Hi Rob
My set up should work on the regular quad's as well. Currently I'm also flying a 22" motor to motor quad with the same controller. It works well ![]() Here are 2 videos of that bigger version (using Wii MP as gyros) running the same code and same controller.
Thanks -Thanh |
Latest blog entry: PrintRBot assembling completes &...
Clearwater, FLorida !
Joined Sep 2009
One more question ? Did you write the code yourself? are you willing to share that part? It would be the only thing us non-programers can not tackel thank you again for this thread, it is cool edit.....duh.... I see the code now.. http://code.google.com/p/simple-flight-controller/ cool beasn |
Thanks Witespy! Yeah I wrote the code, and the source code is there. I hope more people jumping in and create something much cooler.
I know there are many great projects available out there as well. I just started this because I wanted to know what it took to control a flying machine, and I wanted to learn the thinking process that someone has done before for their great flying platforms -Thanh |
Hi Mike
I bought 2 Invensense ITG-3200 gyro chips and was afraid of its size. It's too small, but I will try that out some time. The ITG-3200 uses I2C so I might not be able to use the built-in wireless (which uses SPI to communicate with the host processor) of the 2500T board Do you have the weight of the UFO#8 motors and props? What's the prop size? Is there a good source to buy them? The 1-cell brushless speed controller from HK is pretty small, and if we make a tri-copter I think we can shed out some weights. -Thanh |
Hi Rob
with brushed motors, we can drive the motors directly from the controller without need for external ESCs (well we still need to add 4 FETs to the circuit though). So we save some weight and number of parts. -thanh |
The motors are 3g and are available from Terence at ChineseJade.
The props are 4.5cm long and contain both a CW and CCW in the package and are available from indoorflyer The also sell brushless motors. Both vendors are great to deal with and excellent shipping. I understand about the ITG-3200 - could be an option down the line. I would think that if we could combine the receiver functionality then we could eliminate another part. Watched your living room video again - amazing that you could grab it and let go and it still hovered! Ordering my TI kit soon. Mike |
Hi Mike
Regarding using the built-in RF of the dev kit for the receiver, we will need to use the other target board (the dev kit comes with 2 target board) for transmitting and this would require modifying your TX a bit to hook to the transmitting target board. Or maybe we can try to reverse engineer an existing TX and try to understand its signal. The latter is complicated, and not working with many TX. I've tried to tap the quad with a finger when it's flying, and the quad would end up flying higher after I tap it. It's still level though. Thanks for the links to those little gems. Do you know the diameter of the holes on the air ace props? I think it's better to fly with CW&CCW than tilting the motors. The reason is that when I give it sudden throttle jump the quad yaws, and that when I give yaw the quad tilts sometimes. Are the 3g motors from Terence directly driving the props (without gear box)? The UFO8 motors look a bit more expensive than some of brushed motors mentioned here: * 2g brushless: http://hobbyking.com/hobbyking/store...idProduct=7230 * 2.3g brushless: http://hobbyking.com/hobbyking/store...idProduct=9666 With the 1 cell ESC (weights 0.6g) it brings the weight to around 3g for each motor which are the same weight with the motors from Terence. * 1.95g brushed and gearbox: http://hobbyking.com/hobbyking/store...dProduct=10000 * 3.3g brushed & gearbox http://hobbyking.com/hobbyking/store...dProduct=10001 Too many choices and not sure which one to buy ![]() -Thanh |
Thanks for the info Mike
It's great that you've tested them out. Will try to see if I can change the code to drive a brushed motor this weekend. If that works, will order the brushed motors and props. Wonder how long they would last still ![]() Thanks -Thanh |
| Thread Tools | |
| Sold Parts for tri-copter or quad-copter | BloomingtonFPV | Aircraft - Electric - Power Systems (FS/W) | 4 | Aug 20, 2010 08:20 AM |
| Discussion Tri-Copter and Quad-copter Rotations | CaptainRedmuff | Multirotor Talk | 6 | Jul 01, 2010 10:52 AM |
| Build Log STM8s Quad-copter "Quad-radic" | Edftakeoff | Multirotor Talk | 4 | May 17, 2010 03:09 AM |
| For Sale tri-copter or quad-copter blades | HyperHelis | Aircraft - Electric - Helis (FS/W) | 0 | Sep 17, 2009 04:22 PM |
| Question Tri/hexa-copter or Quad/Octa-copter and Spartan AP2000i or Helicommand | Arthur P. | VTOLs | 2 | May 20, 2007 03:02 PM |
