 PM
Good News Everyone
jombo's Avatar
United States, CT, Trumbull
Joined Dec 2007
Swat343 , looks really nice
jombo is offline Find More Posts by jombo
Latest blog entry: NH airshow
Old Aug 09, 2012, 01:55 PM
South London United Kingdom
Joined Jun 2003
Hi All
Quick word of warning.
Needed to shorten the tail pushrod on my HK450 Pro. I read somewhere that if you heat the metal end, it will soften the glue, so you can take the end off, shorten the rod, and then glue it back on.
Well, it works, rather too well.
Heating does soften the glue, but if the rod is not fully pushed into the connector, it also expands the pocket of air behind it.
Result is, when the glue finally lets go, the end fires off like a rocket.
Mine has, and disappeared somewhere in the flat, probably never to be seen again!
You have been warned!!!!!!!
BL
Border Lord is offline Find More Posts by Border Lord
Old Aug 09, 2012, 02:25 PM
Good News Everyone
jombo's Avatar
Joined Dec 2007
Originally Posted by Border Lord View Post
Hi All
BL
yep it will , i glue mine but i also use a drill bit to pin it in. i tried just gluing it but it acts like a hydraulic pump and pushes the rod back out .
if i drill a hole through it it lets the excess glue out and i also can put a small T pin through it , then cut both ends off .
Old Aug 09, 2012, 03:11 PM
Joined Apr 2011
Originally Posted by Swat342 View Post
Well I just finished my HK 450 pro FBL build last night. All I have to do is balance and install the blades and dial in the FBL unit. It was a fun build however I did noticed the difference in quality between the EXI and HK. The EXI carbon fiber is way cleaner than HK. I am excited about getting her in the air. I am kind of curious to see how she performs with the RX in her belly and not installed on the outside. Total cost was under $200.
Looks good.
What motor, and servo's are you using?
clearprop88 is offline Find More Posts by clearprop88
Old Aug 09, 2012, 04:18 PM
Paycheck flyer
mhills51's Avatar
kansas city
Joined Feb 2007
Hey guys! looks like you don't need thrust bearings, washers, screws, or heck even a feathering shaft with the new 450DFC unit. lol! it's all listed in the directions as Optional?
mhills51 is offline Find More Posts by mhills51
Latest blog entry: Logo build
Old Aug 09, 2012, 07:54 PM
Good News Everyone
jombo's Avatar
Joined Dec 2007
lol , i know . i used everything from my 450 pro head when i did the switch . mine has thrust bearings and trueblood green dampers ( i think trueblood makes the green ones ) . mine is really solid and dosent move up and down like the regular head did .
Old Aug 09, 2012, 08:29 PM
Paycheck flyer
mhills51's Avatar
kansas city
Joined Feb 2007
The new one comes with hard plastic dampers NO give. lol! I just ordered new thrust bearings and shaft. My last ones didn't make it!
Just waiting for my swash to show. Then I will green loctite the head onto the shaft. It wobbles. The newest optional one has the two extra screws at the bottom to clamp it on the shaft.
Old Aug 09, 2012, 08:48 PM
Good News Everyone
jombo's Avatar
Joined Dec 2007
mine did the same thing , it was loose on the shaft to the head . i overtightened the bolt and snapped the original one . i have plenty of spare head bolts . i used red loctite on mine , it dosent move at all . i dont need a bolt anymore .
Old Aug 10, 2012, 12:59 AM
Sweden
Joined Jan 2010
Why the LOL? This is the sane thing to do, since it will offload the DFC links to swash from some of that moment. (edit: torque?)
sandos is offline Find More Posts by sandos
Old Aug 10, 2012, 03:05 AM
Joined Dec 2011
That's one thing I love about the RJX head, it does not wobble on the shaft at all. The bolts that hold the swash followers onto the headblock also clamp the headblock onto the shaft so it can't move. For extra security I like to use 18mm screws and put a nut on the other side.
Atomic Skull is offline Find More Posts by Atomic Skull
Old Aug 10, 2012, 03:21 AM
wlee1017's Avatar
Joined Jul 2011
Look like you are happy & have good time with rjx fbl head. I think hk did something and improved. Can u post me the link & parts mod for rjx fbl head. My son want to have another try on his old 450. Thank.
wlee1017 is offline Find More Posts by wlee1017
Old Aug 10, 2012, 03:27 AM
wlee1017's Avatar
Joined Jul 2011
Never mind. My son found your old post. Thanks.
Old Aug 10, 2012, 03:29 AM
Joined Dec 2011
Make sure to locktite the bearings on the headblock side of the grips. You need to do that to eliminate lateral play.
Old Aug 10, 2012, 04:04 AM
wlee1017's Avatar
Joined Jul 2011
Thank for tips.
Old Aug 10, 2012, 08:40 AM
Crash Expert
Swat342's Avatar
United States, OK, Yukon
Joined Jan 2011
Originally Posted by clearprop88 View Post
Looks good.
The EXI, Metal Digital Servos from Xheli, and Turnigy helidrive sk3 Comp Moter.
http://www.hobbyking.com/hobbyking/s...dProduct=22399
http://www.xheli.com/exi-servo-d213f.html
Was playing around with it last night and pulled the torque tube out. Noticed it was bent so I am about to install an align tt and tt bearing. Maybe this will stop some vibs also. Can't wait to fly it.
Swat342 is offline Find More Posts by Swat342
Discussion 450 HK with Futaba EX radio and 3114 FASST servos SLOPPY? PaulGT3 Mini Helis 8 Nov 28, 2012 11:34 PM
Sold HK 450 head/tail/frame/canopy/motor - $20 shipped RobDog Aircraft - Electric - Helis (FS/W) 5 Nov 09, 2010 10:07 AM
Discussion Vendo HK 450 com Radio HK 7canais baratoooo !!! nino_sdk Brazil 0 Jul 26, 2010 08:42 PM
For Sale hk 450, exi 450 or copterx 450 HeliStyle Aircraft - Electric - Helis (FS/W) 5 May 15, 2010 11:57 AM
Help! HK 450 or HK 600 kilo2018 Beginner Training Area (Heli-Electric) 21 Feb 25, 2010 12:48 PM
