Old Nov 17, 2010, 12:25 AM
sandos is offline
Find More Posts by sandos
Sweden
Joined Jan 2010
Originally Posted by Wade1 View Post
Hey guys,
what does it mean when you are hovering, and apply some left (or right) rudder, and when you let go of the rudder stick, the heli slowly points back to where it was before applying the rudder.
is this a gyro problem or tail slider problem???
Sounds like youre using a HK401B. I had the exact same sort of problems. They did get a lot better when setting up in rate mode, I think.
sandos is offline Find More Posts by sandos
Old Nov 17, 2010, 12:51 AM
pitchp is offline
Find More Posts by pitchp
Retired
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
hmm I am so tempted in trying these, I've heard so much about them
http://www.hobbyking.com/hobbyking/s...dProduct=11943
and it comes with an XT60 connector, which is so ideal now for me.
pitchp is offline Find More Posts by pitchp
Old Nov 17, 2010, 01:23 AM
bymannan is offline
Find More Posts by bymannan
Joined Aug 2010
How much time will it take to charge these in 8C?
bymannan is offline Find More Posts by bymannan
Old Nov 17, 2010, 01:32 AM
mikehoppett is offline
Find More Posts by mikehoppett
Joined May 2009
Orange Rx Hobby King....
FWIW... I bought 1 orange Rx to check it out...cost $18 or £12 delivered.....Same price as a previous Ebay AR6100 clone which has misbehaved on occasion and is very hard to bind... So fitted orange rx to my HK450 and set it up...V. quick bind/ Range test 30 paces no problem /a week of flying no problems so far.... just went back to HK and lo and behold $8 for Orange Rx /I bought 4 as that gave best price including shipping of $8.75 each or £5.50 ish...Bloody amazing!
so I will take my Genuine AR6200 and AR500 and AR6100s out of their existing Foam edf jets and Stunt planes etc.. and stick the El cheapo in those while putting the tested /Authentic/expensive Rxs in the HK500GT and other New expensive stuff I am building.....RESULT!
( DX6i is great no problems in 2 years..)
(Dx5e lots of problems!)
Cheers Mike H.
mikehoppett is offline Find More Posts by mikehoppett
Old Nov 17, 2010, 01:42 AM
sandos is offline
Sweden
Joined Jan 2010
(Thats a 2S btw)
What exactly have you heard? My 35C was kinda bad (balloned, gotten rid of after 20 flights. I did crash with it pretty bad once though, but the punch wasnt great even before), my 45C is kinda bad.
YMMW of course, my samplesize is only 1 of each.
Old Nov 17, 2010, 02:18 AM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
Originally Posted by sandos View Post
(Thats a 2S btw)
i hear a lot of people saying nano techs are good. I'm really tempted in trying one. well after reading your post, i don't know any more
Old Nov 17, 2010, 02:19 AM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
better talk to sandos, I don't have them
Old Nov 17, 2010, 02:21 AM
sandos is offline
Sweden
Joined Jan 2010
I can only charge at 10A which is <5C and that usually takes much less than 15m. Maybe 10m normally, including balancing. This is from storage charge though.
Old Nov 17, 2010, 02:30 AM
beenflying is offline
Find More Posts by beenflying
as much as I can
beenflying's Avatar
NZ
Joined Jan 2010
The Nanotech's aren't as good as the standard Turnigy Lipo's of the same C rating. The 45C Nanotech's aren't even as good as the standard 40C Lipo's. I won't be buying any more Nanotech's until I hear or some improvement.
beenflying is offline Find More Posts by beenflying
Old Nov 17, 2010, 02:32 AM
bymannan is offline
Joined Aug 2010
That's nice, so with your car near by you can fly all day Maybe I should also get a more serious charger. Something like this will do:
http://www.hobbycity.com/hobbyking/s...dProduct=10382
Old Nov 17, 2010, 02:40 AM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
wow just aswell I asked here first. thanks guys
Old Nov 17, 2010, 06:05 AM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Originally Posted by topgearuk View Post
The 1st 3 are correct 250, 400 and 450 were all originally based on motor size, however the 500, 550, 600 and 700 heli's are all based on blade size.
The mini Titan 325, is based on blade size which makes it the same size as a trex 450!!
A doesnt a 500 use 425mm blades? not 500mm
EDIT:
Info from xheli site for a 500
Mini servo (3)
Head lock gyro
Specialized Tail Servo
Pitch gauge
60A Brushless ESC
500 size Brushless motor (1600KV)
22.2V 6S Li-Poly 2100~2500mAh battery
425mm main blade
So I think the 500 was based on a 500 size motor
losifanatic is offline Find More Posts by losifanatic
Old Nov 17, 2010, 07:06 AM
jombo is offline
Find More Posts by jombo
Bad News Everyone
jombo's Avatar
United States, CT, Trumbull
Joined Dec 2007
Didn't you had similar gyro problems with your 250??
yep i still do , the problem i am having right now is in rate mode it is pretty solid and i get no drift. in HH mode with the red light on i still get a little tail wag/ drift . i have been reading about this problem and it seems to be with the tail blades being too long by 3mm, and the servo set at 3 to 5 mm from the center screw. since my pinion on the 250 came loose and i red loctited it yesterday i am going to try the tail servo first at 5 mm from center first. if i still get some wag then i may cut my tail blades down a mm at a time . the other solution was to lower the throttle curve , i did that but it flew ok but to hover i was almost at full throttle . i also want to change my tail blades to the K/B dream design 250 blades , that also will help .
jombo is offline Find More Posts by jombo
Old Nov 17, 2010, 07:08 AM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
EDIT:
with the exeption from the gaui X5
Old Nov 17, 2010, 07:14 AM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
jombo: you get two tailblades with the 250. The batman and the rectangular one. Try with the rectangular one, but sand the leading edge part to be flat. Try to make an even sanding on both sides. I'm using that on my plastic 250, and it had no wag, with the mystery gyrd gyro and esky 8g servo. The only problem that I get is initialisation every now and then, for which i perform the flick switch gear trick x3, and that temporarily fixes my problem other than that, no bounce. Also do you have a tacho? Try to see if you can tach your heli for your HS, at 100% and one at 85%, if none of this works, just wait for the new mems gyro from assan($15 and it's only 8g!!). I am so glad to see the fbl taking a big market in the heli industry, it's definately driving the prices down for these gyros.
Help! HK 450 or HK 600 kilo2018 Beginner Training Area (Heli-Electric) 29 Apr 19, 2016 03:56 AM
Discussion 450 HK with Futaba EX radio and 3114 FASST servos SLOPPY? PaulGT3 Mini Helis 9 Sep 02, 2013 05:10 PM
Sold HK 450 head/tail/frame/canopy/motor - $20 shipped RobDog Aircraft - Electric - Helis (FS/W) 5 Nov 09, 2010 10:07 AM
Discussion Vendo HK 450 com Radio HK 7canais baratoooo !!! nino_sdk Brazil 0 Jul 26, 2010 08:42 PM
For Sale hk 450, exi 450 or copterx 450 HeliStyle Aircraft - Electric - Helis (FS/W) 5 May 15, 2010 11:57 AM
