Espritmodel.com Heli Air
Old Feb 26, 2011, 02:30 AM
Fly Crash Fix Fly Crash Fix
Andy08's Avatar
Gisborne, New Zealand
Joined Jul 2008
Hi guys,
Im rebuilding after my last crash and was thinking of hotting it up a bit. What hobby king motor do you gour reccomend for a hot 3s setup? Im doing loops rolls and flips and am starting to want to chuck it about a bit harder. I have been running this one.
Hobby King have the Futaba GY520 Gyro back in stock if anyone was after one.
Andy
Andy08 is offline Find More Posts by Andy08
Old Feb 26, 2011, 05:23 AM
Oh, you mean WORKING planes...
Sydney, Australia
Joined Dec 2008
Andy, the 2218 is one option to step up from the 2215.
http://www.hobbyking.com/hobbyking/s...idProduct=9257
More power, but more battery drain.
Harrow is online now Find More Posts by Harrow
Old Feb 26, 2011, 11:47 AM
Looptastic!
sp00fman's Avatar
Enschede, Netherlands
Joined Nov 2009
Andy, what Lipo packs do you use? If your still on 20C a motor upgrade will do exactly.....nothing.
I like my 2627 motor a lot. it has a little more oomph on 30C+ packs than with the H2215 motor.
sp00fman is online now Find More Posts by sp00fman
Old Feb 26, 2011, 01:26 PM
Andy08's Avatar
Joined Jul 2008
Hi, Thanks. Have you run both motors? Im not sure I would motice the extra 100kva. Im happy with my headspeed I just dont want it to bog. I know I should watch my collective managment but I want to be able to slam it.
Hi, I run these 45c packs. Were you talking about this motor?
This is a bit off topic but I have also been watching this thread. A guys building a scale airwolf around a 700e. Working countermeasures, retractable guns, air brakes on the retracts, real cameras in the surveillance pods, hot pilots. very cool.
Old Feb 26, 2011, 02:26 PM
Things that do fly
Magic k2's Avatar
In my house ;-) The uk
Joined Dec 2008
If you want to bang the sticks hard just reduce the throws of the servos in the tx and it wont bog,,slam away
Magic k2 is offline Find More Posts by Magic k2
Old Feb 26, 2011, 03:32 PM
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
The larger motor should be capable of more torque. Torque is what you need to prevent loss of head speed.
You want the largest motor with the highest Kv and the smallest pinion to maximize torque and minimize head speed changes under load.
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Feb 26, 2011, 03:52 PM
Not a six pack
rocketscience's Avatar
USA, IL, Chicago
Joined Jul 2008
I have run both. As pmackenzie has alluded to, the difference in the motors is torque. the 2218 is larger and heavier and sucks more juice. I've gone through maybe 5 of the 2218s back when I was on 3S. various crashes, 1 started stuttering, 1 had the shaft just shear right off (in flight). but I still used them for their power. 12t or 13t. I used 13t.
rocketscience is offline Find More Posts by rocketscience
Old Feb 26, 2011, 05:32 PM
The New Guy
fatalsync's Avatar
USA, TX, College Station
Joined Oct 2010
Another weekend, another rewarding but frustrating flying session.
Rewarding - I went through the entire head and reset everything up again. Mixed out all the CCPM interaction and got the pitch straight on.
Frustrating - Despite my ample application of Loctite, the heli threw a tail grip. I had just bought a set of Pro grips to put on, but I didn't have the plastic control arm that the grip took with it... And, of course, the LHS doesn't have the part in either V2 or Pro.
I guess it's not a big deal, it's raining here now anyway, so my flying was pretty much done for the weekend.
fatalsync is offline Find More Posts by fatalsync
Old Feb 26, 2011, 05:38 PM
Andy08's Avatar
Joined Jul 2008
Pat MacKenzie
Im sold. Thanks guys.
Old Feb 27, 2011, 05:11 AM
Looptastic!
sp00fman's Avatar
Joined Nov 2009
Oh im sorry, that motor is on my 250. lol.
I have the typhoon H2215, and on my other 450 the 2836. I run it on a 13T pinion getting a little over 3000rpm with 100-93-85-93-100 throttle curve and about 12 degrees pitch. Its unboggable with my skillset.
http://www.hobbyking.com/hobbycity/s...idProduct=8137
i don t own the 2218, but i dont feel the need to upgrade ATM.
Old Feb 27, 2011, 05:29 AM
Telechat's Avatar
Paris, France
Joined Jan 2009
old elec setup still any good?
Hey guys,
I've had my Trex 450 kit laying around for a while and never built it (yet). I plan on using some 'old' electronic components:
-Gyro: Futaba GY-240
-Tail servo: Futaba S9650
-cyclic: HXT900
Am I good to go with these or do I need to upgrade with more up to date servos from HK?
I spotted a few servos that might be better:
gyro: http://www.hobbyking.com/hobbyking/s...dproduct=15318
tail servo: http://www.hobbyking.com/hobbyking/s...idproduct=5195
cyclic: http://www.hobbyking.com/hobbyking/s...idProduct=9446
Telechat is offline Find More Posts by Telechat
Old Feb 27, 2011, 07:23 AM
Looptastic!
sp00fman's Avatar
Joined Nov 2009
Just try them. you can always upgrade later on.
Old Feb 27, 2011, 12:00 PM
just gotta mess with it!
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
I use a 2218H in my HK 450 Pro, with a 13t pinion. I've seen it draw as much as 55A, so you need to watch your pitch range. I actually prefer to run it in governor mode at 2800 rpm for 7 minute flights. I'm waiting on a 12t pinion to try too, and funnily enough, a 2215 motor to see what kind of flight times I can eke out of the system. I would suggest that with a 2218H you need a minimum of 25c packs. My 2218H thru a noisy phase when spooling up, no matter what timing it's on, and I also find 16KHz PWM to be a bit more efficient.
2Doggs is offline Find More Posts by 2Doggs
Old Feb 27, 2011, 01:09 PM
i812's Avatar
Joined Aug 2009
I'd like to be able to do these stunts in my living room. Could someone recommend a good setup for my HK 450?
Nick Maxwell Protos 500 Indoor (2 min 30 sec)
i812 is offline Find More Posts by i812
Old Feb 27, 2011, 01:47 PM
Good News Everyone
jombo's Avatar
United States, CT, Trumbull
Joined Dec 2007
that is pretty slick , i want a garage like that too .... and fly almost as good
jombo is offline Find More Posts by jombo
Latest blog entry: NH airshow
Discussion 450 HK with Futaba EX radio and 3114 FASST servos SLOPPY? PaulGT3 Mini Helis 8 Nov 28, 2012 11:34 PM
Sold HK 450 head/tail/frame/canopy/motor - $20 shipped RobDog Aircraft - Electric - Helis (FS/W) 5 Nov 09, 2010 10:07 AM
Discussion Vendo HK 450 com Radio HK 7canais baratoooo !!! nino_sdk Brazil 0 Jul 26, 2010 08:42 PM
For Sale hk 450, exi 450 or copterx 450 HeliStyle Aircraft - Electric - Helis (FS/W) 5 May 15, 2010 11:57 AM
Help! HK 450 or HK 600 kilo2018 Beginner Training Area (Heli-Electric) 21 Feb 25, 2010 12:48 PM
