Old Sep 02, 2011, 04:04 PM
dennisjm is online now
Find More Posts by dennisjm
Proud RC Addict
United States, UT, American Fork
Joined Nov 2009
It looks like it needs more speed before it gets in the air. Like the motor is providing tons of torque on the frame but there isn't enough air over the surfaces to fly well. Just a guess..
dennisjm is online now Find More Posts by dennisjm
Old Sep 02, 2011, 04:22 PM
Lee is online now
Lee
Find More Posts by Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Originally Posted by Jared_Zygote View Post
I could not get the thing to taxi strait! I taxied over and over trying to get it to work but once it got going it would start swaying to one side or the other. On one attempt I got it pretty strait and tried to take off but the exact same thing happened that happened last time. Up 2 feet then crash down. I have never had so much trouble getting a plane up!! I am planning on repairing it then hanging it up to be a show piece. It is so highly detailed it breaks my heart to see it getting munched.
This time was much worse then last. I have video.....but I cant get my self to post it just yet. Still too tender :-)
It's a normal top heavy tail dragger with a slight cross breeze. Does it hand launch OK?
Lee is online now Find More Posts by Lee
Old Sep 02, 2011, 04:23 PM
Jared_Zygote is offline
Find More Posts by Jared_Zygote
Corn-holio
Jared_Zygote's Avatar
Provo Utah
Joined Mar 2004
you are probably right. I just could not keep it strait on the ground long enough to get to speed. It was probably off balance too. I had no info on where it should balance so I just guessed based on the position of my other planes. With the huge battery and motor in the nose it may have been nose heavy too.
Lee- It is too heavy to hand launch
Jared_Zygote is offline Find More Posts by Jared_Zygote
Old Sep 02, 2011, 04:46 PM
Darren Hintze is offline
Find More Posts by Darren Hintze
Tight is Right
Darren Hintze's Avatar
Lehi, Utah, United States
Joined Dec 2001
Hey Jared, sorry to hear about the continued struggles.
One thing I noticed... the plane does not sit anywhere close to level on the ground. As soon as you are adding elevator, the plane is coming off the ground in a turn.
Darren Hintze is offline Find More Posts by Darren Hintze
Old Sep 02, 2011, 05:03 PM
JONBOYLEMON is offline
Find More Posts by JONBOYLEMON
Full disclosure, not sponsored
JONBOYLEMON's Avatar
Joined May 2002
Jared, it looks like pilot error. Sorry.
Tail draggers are a bugger and require LOTS O rudder on takeoff.
Looking at the video the tail never started "flying" tipstall 3' off the ground = UGLY.
Get the tail flying before pulling up.
What prop? I am guessing you want an 10 or 12 as the last #
JONBOYLEMON is offline Find More Posts by JONBOYLEMON
Old Sep 02, 2011, 05:15 PM
Corn-holio
Provo Utah
Joined Mar 2004
Oh yea pilot error was never in question, we all knew that. Im just trying to learn for next time.
I was trying to do rudder but I need more practice I guess because on all my test taxis I would over correct no matter how easy I was trying to be, then finally loose control and stop.
the last prop I used was a 13x8
Anyway thanks for the tips y'all
Old Sep 02, 2011, 05:19 PM
Joined May 2002
PS, have you put a watt meter on the setup????
Next time do it at the sod farm in the middle of the sprinkler rows. Go full throttle and wherever nose is pointing when it get going, take off that direction. That would add some comfort for a squirly tail dragger. Dont feel bad about pilot error. We have all had some "Unique" tail dragger "takeoffs/attempted murders"
Old Sep 02, 2011, 09:07 PM
Wind_of_Change is offline
Find More Posts by Wind_of_Change
More Combat Please!
Wind_of_Change's Avatar
Utah
Joined Dec 2003
Bummer about the Bird Dog Jared.
A Bird Dog? Is that a dog with wings, meaning a plane that flies like a dog?
Anyhow, definitely didn't look fun to take off. My first little biplane was like that, couldn't control it on the ground AT ALL. But I'm surprised with a bigger plane like that.
Sometimes when you punch it the motor torque drags you hard left, and if it does it in the extreme, it means your motor is probably mounted wrong. You need a certain amount of right thrust angle to counter that, and if it's not built in, then the plane will veer hard that direction. And if you have your tail wheel trimmed to offset it, they'll fight each other and get you wagging like that. Even WITH motor's set up with right thrust angle, tail-draggers often require full rudder to offset torque.
Also, did you double-check your control surfaces to make sure your ailerons were set up right before flying? Looks almost like you trying turning one way and it went the other.
For a plane that size, you may want to try out one of these Starmax P51's - they fly amazingly well with the right setup. The FMS was great too, but not as beautiful or detailed.
Better luck next time. Sad I didn't get to see it before the incident.
Wind_of_Change is offline Find More Posts by Wind_of_Change
Joined May 2002
I plan to be at the sod farm early tomorrow.
Old Sep 02, 2011, 09:32 PM
More Combat Please!
Utah
Joined Dec 2003
This thread needs a boost. So here's a guy flying that could have lost everything if he'd flown a few inches lower.
This is what you call a "CLOSE CALL"
Jeb Corliss " Grinding The Crack" (3 min 30 sec)
Old Sep 02, 2011, 09:39 PM
smileyz is offline
Find More Posts by smileyz
ɯoɔ˙sǝıqqoɥɥɔǝʇlɐıɹǝɐ ˙ʍʍʍ
smileyz's Avatar
United States, UT, Lehi
Joined Apr 2005
That is just plan sick! I think I'd have to check my shorts if I got that close I don't think I'd be laughing about it...
Mike K.
http://www.youtube.com/watch?v=TWfph...layer_embedded
smileyz is offline Find More Posts by smileyz
Old Sep 02, 2011, 09:55 PM
Tight is Right
Joined Dec 2001
I will be flying tomorrow early!
Old Sep 02, 2011, 10:05 PM
More Combat Please!
Utah
Joined Dec 2003
So... we talking REALLY early, or just sorta early? Not sure I can get up for the 7 a.m. flying. What's everybody doing time-wise?
Old Sep 02, 2011, 10:25 PM
Tight is Right
Joined Dec 2001
I'll be there by 8. I've had a really long week and am not going super early either. Of course I'll still probably wake up before 7 and leave when I am ready anyway.
Old Sep 02, 2011, 10:29 PM
Joined May 2002
I am hoping for 7:00 shooting for 7:30.
Help! Trying to find Nitro flying area in Ogden Depot, Weber county, Utah jjstick USA - District X 4 Nov 08, 2013 01:20 AM
Alert Utah County Flying Schedule Darren Hintze Utah Flyers Organization 12934 Nov 09, 2010 06:35 AM
Discussion Utah County Flying Sites redgiki Utah Flyers Organization 6 Mar 23, 2007 03:23 PM
