Old Sep 10, 2012, 03:00 PM
compa71 is offline
Find More Posts by compa71
I try to Fly
compa71's Avatar
Italia, Emilia Romagna, Reggio nell'Emilia
Joined Dec 2011
Originally Posted by green_flyer View Post
I have done a static thrust test of GWS 5030 prop on the P51 with stock motor. 210g thrust for 5.13A, so much better than stock prop (210g for 10.5A - ridiculous amp draw).
I havent flown it yet, I have been fiddling trying to install a GWS 5043 prop into a nose cone, and a few other bits. What I can say is that with only a 5A draw I got a 325mah battery which slides right up behind the motor and appears to acheive the reccomended cog with no extra weight added. we will see if that works.
with only 5A draw I could have even gone with a lighter esc and lost 4~5g of weight.
http://www.youtube.com/watch?feature...&v=Q4Zd-dRAQRE
sure, 5043 perfect for 2s and 5030 perfect for 2s
compa71 is offline Find More Posts by compa71
Old Sep 14, 2012, 04:15 PM
oldsneakers is online now
Find More Posts by oldsneakers
oldsneakers's Avatar
United States, CT, Hamden
Joined Jul 2011
We took it on the chin with a two FF Corsair flyoff yesterday between me and my friend. My 3S 350mah Blue lipos keep getting shorter and shorter flight times. I guess I must be ruining them flying to too low of a voltage. The second battery died at 2:20 into the flight and crashed breaking the motor mount cowling. It was flying great up till then. My friend installed a non stock motor and 18 amp esc in his. I would guess it was not balanced correctly and never really made it into the air. One of those crazy go everywhere and then crash kind of hand launches. Still good fun.
oldsneakers is online now Find More Posts by oldsneakers
Old Sep 21, 2012, 10:13 AM
Joined Jul 2011
I saw a 3 blade gws 6030 EP propellor on headsuprc and bought a few thInking I could eek out a little more speed out of my FF Corsair. I suppose I could have used a propellor calculator but for me it's fun to actually test them. Here's what I got.
Stock motor, 3S 350mah, 2 blade gws 6030 EP prop
Amps - 9.4
Watts - 104.3
Thrust - 305 g
Stock motor, 3S 350mah, 3 blade gws 6030 EP prop
Amps - 10.1
Watts - 108.5
Thrust - 325 g
So not a big improvement but a little faster.
Old Oct 10, 2012, 03:29 PM
updogg is offline
Find More Posts by updogg
Joined Sep 2012
I have the same plane and am having some problems getting it in the air. How would I fix the wash out issue?
updogg is offline Find More Posts by updogg
Old Oct 11, 2012, 11:29 AM
updogg is offline
Joined Sep 2012
If I was gonna do a motor upgrade on this plane, what would be my best way to go? Should I do a motor with a higher kv or lower kv?
Old Oct 11, 2012, 11:55 AM
whichwaysup is offline
Find More Posts by whichwaysup
when down=up, up=expensive
whichwaysup's Avatar
United States, NC, Greenville
Joined Apr 2012
Motor upgrade?? Have you tried it on 3S yet? You may find that a simple battery swap from 2S to 3S will give you more speed than you need! I used a 3S Thunder Power G3 350 mAh and the thing got out of sight faster than I could see it.
Still have the battery, by the way, but not the airplane if anyone is interested in buying it. Just sitting here in storage charge with only about 10 (short) flights on it.
whichwaysup is offline Find More Posts by whichwaysup
Old Oct 11, 2012, 12:14 PM
updogg is offline
Joined Sep 2012
How much for it?
Old Oct 11, 2012, 01:01 PM
Joined Apr 2012
Pm'd you, since we're a bit OT. Let me know.
Old Oct 15, 2012, 10:06 AM
updogg is offline
Joined Sep 2012
I blew my esc on this plane I think. Looking to get a new motor and esc. I just purchased a Turnigy 3S 370mAh battery. Needs some suggestions for the motor and esc. I was looking at the GENS ACE Mars Brushless Motor Mars-BL2738-3430KV w/30A ESC Combo for RC Airplanes on hobbypartz.com
Could use some opinions if this would be a good fit for my plane
Old Oct 15, 2012, 10:54 AM
Joined Apr 2012
Hey all - If anyone is looking for a battery to go 3S - I'm selling this one - fit nicely in the plane and has the right connector. PM me if interested.
http://www.rcgroups.com/forums/showthread.php?t=1751948
Old Nov 05, 2012, 11:08 AM
rotagen is offline
Find More Posts by rotagen
Scratch building addict
rotagen's Avatar
United States, CA, Felton
Joined Jan 2005
Anyone know who is selling these micros? Having a hard time finding them.
rotagen is offline Find More Posts by rotagen
Old Nov 05, 2012, 12:23 PM
Joined Apr 2012
you might want to look for something else.
Seriously, I would read this thread a bit before you buy. Hate to discourage you, but those that have had good experiences with these have been the exception, and it is a credit to their ability to fix all the things that are wrong with them.
Old Nov 05, 2012, 01:29 PM
Rescuejim is offline
Find More Posts by Rescuejim
I can crash anything
United States, TX, Fort Worth
Joined May 2012
I second that. I have actually had more fun trying to rebuild the plane in a more flyable configuration than I have flying it. As a matter of fact I probably haven't put ten batteries threw it in 6 months and I have probably flown a hundred batteries in that time.
Rescuejim is offline Find More Posts by Rescuejim
Old Nov 20, 2012, 05:16 PM
compa71 is offline
I try to Fly
compa71's Avatar
Joined Dec 2011
finally ready F4U carbon fiber/tungsten cowl
mounted
Old Nov 20, 2012, 05:43 PM
TimJohnson is offline
Find More Posts by TimJohnson
Split S
TimJohnson's Avatar
United States, CA, Rancho Santa Margarita
Joined Jul 2006
Cool! Good work!
TimJohnson is offline Find More Posts by TimJohnson
Build Log FlyFly Mirage2000 with NEW Inverted/Knife Edge/High Speed Videos! SkylineFlyer Foamy EDFs 105 Mar 05, 2011 11:26 PM
For Sale FlyFly 90mm F-4 ARTF SkylineFlyer Aircraft - Electric - Jets (FS/W) 0 Nov 08, 2010 12:00 PM
Rave Huge FlyFly Sale Mix and Match 2 for $299.99 SkylineFlyer Foamy EDFs 0 Aug 31, 2010 09:20 PM
Discussion Which is best to buy for his flying behaves between FLYFLY MIRAGE or FLYFLY RAPTOR ? FedericoA Foamy EDFs 3 Jan 24, 2009 09:48 PM
