Old Nov 20, 2010, 12:18 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
shacking tail???
OK changed motor, changed swash plate, and changed flybarcage. Shake is still there and still just as bad as it has been??? There is very little vibs in the heli when I hold it in my hand and spin her up. The only thing left to change is the gyro. Gosh I hope the quark isn't messed up. Guess I will be buying a new gyro soon to find out If the gyro is good its going on the second heli The scorpion is going on it now since I took it out of heli #1.
losifanatic is offline Find More Posts by losifanatic
Old Nov 20, 2010, 12:46 PM
Magic k2 is offline
Find More Posts by Magic k2
Things that do fly
Magic k2's Avatar
In my house ;-) The uk
Joined Dec 2008
You can just bypass the gyro to test,is your flybar centered ?measure from head to each paddle?bent or wonkey gear ?
Magic k2 is offline Find More Posts by Magic k2
Old Nov 20, 2010, 12:57 PM
Sippin the Koolaid!
Joined Oct 2007
My tail servo is a narrow band width servo so I can not bypass the gyro or test with my dectrum gyro.
Its a new flybar(I put on this morning with the cage) and new paddles that I bought after the crash. I put the bar on and centered it(useing a digital caliper) and then put eh paddles on useing the caliper too.
I might just send the gyro back to spartan to have it checked out. I would be without a heli for a while but it might be worth it as I am trying to put together a 72inch 3dhs extra 330 and thats where all my money is going(and christmas for the wife and kids)
Old Nov 20, 2010, 01:18 PM
Magic k2 is offline
Things that do fly
Magic k2's Avatar
Joined Dec 2008
you must have an old servo hanging around somwhere? pop it on to test without the gyro ,any junk will do
Old Nov 20, 2010, 01:35 PM
Sippin the Koolaid!
Joined Oct 2007
It has to be digital to work with the quark. Now I unhooked the gyro and from the heli. Howly caw While holding it the tail servo goes nuts. I let go if the servo and just let it sit there and it still goes nuts. Any minut movement causes crazy tail servo twitch. I have a small vid of it but I have to load it
Old Nov 20, 2010, 02:09 PM
Sippin the Koolaid!
Joined Oct 2007
Here is a vid of the tail acting weird. The servo as long as the gyro is perfect moves smoothly but the gyro is super sensitive right now
http://www.youtube.com/watch?v=V_UIX32iKnk
Old Nov 20, 2010, 04:01 PM
sp00fman is offline
Find More Posts by sp00fman
Looptastic!
sp00fman's Avatar
Enschede, Netherlands
Joined Nov 2009
Omg... that can't be good..
I had a jittering tail servo once, and sounded just like that! It Jitteredd only in rate mode, not in HH. Very odd.
Later found out it was the servo output gear loose on the Potentiometer shaft inside the servo. Pretty easy fix.
sp00fman is offline Find More Posts by sp00fman
Old Nov 20, 2010, 05:34 PM
Magic k2 is offline
Things that do fly
Magic k2's Avatar
Joined Dec 2008
Check all your wires,,not in nots or coils,,is that antenna touching something ?cf or metal?connect the gyro output to one of the other servos on the heli to test also
Old Nov 20, 2010, 05:42 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
It looks like the gain is at 100%. When the gyro is sitting free it loses the damping that the mass of the heli gives, so the servo gets quite "nervous".
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Nov 20, 2010, 07:24 PM
rishalkant is offline
Find More Posts by rishalkant
Joined Nov 2010
need help with HK450 blades not spinning fast enough
I am new and building my first heli which is hk450 v2
i got everything installed and when i move my throttle to full the blades never spin fast enough to take off
Here is the video which shows it
Trex 450 clone hk 450 need help (1 min 15 sec)
my battery is fully charged
heres is my setup
Turnigy 2200mAh 3S 25C Lipo Pack
HK450V2 HK450 CCPM 3D Helicopter Kit (Align T-rex Co
4 hxt900
Turnigy E500 6T 4000Kv 200W Heli Motor
Hobby King 401B AVCS Digital Head Lock Gyro
please let me know
if u have any solutions
thanks
rishalkant is offline Find More Posts by rishalkant
Old Nov 20, 2010, 08:05 PM
pitchp is offline
Find More Posts by pitchp
Retired
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
http://www.youtube.com/watch?v=_MVclHPXzyw
heres is my setup
4 hxt900
please let me know
thanks
what's your Throttle Curve?
N Mode Curve:
S1 Mode Curve:
pitchp is offline Find More Posts by pitchp
Old Nov 20, 2010, 08:09 PM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
I'm trying to make custom skids, real beefy skids like a gorilla skids, but with my own flare. I have the skeleton skids(plastic), I would like to paste something over it, but I'm not sure what I can use. I need something light and reinforce my skeleton skids, and that will mold easily, and cure with in 2-3 days. Any ideas what I can use?
Old Nov 20, 2010, 09:02 PM
rocketscience is offline
Find More Posts by rocketscience
Not a six pack
rocketscience's Avatar
USA, IL, Chicago
Joined Jul 2008
heres is my setup
4 hxt900
please let me know
thanks
Did you do a throttle range on the ESC?
For most HK ESCs (check instructions for yours!!)
Make your throttle curve have 0 for low and 100 for high in normal mode. The other points in between can be anything.
unplug battery, turn on tx, turn throttle hold off (so motor is engaged).
throttle to max.
plug in battery.
you will hear a confirmation beep - typically 2 beeps.
reduce throttle to min.
you will hear the normal 3 beeps for a 3 cell battery.
you can now test throttle. re-adjust your max point to whatever you want it to be.
again check the steps for YOUR esc. might want to try this without blades.
rocketscience is offline Find More Posts by rocketscience
Old Nov 20, 2010, 09:34 PM
Sippin the Koolaid!
Joined Oct 2007
I am going to pull the savok servo off the other heli to see if the shack goes away
Old Nov 20, 2010, 10:25 PM
Wade1 is offline
Find More Posts by Wade1
Australia
Joined Jul 2008
So could a warped main gear cause a bit of vibrations ? All of the main gears I have bought (from Hobbyking) are slightly out of round. would this upset the tail at all ?
Wade1 is offline Find More Posts by Wade1
Help! HK 450 or HK 600 kilo2018 Beginner Training Area (Heli-Electric) 29 Apr 19, 2016 03:56 AM
Discussion 450 HK with Futaba EX radio and 3114 FASST servos SLOPPY? PaulGT3 Mini Helis 9 Sep 02, 2013 05:10 PM
Sold HK 450 head/tail/frame/canopy/motor - $20 shipped RobDog Aircraft - Electric - Helis (FS/W) 5 Nov 09, 2010 10:07 AM
Discussion Vendo HK 450 com Radio HK 7canais baratoooo !!! nino_sdk Brazil 0 Jul 26, 2010 08:42 PM
For Sale hk 450, exi 450 or copterx 450 HeliStyle Aircraft - Electric - Helis (FS/W) 5 May 15, 2010 11:57 AM
