Old Mar 18, 2011, 07:36 AM
Magic k2 is offline
Find More Posts by Magic k2
Things that do fly
Magic k2's Avatar
In my house ;-) The uk
Joined Dec 2008
Originally Posted by Wade1 View Post
So I changed the 11t pinion with a 13t pinion. and it seems WAY louder. but still no lift.
throttle curve is 0, 17.5, 40, 70, 100. I know those numbers are all over the place but I just put something in that would get it off the ground.
pitch is 40, 45, 50, 75, 100.
blades are set at -4, 0, +9
Hit throttle hold so it doesnt spin up and hit the throttle,do the blades pitch up? how far? next is are the blades the correct way around and spinning the right direction? i know you changed the motor so could be spinning wrong way,also ,try setting thr curve to 40,100,100,100 100 just to try,,,oh i did say before but does the ESC have a govonor that is holding the head speed down?
Magic k2 is offline Find More Posts by Magic k2
Old Mar 18, 2011, 07:51 AM
Wade1 is offline
Find More Posts by Wade1
Australia
Joined Jul 2008
I have disconnected the motor and moved the throttle stick up and yes, the blades pitch up to +9 degrees.
As far as the blades being the correct way....I think so ? the tail is spinning the correct way so I assume it is.
ESC doesnt have govenor.
It is in a scale fuselage so putting the belt around the cog at the front of the tail boom was pretty hard. if the belt is twisted the wrong way around the pulley, could that cause this problem ? even tho the blades seem to be spinning the right way ?
Wade1 is offline Find More Posts by Wade1
Old Mar 18, 2011, 08:42 AM
sh4nce is offline
Find More Posts by sh4nce
sh4nce's Avatar
BelgiŽ, Brussel, Brussel
Joined Nov 2010
main rotors should go clockwise while tail ccw. The tail driven badly would only result in a non steady tail I guess. Shouldn't stop the main rotor from working. Unless it has insane friction slowing it down?
Also check that rotors are pointing the right way. Yesterday mine was hopping around because I had one rotor mounted the wrong way
sh4nce is offline Find More Posts by sh4nce
Old Mar 18, 2011, 09:50 AM
rocketscience is offline
Find More Posts by rocketscience
Not a six pack
rocketscience's Avatar
USA, IL, Chicago
Joined Jul 2008
According to the dark horse headspeed calc, 2500kv on 13t is still just 2200 rpm. With a fuselage on there and 9 degrees of pitch.. I don't know. I think you need 2600-2800 rpm just to take off. Either that or 11 degrees pitch maybe. But I have never done scale so I'm no expert on the effects of weight from the fuse. Just curious, what made you get that motor?
I used to run the 2218 (red/silver) 2500kv motor too on 13t but with 4S. Which according to the calc gets you 3000rpm headspeed. And even that was with 12 degrees pitch.
rocketscience is offline Find More Posts by rocketscience
Old Mar 18, 2011, 11:51 AM
porqui is offline
Find More Posts by porqui
Fly Safe !!
Cape Town
Joined Jul 2007
Wade google Finless Bob and look at his video's on setting up you head and curves and pitches etc as with your combination and settings you are never going to get the heli in the air.
Those videos are really good and will help you to understand the whole concept of setting up for flight.Most here on rcg have gone through them - download all of them and keep them and study them.
porqui is offline Find More Posts by porqui
Old Mar 18, 2011, 01:03 PM
2Doggs is offline
Find More Posts by 2Doggs
Two helis flying
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
I've messed around with governor mode on my HK 560 Pro, and I've had it hovering at 2200, using somewhere around +7 pitch, and my 450 weighs in at about 850g. What does yours weigh with the scale body?
Wade, your throttle curves aren't too far out - but you could change them to 0,60, 70, 80, 90, 100. If it's still not lifting off the ground, increase the swash pitch mix.
With the stock dampers, my 450 "nods" at anything below about 2400, though, so maybe you will have to try a 14t pinion.
2Doggs is offline Find More Posts by 2Doggs
Old Mar 18, 2011, 05:22 PM
Wade1 is offline
Australia
Joined Jul 2008
The reason I got this motor is because I thought for scale applications, a lower kv was better.
Will adjust pitch and throttle and report back.
Thanks guys !
Old Mar 18, 2011, 06:47 PM
bbking9 is offline
Find More Posts by bbking9
Plano, TX
Joined Feb 2007
Wade in your Swash Mix - change the "+" numbers to "-" numbers - that should get you lifted off the ground. So go from say +60 to -60.
bbking9 is offline Find More Posts by bbking9
Old Mar 18, 2011, 09:05 PM
krefi is offline
Find More Posts by krefi
rather fly, but this'll do
krefi's Avatar
Portland, OR
Joined Feb 2008
Did y'alls kits come with washers for mounting the servos, or did you find your own elsewhere?
krefi is offline Find More Posts by krefi
Old Mar 18, 2011, 10:46 PM
2Doggs is offline
Two helis flying
2Doggs's Avatar
Joined Nov 2009
no washers with either of my HK 450 Pros!
Old Mar 19, 2011, 10:19 PM
mountainsax is offline
Find More Posts by mountainsax
Fix, Fix, Fly, Fix, Fix, Fly
mountainsax's Avatar
Colorado
Joined Apr 2009
Hey guys, I just got the metal blade holders from HK for the V2 and I need a little help with assembly! There appear to be more parts than I know where to put them. Does anyone know of a diagram for assembly?
Ethan
mountainsax is offline Find More Posts by mountainsax
Old Mar 20, 2011, 02:53 AM
sh4nce is offline
sh4nce's Avatar
Joined Nov 2010
Ethan
Did you check the trex 450 manual? It has an exploded view of the head. You can google it or get from files section on HK product page.
Old Mar 20, 2011, 08:33 AM
Colorado
Joined Apr 2009
I have the Trex 450 V2 manual but the setup is different, or I am missing something. If I can't find something I'm sure I can figure it out!
Old Mar 20, 2011, 09:39 AM
fatalsync is offline
Find More Posts by fatalsync
The New Guy
fatalsync's Avatar
USA, TX, College Station
Joined Oct 2010
The confusing part about the setup image in the align manual is that it shows you both dampers but only one set of collar/washers/bearings.
fatalsync is offline Find More Posts by fatalsync
Old Mar 20, 2011, 12:00 PM
ghost2212 is offline
Find More Posts by ghost2212
Skint since 2000
ghost2212's Avatar
Reading, United Kingdom
Joined Oct 2008
Just Flew My HK450 with the Ga-250 gyro.
Got a couple of packs through my HK450 just doing nose in practice and some auto's from chest height and then on the last pack i did some nice fast forward circuits as seen in the video. I'm using the GA-250 gyro and it kicks out abit in pitch pumps though its not as bad as the hk401b. Also in the stall turns i would pull up in to the vertical and put rudder in and it felt like it was sticking. Then it would suddenly move and i'd end up coming out of it a bit wrong as you might be able to see in this video. It may just be me but further tests will be conducted to see
HK450 Flight 1 20-3-11 With ASSAN GA-250 (4 min 19 sec)
hope spring comes soon
Brett
ghost2212 is offline Find More Posts by ghost2212
Help! HK 450 or HK 600 kilo2018 Beginner Training Area (Heli-Electric) 29 Apr 19, 2016 03:56 AM
Discussion 450 HK with Futaba EX radio and 3114 FASST servos SLOPPY? PaulGT3 Mini Helis 9 Sep 02, 2013 05:10 PM
Sold HK 450 head/tail/frame/canopy/motor - $20 shipped RobDog Aircraft - Electric - Helis (FS/W) 5 Nov 09, 2010 10:07 AM
Discussion Vendo HK 450 com Radio HK 7canais baratoooo !!! nino_sdk Brazil 0 Jul 26, 2010 08:42 PM
For Sale hk 450, exi 450 or copterx 450 HeliStyle Aircraft - Electric - Helis (FS/W) 5 May 15, 2010 11:57 AM
