Old Dec 04, 2012, 06:21 AM
oldsneakers is offline
Find More Posts by oldsneakers
oldsneakers's Avatar
United States, CT, Hamden
Joined Jul 2011
I bought the Hobby King version of the FF Corsair and it came with a 39 gram nose weight molded in the nose foam. I bought the same plane as a kit from Banana and it didn't have the weight. I never flew the kit, but I'm guessing based on everyone's experiences, it's not going to fly good as is. Besides adding a gyro to the ailerons, going to a 3S 350mah battery made mine pretty flyable. That extra power made it hand launch decent.
oldsneakers is offline Find More Posts by oldsneakers
Old Dec 04, 2012, 12:14 PM
TimJohnson is offline
Find More Posts by TimJohnson
Split S
TimJohnson's Avatar
United States, CA, Rancho Santa Margarita
Joined Jul 2006
Just a heads up, the info I posted is for the FLYFLY branded P-51, not any of the or other brand renditions.
TimJohnson is offline Find More Posts by TimJohnson
Old Dec 04, 2012, 12:25 PM
ampdchaos is offline
Find More Posts by ampdchaos
United States, CA, San Diego
Joined Oct 2012
thanks ill keep it in mind.
ampdchaos is offline Find More Posts by ampdchaos
Old Dec 18, 2012, 05:39 PM
Joined Jul 2011
The motor in my Corsair finally gave up the ghost. It would just twitch with power applied. Can't complain, had a lot of flights on it. I had another stock motor and everything is back to normal.
I bought one of those HK/Banana Fun Fighter Corsairs to try. It's just about the same size as the Fly Fly Corsair. It's kinda ugly, not even trying to be scale. But as the name implies, it is a lot of fun. On the stock 3S battery it is way fast. A lot faster than the Fly Fly on 3S. Between the two of them it's a blast.
Old Dec 18, 2012, 06:18 PM
nom is offline
nom
Find More Posts by nom
nom
nom's Avatar
United States, ID, Boise
Joined Mar 2011
Where did you get the stock motor?
nom is offline Find More Posts by nom
Old Dec 18, 2012, 09:18 PM
Joined Jul 2011
Hobby88 in China.
Old Dec 19, 2012, 11:27 AM
nom is offline
nom
nom
nom's Avatar
Joined Mar 2011
Would you happen to have the model # handy? Thanks in advance.
Old Dec 19, 2012, 05:52 PM
Joined Jul 2011
The original motor is marked:
Model FF 3-312
2000 KV
The replacement motor has no markings. But it looks and performs identically as the original.
I'm pretty sure this is what I bought. The picture is wrong but the motor is right.
http://www.hobby88.com/shop/product_...roducts_id=403
Old Dec 19, 2012, 06:52 PM
KCinNC is offline
Find More Posts by KCinNC
that's gonna leave a scar
United States, NC, Mooresville
Joined Aug 2007
Model FF 3-312
2000 KV
are you using the stock prop ?
KCinNC is offline Find More Posts by KCinNC
Old Dec 19, 2012, 07:47 PM
Joined Jul 2011
Nope, I'm using an EP-6030. It's got a lot more thrust than the stock.
Old Dec 19, 2012, 08:57 PM
nom is offline
nom
nom
nom's Avatar
Joined Mar 2011
Oldsneakers, thanks for the info...now I can fly it again!
Old Oct 25, 2013, 11:09 AM
bman702 is offline
Find More Posts by bman702
Joined Oct 2013
FLYFLY P51d 550mm
I wish I would have seen this thread before i bought it. Well I built new landing gear added a steerable tail wheel. I'm trying to stick with the stock motor and 2S battery, CG seems pretty good with battery shoved up there. I break (2) of the stock props every time I fly, the collet is integral to the shaft. I read all these comments on use a GWS 5030 prop, my question is how??? I cant find a spinner or a cap that will fit in that tine hole the original spinner screws into. I cant remove the 4mm adapter that is welded or glued to the 2mm shaft without bending the shaft. I bought a FLYFLY 2 blade prop with spacer but without a spinner cap its useless. I cant keep breaking 5$ props while im trying to get this pig to fly. Can anyone give me model numnbers of adapters you used or your setup with one that actually flies well. Thanks
bman702 is offline Find More Posts by bman702
Old Oct 25, 2013, 08:03 PM
KCinNC is offline
Joined Aug 2007
i still have 2 of these (kits) i've yet to build !! had a hard time figuring out what motor to use. could not get my hands on the stock motor. there are all kinds of prop/collet adapters out there. find a 2mm that looks close to what you need. it's just trial and error on this thing. i was also planning to use a 2 blade prop.
maybe this winter i'll get one of these things flying
Old Oct 26, 2013, 04:55 AM
Joined Jul 2011
I would recommend going to a 3S battery. It made a big difference for me.
Old Oct 26, 2013, 06:26 PM
nom is offline
nom
nom
nom's Avatar
Joined Mar 2011
Agreed, +1 3S!
Build Log FlyFly Mirage2000 with NEW Inverted/Knife Edge/High Speed Videos! SkylineFlyer Foamy EDFs 105 Mar 05, 2011 11:26 PM
For Sale FlyFly 90mm F-4 ARTF SkylineFlyer Aircraft - Electric - Jets (FS/W) 0 Nov 08, 2010 12:00 PM
Rave Huge FlyFly Sale Mix and Match 2 for $299.99 SkylineFlyer Foamy EDFs 0 Aug 31, 2010 09:20 PM
Discussion Which is best to buy for his flying behaves between FLYFLY MIRAGE or FLYFLY RAPTOR ? FedericoA Foamy EDFs 3 Jan 24, 2009 09:48 PM
