Old Nov 21, 2010, 08:50 AM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Originally Posted by frac View Post
how exactly do you do that??
probably a broken or uninstalled shear bolt, top or bottom, or the pinion/main gear mesh
Easy - they install it upside down at the factory.
pmackenzie is offline Find More Posts by pmackenzie
Old Nov 21, 2010, 11:31 AM
Piper J3 is offline
Find More Posts by Piper J3
Full Scale Piper Cub Driver
Piper J3's Avatar
Hinckley, Ohio
Joined Nov 2008
LiPo usage...
I ran a test to determine LiPo usage on my Mini Titan SE. Machine is stock with motor and ESC as supplied. I did a sustained 4 minute hover with starting voltage = 12.4 and ending voltage =11.3. LiPo is HK 2200 Nano with about 20 cycles. I checked individual cell voltages before test and they were balanced. Best I can determine from LiPo charts is 11.3 ending voltage = approx 30% remaining capacity. Does 4 minutes of hover use this much power? I have been reading RCG posts where guys are getting much longer flight times on 2200 mA.
Piper J3 is offline Find More Posts by Piper J3
Old Nov 21, 2010, 11:54 AM
pmackenzie's Avatar
Joined Dec 2002
It all depends on head speed, but my HK450 at ~2850 rpm uses about 1800 mahr in 7:30.
Pat MacKenzie
Old Nov 21, 2010, 12:37 PM
rishalkant is offline
Find More Posts by rishalkant
Joined Nov 2010
Originally Posted by pitchp View Post
what's your Throttle Curve?
N Mode Curve:
S1 Mode Curve:
thanks for ur reply
y t. curve is
n mode S curve
L 0% 100%
2 25% 85%
3 50% 75%
4 75% 85%
h 100% 100%
let me know
thansk
rishalkant is offline Find More Posts by rishalkant
Old Nov 21, 2010, 12:45 PM
Joined Nov 2010
Originally Posted by pmackenzie View Post
I wonder if the one-way bearing might be backwards?
But I agree, definitely remove the main and tail blades while you try to figure it out.
Pat MacKenzie
hi which bearing are u taking about
let me know and i ll let u know it is set
thanks for replying
Old Nov 21, 2010, 12:53 PM
pmackenzie's Avatar
Joined Dec 2002
There is a bearing in the main gear that lets the motor drive the main shaft but not the main shaft drive the motor.
If you turn the main rotor forward/clockwise (looking from the top) by hand the motor should not spin.
If you turn the main rotor backwards/counter clockwise then the motor should spin.
Pat MacKenzie
Old Nov 21, 2010, 01:01 PM
Piper J3 is offline
Piper J3's Avatar
Hinckley, Ohio
Joined Nov 2008
Pat MacKenzie
I measured head speed at 2540 so I wonder what the problem is. I have three HK Nano 2200's and they all exibit 70% usage @ 4 minutes. LiPo and motor run cool and ESC runs hot. All rotating mechanics are free.
Old Nov 21, 2010, 01:08 PM
pmackenzie's Avatar
Joined Dec 2002
What motor and pinion? What ESC?
If you are using throttle to keep the headspeed down then it would be better to put a smaller pinion on.
Pat MacKenzie
Old Nov 21, 2010, 01:22 PM
Piper J3 is offline
Piper J3's Avatar
Hinckley, Ohio
Joined Nov 2008
Pat MacKenzie
Mtr - OBL 29/37-10H
ESC - Ace BLC-40
Head speed = 2540
AUW = 860 grams
Also, I'm running cheap wood blades if that factors in...
Machine is well balanced and smooth on run-up and in the air.
I'm thinking this machine is heavier than a Trex by about 100 grams which could easily explain shorter run times.
LiPo and motor run cool, but ESC gets pretty hot.
Thanks for your help.
Piper J3
Old Nov 21, 2010, 01:33 PM
Joined Nov 2010
Pat MacKenzie
Yes i checked it and the motor spins only if i move my main rotor backwards
but if i go forward then the motor will not spin
here is the motor i am using
Turnigy E500 6T 4000Kv 200W Heli Motor
from hobbyking
http://hobbyking.com/hobbyking/store...idProduct=6316
i was reading the feedback on this motor and some people complained that the motor requires more than 200watts as stated in the decription and some people also stated that this motor requires a stronger esc
so u think that would be the problem
thanks
Old Nov 21, 2010, 02:17 PM
sp00fman is offline
Find More Posts by sp00fman
Looptastic!
sp00fman's Avatar
Enschede, Netherlands
Joined Nov 2009
Originally Posted by Piper J3 View Post
Mtr - OBL 29/37-10H
ESC - Ace BLC-40
Head speed = 2540
AUW = 860 grams
Piper J3
Make 100% sure the blades track properly. a few hours ago i got back from tracking the blades on my night bird. At first it could barely stay in the air inverted, and with only one correct turn on the main grip link it felt like a rocket again. It weights 900g and i can squeeze 5 mins out of a pack and charge about 1700mAh back
sp00fman is offline Find More Posts by sp00fman
Old Nov 21, 2010, 03:00 PM
Joined Nov 2010
[QUOTE=pmackenzie;16610819]What motor and pinion? What ESC?
i listed the link to my motor on previous post and i am using a 13t pinion
thanks
Old Nov 21, 2010, 03:03 PM
pmackenzie's Avatar
Joined Dec 2002
Try an 11 tooth pinion.
It would be a better match to your motor and head speed.
Pat MacKenzie
Old Nov 21, 2010, 03:07 PM
Joined Nov 2010
[QUOTE=pmackenzie;16611626]Try an 11 tooth pinion.
Actually i did and same thing
do u think my motor might be defective cause my first ESC was defective
also i plugged a 50a esc and all the servos start shaking by them self it even has the BEC but still all the servos shake
and the 50a ESC will not beep when i try to set the throttle range
let me know
thanks
Old Nov 22, 2010, 01:55 AM
Harrow is offline
Find More Posts by Harrow
Yes, I know it's upside down.
Sydney, Australia
Joined Dec 2008
+1. When I did my first HK450 build, I was only getting 2 minutes of hover. I had not even heard of blade tracking at that time, and it was out by quite a bit. Sounded really cool in the air though.
Harrow is offline Find More Posts by Harrow
Help! HK 450 or HK 600 kilo2018 Beginner Training Area (Heli-Electric) 29 Apr 19, 2016 03:56 AM
Discussion 450 HK with Futaba EX radio and 3114 FASST servos SLOPPY? PaulGT3 Mini Helis 9 Sep 02, 2013 05:10 PM
Sold HK 450 head/tail/frame/canopy/motor - $20 shipped RobDog Aircraft - Electric - Helis (FS/W) 5 Nov 09, 2010 10:07 AM
Discussion Vendo HK 450 com Radio HK 7canais baratoooo !!! nino_sdk Brazil 0 Jul 26, 2010 08:42 PM
For Sale hk 450, exi 450 or copterx 450 HeliStyle Aircraft - Electric - Helis (FS/W) 5 May 15, 2010 11:57 AM
