Old Nov 20, 2010, 11:29 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Originally Posted by Wade1 View Post
So could a warped main gear cause a bit of vibrations ? All of the main gears I have bought (from Hobbyking) are slightly out of round. would this upset the tail at all ?
It shouldnt to much. The align gears a a bit warped too
losifanatic is offline Find More Posts by losifanatic
Old Nov 20, 2010, 11:39 PM
pitchp is offline
Find More Posts by pitchp
No Longer Active
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
my v1 is warped badly, no vibes my metal version slight warped, no vibes. you're not having the same problems as losi are you?
pitchp is offline Find More Posts by pitchp
Old Nov 21, 2010, 12:07 AM
Wade1 is offline
Find More Posts by Wade1
Australia
Joined Jul 2008
it looks just like losi's but no where near as bad as that.im waiting for a nice day to get some footage outside rather than in my living room like I have been. I need to get closer to the heli so you can actually see the vibes.
someone in a previous post said it looks "nervous". Thats a perfect way of saying what mine looks like.
Wade1 is offline Find More Posts by Wade1
Old Nov 21, 2010, 12:34 AM
pitchp is offline
No Longer Active
pitchp's Avatar
Joined Aug 2010
yep sounds similar
Old Nov 21, 2010, 03:16 AM
sandos is offline
Find More Posts by sandos
Sweden
Joined Jan 2010
Originally Posted by losifanatic View Post
Here is a vid of the tail acting weird. The servo as long as the gyro is perfect moves smoothly but the gyro is super sensitive right now
http://www.youtube.com/watch?v=V_UIX32iKnk
I don't think the behaviour is that weird: The gyro is loose and free to vibrate, AND the servo is moving. I am guessing the servo movement is transmitted through the heli, making the gyro move, which in turn makes it react again. It seemed to calm down when you held it!
sandos is offline Find More Posts by sandos
Old Nov 21, 2010, 03:34 AM
sp00fman is offline
Find More Posts by sp00fman
Looptastic!
sp00fman's Avatar
Enschede, Netherlands
Joined Nov 2009
Originally Posted by pitchp View Post
I'm trying to make custom skids, real beefy skids like a gorilla skids, but with my own flare. I have the skeleton skids(plastic), I would like to paste something over it, but I'm not sure what I can use. I need something light and reinforce my skeleton skids, and that will mold easily, and cure with in 2-3 days. Any ideas what I can use?
Have you seen my coathanger skids? They ware proven indestructible :P
sp00fman is offline Find More Posts by sp00fman
Old Nov 21, 2010, 03:49 AM
sandos is offline
Sweden
Joined Jan 2010
Ive been thinking about making snow-skids now that winter is here...
This has got have been done before, right?
Old Nov 21, 2010, 03:54 AM
Harrow is offline
Find More Posts by Harrow
Yes, I know it's upside down.
Sydney, Australia
Joined Dec 2008
Subscribed. (wondered why you guys had all gone quiet for so long!)
Harrow is offline Find More Posts by Harrow
Old Nov 21, 2010, 04:36 AM
Harrow is offline
Sydney, Australia
Joined Dec 2008
Originally Posted by rishalkant View Post
I am new and building my first heli which is hk450 v2
i got everything installed and when i move my throttle to full the blades never spin fast enough to take off
my battery is fully charged
heres is my setup
Turnigy 2200mAh 3S 25C Lipo Pack
HK450V2 HK450 CCPM 3D Helicopter Kit (Align T-rex Co
4 hxt900
Turnigy E500 6T 4000Kv 200W Heli Motor
Hobby King 401B AVCS Digital Head Lock Gyro
please let me know
if u have any solutions
thanks
Hmm, something fundamentally wrong here as your blades are barely turning at all.
I think you need to first reprogram the high and low throttle points in your ESC as a starting point. (unplug battery, turn tx on and set throttle to full, plug battery into heli, after a confirmation beep from ESC, move throttle to low, and should then get some sort of confirmation tune.)
You then need to make sure your throttle curve is right. You sound like you have been playing with the throttle trim. Set the throttle trim back to zero, and check that your throttle curve has 0 at the first point, and 100 at the last point. (Actually, make sure you have the thottle curve correct before reprogramming the throttle points on the ESC.)
Probably a good idea to remove the heli blades when you try all this.
Let us know how you go.
Old Nov 21, 2010, 08:03 AM
pmackenzie is online now
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
I wonder if the one-way bearing might be backwards?
But I agree, definitely remove the main and tail blades while you try to figure it out.
Pat MacKenzie
pmackenzie is online now Find More Posts by pmackenzie
Old Nov 21, 2010, 08:23 AM
frac is offline
Find More Posts by frac
anarchist
frac's Avatar
Pat MacKenzie
how exactly do you do that??
probably a broken or uninstalled shear bolt, top or bottom, or the pinion/main gear mesh
frac is offline Find More Posts by frac
Old Nov 21, 2010, 08:28 AM
sp00fman is offline
Looptastic!
sp00fman's Avatar
Joined Nov 2009
I did while learning in the beginning of this year. I halved a piece of foam-tube and ziptied it under my skids. Combined with the training gear it held nicely
(the stuff you can put around metal pipes of radiators to prevent heat loss)
$1 solution
You also need something on the bottom of the vertical tail fin to prevent it ditching in the snow.
Old Nov 21, 2010, 08:43 AM
Magic k2 is offline
Find More Posts by Magic k2
Things that do fly
Magic k2's Avatar
In my house ;-) The uk
Joined Dec 2008
i have seen inflatable booms that connect onto the skids so you can land on snow or water,seen them on youtube and they were bright orange,was maybe nightflyer.
Magic k2 is offline Find More Posts by Magic k2
Old Nov 21, 2010, 09:31 AM
frac is offline
anarchist
frac's Avatar
the air tube/pillow packing from HC orders is good for that
Old Nov 21, 2010, 09:42 AM
frac is offline
anarchist
frac's Avatar
washout arms
i've received these and i'm waiting on these
the ones i have seem very solid, i'm wondering if there is any difference between those and the V2 arms besides the color? anybody try both?
Help! HK 450 or HK 600 kilo2018 Beginner Training Area (Heli-Electric) 27 Dec 24, 2015 06:02 PM
Discussion 450 HK with Futaba EX radio and 3114 FASST servos SLOPPY? PaulGT3 Mini Helis 9 Sep 02, 2013 06:10 PM
Sold HK 450 head/tail/frame/canopy/motor - $20 shipped RobDog Aircraft - Electric - Helis (FS/W) 5 Nov 09, 2010 11:07 AM
Discussion Vendo HK 450 com Radio HK 7canais baratoooo !!! nino_sdk Brazil 0 Jul 26, 2010 09:42 PM
For Sale hk 450, exi 450 or copterx 450 HeliStyle Aircraft - Electric - Helis (FS/W) 5 May 15, 2010 12:57 PM
