Old Jul 21, 2012, 02:02 PM
clearprop88 is offline
Find More Posts by clearprop88
Joined Apr 2011
I just ordered the downlinks to convert my RJX head to DFC.
If you want to do the conversion this is the part you need.
H45165T : 450DFC Pitch Link Assy
There are several vendors on eBay. I ordered it from this company in Florida.
http://www.ebay.com/itm/Align-TREX-4...item3cc89ba044
$18.99 shipped
You might be able to use the Tarot links, but they didn't look as sturdy as the Align ones.
clearprop88 is offline Find More Posts by clearprop88
Old Jul 21, 2012, 07:20 PM
Border Lord is offline
Find More Posts by Border Lord
South London United Kingdom
Joined Jun 2003
mhills51
Thanks for the thought, and the link. I already have a Turnigy Plush 40a which is 6s capable, so I am thinking motor and LiPo are all I need.
This for LiPo
http://www.hobbyking.com/hobbyking/s...dproduct=23919
but I am undecided on motor.
Either Tarot
http://www.ac-rc.com/product_info.ph...etplluof867dm5
or 3dPro
http://www.rc711.com/shop/3dpro-1800...?cPath=166_255
Anybody venture an opinion as to which is better?
BL
Border Lord is offline Find More Posts by Border Lord
Old Jul 21, 2012, 08:02 PM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
Tarot is starting to have a better rep. I think. I have a 3800kv that was good, but I had to take it out. Couldn't get it geared right for the slanted gearing.
mhills51 is offline Find More Posts by mhills51
Old Jul 22, 2012, 12:44 AM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
Tarot have now released a slant 9T and 10T pinion, which allows higher kv motors, with a 3.17mm shaft, to be used:
http://www.oomodel.com/tarot-450-pro...t-p-63492.html
http://www.oomodel.com/tarot-450-par...r-p-63565.html
beenflying is offline Find More Posts by beenflying
Old Jul 22, 2012, 12:57 AM
Atomic Skull is offline
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
I just found a source of dirt cheap stainless steel cap head and button head allen screws.
http://www.trimcraftaviationrc.com/
Only thing they don't have is cap head sheet metal screws for plastic parts (though you can use machine screws for that) and collar screws. They don't have 18mm and 9mm M2 for the tail but you can substitute 20mm and 12mm and put an M2 nut on the other side or just cut the screw down.
Atomic Skull is offline Find More Posts by Atomic Skull
Old Jul 22, 2012, 12:58 AM
Joined Dec 2011
Using a slant gear in a helicopter that doesn't have thrust bearings on the mainshaft is just asking for problems.
Old Jul 22, 2012, 01:11 AM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
Funny my 450 and 500 don't seem to have a problem. Come to think about it the SAB Goblin with all it's power and no thrust bearing does not seem to have a issue. I think it's ok.
Old Jul 22, 2012, 02:32 AM
Joined Dec 2011
The slant gear will put axial load on the mainshaft bearings and wear them out faster.
Old Jul 22, 2012, 04:18 AM
Harrow is offline
Find More Posts by Harrow
Yes, I know it's upside down.
Sydney, Australia
Joined Dec 2008
The axial force produced by the slant gear is only a small % of the lift forces produced by the main blades. Gaui X7 is another one with helical gears as standard and no thrust bearings.
Harrow is offline Find More Posts by Harrow
Old Jul 22, 2012, 05:00 AM
Truglodite is offline
Find More Posts by Truglodite
Registered Aircraft Offender
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
Originally Posted by Harrow View Post
The axial force produced by the slant gear is only a % of the lift forces produced by the main blades. Gaui X7 is another one with helical gears as standard and no thrust bearings.
Motor bearings are the concern with slant gears. They can handle it for a while, but not as long as without. Bigger helis need slant gears because they can strip gears with the power they have. Those helis also have much larger motor bearings, and spin lower RPM's in general. 450's don't strip unless you crash, plus their motor bearings are tiny and spin really fast.
Kev
Truglodite is offline Find More Posts by Truglodite
Old Jul 22, 2012, 05:01 AM
pitchp is offline
Find More Posts by pitchp
No Longer Active
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
Tarot is starting to have a better rep. .
Tarot is definately going beyond leaps and bounds. Once Tarot makes a Logo 600 clone. I'd be definately be one of the first to buy one!!
http://translate.googleusercontent.c...JbVFjaa9lGx_cw
pitchp is offline Find More Posts by pitchp
Old Jul 22, 2012, 11:54 AM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
and speaking of a 450 that small% is even smaller than that lol! I like them for how smooth and quite it makes them. I don't like the limited gearing combos. Go figure my tarot 3800kv is 3.5 shaft so it will sit on the shelf a little longer.
Old Jul 22, 2012, 05:22 PM
Joined Dec 2011
Personally I like my helicopters to be loud. It keeps the dog walkers and lone soccer guys off the field. I see one of them coming and a few low high speed passes and hard knife edge turns to make the blades fart and they usually think better of it.
Old Jul 22, 2012, 05:24 PM
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
ROTFL AS!
Kev
Old Jul 22, 2012, 11:13 PM
pitchp is offline
No Longer Active
pitchp's Avatar
Joined Aug 2010
New Flybarless Pitch Guage!
http://www.hobbyking.com/hobbyking/s...martphone.html
Help! HK 450 or HK 600 kilo2018 Beginner Training Area (Heli-Electric) 27 Dec 24, 2015 06:02 PM
Discussion 450 HK with Futaba EX radio and 3114 FASST servos SLOPPY? PaulGT3 Mini Helis 9 Sep 02, 2013 06:10 PM
Sold HK 450 head/tail/frame/canopy/motor - $20 shipped RobDog Aircraft - Electric - Helis (FS/W) 5 Nov 09, 2010 11:07 AM
Discussion Vendo HK 450 com Radio HK 7canais baratoooo !!! nino_sdk Brazil 0 Jul 26, 2010 09:42 PM
For Sale hk 450, exi 450 or copterx 450 HeliStyle Aircraft - Electric - Helis (FS/W) 5 May 15, 2010 12:57 PM
