Old Nov 09, 2010, 03:51 PM
jombo is offline
Find More Posts by jombo
Bad News Everyone
jombo's Avatar
United States, CT, Trumbull
Joined Dec 2007
Originally Posted by Magic k2 View Post
There was cake but it went quite fast
yep, it was ice cream cake with extra crunchies so who has one of these fancy flying machines is this new
jombo is offline Find More Posts by jombo
Old Nov 09, 2010, 03:53 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Ice cream cake is my fav. Im always late to the party.
I picked up one of those flying thingies but dont know how it works
losifanatic is offline Find More Posts by losifanatic
Old Nov 09, 2010, 04:03 PM
Barak1001 is offline
Find More Posts by Barak1001
Resident Skeptican
Barak1001's Avatar
USA, AL, Hanceville
Joined May 2008
The problem is with how SQL (the database that handles these threads) parses large threads.
They are having all of the threads that are hundreds of pages long closed to keep seek times down on the server. I'm honestly surprised they hadn't done it before now.
Barak1001 is offline Find More Posts by Barak1001
Old Nov 09, 2010, 04:06 PM
Sippin the Koolaid!
Joined Oct 2007
The 3dhobbyshop addict thread part 2 had 29,000 posts in less than year. That was a big thread (sad thing is that I have read every page) That thread was closed yeasterday and the part 3 already has 16 pages. There was and is some monster sized threads in here
Old Nov 09, 2010, 04:54 PM
n00b-E is offline
Find More Posts by n00b-E
n00b-E's Avatar
Joined Sep 2007
Subscribed...............again
n00b-E is offline Find More Posts by n00b-E
Old Nov 09, 2010, 05:24 PM
whiskykid is online now
Find More Posts by whiskykid
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
thanks guys! I'm gonna put that darkhorse calc. in my fav's
will hafta check inta weight of the batts,but sense I plan on using zippy flitemax the cost shouldn't realy add that much.
here is my shopping list so far,keep in mind,I'll be adding 2 are 3 more servo's,and a few more sets of blades,just havn't figured out how ta do that on my wish list!
http://www.hobbyking.com/hobbyking/s...ustomer=194802
keep them spinnin! thank's new heli addic, only took one good hover! the Kid!
whiskykid is online now Find More Posts by whiskykid
Old Nov 09, 2010, 05:38 PM
Resident Skeptican
Barak1001's Avatar
USA, AL, Hanceville
Joined May 2008
The issue with using a 4s is weight, generally they are much heavier than a 3s that will fly as long.
This means that with a 4s you'll wind up having to add weight to the tail (literally weights of some type) in order to correct the center of gravity for the helicopter.
3s 2650 mah are about the largest batteries you're going to want to use on your helicopter. With a 212 gram battery (weight of the 2650) you'll wind up having to be extremely creative with mounting your electronics to get it to balance.
With the Flightmax 3s 2200mah 25c that most people use they are the perfect weight to balance the chopper out.
Old Nov 09, 2010, 05:40 PM
Sippin the Koolaid!
Joined Oct 2007
Mine balanced perfectly with a 202gram 2200 55C lipo on the nose(its the pro vesion)
Old Nov 09, 2010, 05:52 PM
team sleprock
whiskykid's Avatar
Joined Dec 2009
http://www.hobbycity.com/hobbycity/s...idProduct=9162
oh well, was a thought,will b using this batt. in my jets,and at almost 250 grms,looks like 3s and some more batt.s
sry I didnt have any 2200 3s batts .ta compare,thanks for the info on that!
I guess I should add some 450 size traing gear to my list! DUH!
Old Nov 09, 2010, 06:00 PM
sp00fman is offline
Find More Posts by sp00fman
Looptastic!
sp00fman's Avatar
Enschede, Netherlands
Joined Nov 2009
try to avoid back-ordered parts, it can get annoying.
For the tail servo i had good luck with a clone 9257 servo, and this might be comparable: http://www.hobbycity.com/hobbyking/s...dproduct=13422
shame its also on backorder.
Edit: turned out to be a bad idea. The gotec is not riliable
sp00fman is offline Find More Posts by sp00fman
Old Nov 09, 2010, 06:02 PM
Resident Skeptican
Barak1001's Avatar
USA, AL, Hanceville
Joined May 2008
I've got a CF boom and stabilizers, with my current setup I have to put the battery as far up as it can go on the tray in order to balance out. That's with a Flightmax 3s 2200 25c that weighs 179 grams if I remember right.
Old Nov 09, 2010, 06:18 PM
pastorJohn is offline
Find More Posts by pastorJohn
Lord, teach me pa... *crash*
pastorJohn's Avatar
USA, ME, Caribou
Joined Jun 2008
W00t. New thread.
I missed cake? I am sad. However, I am glad the thread didn't die.
Happy flying!
pastorJohn is offline Find More Posts by pastorJohn
Old Nov 09, 2010, 06:21 PM
rocketscience is online now
Find More Posts by rocketscience
Not a six pack
rocketscience's Avatar
USA, IL, Chicago
Joined Jul 2008
Originally Posted by whiskykid View Post
can I just change the Kv on the motor,and drive gear, will it make this lil heli even more twitchy, too heavy.
correct me if I'm wrong! but won't lower Kv with higher volt's,just make more tourqe!
I've read though so many posts and threads,I do remember a couple guys,had used 4s,but can't remember why,are what the result was!
thanks the Kid
P.s. I will be getting the HK450MT
4s 2200 (stretched)
other info (blog)
If you stick with the 325mm blades, then 1800ma 4S. On a v2 with a Mini servo on the tail, I can push the battery about 1/2" farther back before it touches the frame. Flight times are great.
rocketscience is online now Find More Posts by rocketscience
Old Nov 09, 2010, 06:42 PM
team sleprock
whiskykid's Avatar
Joined Dec 2009
Rocketscience! wether are not I go 4s, thats some good info thank you!
ok I hafta ask,was it the heli? are your flying style, cuase that looked super smooth!
Old Nov 09, 2010, 07:18 PM
rikybob is offline
Find More Posts by rikybob
AMA # 949551
rikybob's Avatar
USA, FL, Orlando
Joined Oct 2009
I love the 2215! Also the 401B "Cyro" (look closely at the picture) is cool too!
b
rikybob is offline Find More Posts by rikybob
Help! HK 450 or HK 600 kilo2018 Beginner Training Area (Heli-Electric) 27 Dec 24, 2015 06:02 PM
Discussion 450 HK with Futaba EX radio and 3114 FASST servos SLOPPY? PaulGT3 Mini Helis 9 Sep 02, 2013 06:10 PM
Sold HK 450 head/tail/frame/canopy/motor - $20 shipped RobDog Aircraft - Electric - Helis (FS/W) 5 Nov 09, 2010 11:07 AM
Discussion Vendo HK 450 com Radio HK 7canais baratoooo !!! nino_sdk Brazil 0 Jul 26, 2010 09:42 PM
For Sale hk 450, exi 450 or copterx 450 HeliStyle Aircraft - Electric - Helis (FS/W) 5 May 15, 2010 12:57 PM
