This thread is privately moderated by Sandancer, who may elect to delete unwanted replies.
Old Nov 08, 2010, 08:50 PM
Sandancer is offline
Find More Posts by Sandancer
"Auntie Samantha"
Sandancer's Avatar
USA, MO, Clever
Joined Dec 2009
Build Log
F4U Corsair: Gotta' Have Flaps on this Bird!
In my opinion, the Flaps on the Corsair are AWESOME!
F4U Corsair Flaps (1 min 49 sec)
I have started the mod, and the starboard wing has been cut, channeled, hinged and pinned.
TIP: The design of the flaps being divided into 3 pieces on the Corsair was:
1: Because of the gull wing design it required the inner & center flaps to be separate by design of course.
2: The center & outer flaps were divided so the wings of the Corsair could fold up for storage on aircraft carriers.
The point I'm making here is....If your not freaky about scale, and you have no intention of making the wings fold up, which would be quite tricky with foam, then it would NOT be necessary to cut the center/outer flaps apart! They can be left as a 1-piece unit and still function.
Here are some preliminary pics of what I've done so far!
UP-DATE 11/11/2010: I've completed the starboard wing flaps today. I decided to go with the Dubro Heavy Duty Hinge & Cotter Pin . They worked out great when it came time to do the gluing. I was able to remove the cotter pins and separate the pieces while the CA dried so it wouldn't seep into the hinges. It will also allow the removal of one of the flaps if need be?
I used a piece of .020 High Impact Styrene 1 1/2" x 2" for the stiffener between flap 1 and flap 2. I ended up pinning flaps 2 and 3 with some CF rod and glued them together. I liked how solid this made flaps 2 & 3 that I decided to make flap 3 the driver. This worked out great now that I could run the linkage straight on to the servo.
After running the flaps thru numerous cycles I am very pleased with how easy they deploy, not to mention how kewl they look!
UP-DATE 11/15/2010: I got the flaps done and working flawlessly.
Sandancer is offline Find More Posts by Sandancer
Old Nov 08, 2010, 09:32 PM
HawkerTyphoon is offline
Find More Posts by HawkerTyphoon
HawkerTyphoon's Avatar
United States, NY, Patterson
Joined Jan 2009
That is REALLY COOL. How are you going to actuate all 6 flap sections at the same time?
HT
HawkerTyphoon is offline Find More Posts by HawkerTyphoon
Old Nov 08, 2010, 09:48 PM
"Auntie Samantha"
Sandancer's Avatar
USA, MO, Clever
Joined Dec 2009
HT
The 3 flaps are connected together so they'll work in unison. At this time I am thinking I will make the center flap the driver for each side. I'll make a reversed servo for one side and run both servo's thru a Y-Connector to the Rx. One channel is all I'll need.
Old Nov 08, 2010, 10:06 PM
Joined Jan 2009
Ahhh, Now that you said that I see the pic. where it shows that.
Sounds pretty niffty, cant wait to see it done!
HT
Old Nov 09, 2010, 05:54 PM
LICobra is offline
Find More Posts by LICobra
Warbird Enthusiast
LICobra's Avatar
Long Island, NY
Gaz...very nice on the flaps
LICobra is offline Find More Posts by LICobra
Old Nov 09, 2010, 06:33 PM
"Auntie Samantha"
Sandancer's Avatar
USA, MO, Clever
Joined Dec 2009
It's a work in progress Tony. I'm coming up with new innovations as I go.
Gaz
Old Feb 10, 2011, 01:47 PM
Eddie P is offline
Find More Posts by Eddie P
Official Boat Bum
Eddie P's Avatar
United States, NV, Reno
Joined Mar 2000
Fantastic work!
Eddie P is offline Find More Posts by Eddie P
Question CG on PZ F4U Corsair with Rotating Retracts hongrn Electric Warbirds 12 Jan 28, 2011 03:35 AM
Discussion F4U Corsair 60 w/Retracts ARF by Hangar 9 V2rider Electric Warbirds 10 Dec 25, 2010 05:49 AM
Discussion F4U Corsair Papo_60 Beginner Training Area (Aircraft-Electric) 6 Oct 31, 2010 05:03 AM
Does any body have flaps on their GWS Corsair? Flybyguy Parkflyers 16 Sep 21, 2004 02:34 PM
Question Anyone have any experience or thoughts on Aerofoam's F4U Corsair? Navy Air Slope 5 Jun 16, 2004 06:07 PM
