Old Jul 01, 2012, 06:35 AM
dazza44 is offline
Find More Posts by dazza44
who put that tree there
dazza44's Avatar
Joined Jun 2010
thinking about getting this thing to fly better than last time,got p51 airborne stalled n crashed,left it in box since..
all repaired now,whats the best prop on a 2s,i tried a 6x6 got a little too hot.
6x4 ?? 6x5?? anyone tried on stock..
dazza44 is offline Find More Posts by dazza44
Old Jul 01, 2012, 11:01 AM
will3kgt is offline
Find More Posts by will3kgt
will3kgt's Avatar
Grand Blanc, MI
Joined Jan 2007
I run mine on a 4.7 x 4.25 APC Prop.
will3kgt is offline Find More Posts by will3kgt
Old Jul 01, 2012, 12:13 PM
dazza44 is offline
dazza44's Avatar
Joined Jun 2010
hows it fly on that prop,hand launch ok?
Old Jul 01, 2012, 03:46 PM
will3kgt is offline
will3kgt's Avatar
Grand Blanc, MI
Joined Jan 2007
It flies alright. Is your plane correctly balanced? I needed 21gms of lead in mine.
Old Jul 01, 2012, 03:53 PM
dazza44 is offline
dazza44's Avatar
Joined Jun 2010
yeah balanced ok,stuck about 28g of lead up front to balance it..
Old Jul 01, 2012, 11:13 PM
will3kgt is offline
will3kgt's Avatar
Grand Blanc, MI
Joined Jan 2007
You're good to go.
Old Jul 02, 2012, 03:23 AM
dazza44 is offline
dazza44's Avatar
Joined Jun 2010
hopefully better than the first attempt.
damn thing just rolled over and wham,needed more airspeed on launch..
Old Jul 02, 2012, 09:29 AM
will3kgt is offline
will3kgt's Avatar
Grand Blanc, MI
Joined Jan 2007
Throttle to 75% and launch. Make sure you throw it straight
and true.....Then you won't have to deal with that "P-51 thing"
Old Jul 02, 2012, 11:35 AM
whichwaysup is offline
Find More Posts by whichwaysup
when down=up, up=expensive
whichwaysup's Avatar
United States, NC, Greenville
Joined Apr 2012
Beware - stupid as it sounds, check your ailerons and make sure they aren't reversed. . . . .
whichwaysup is offline Find More Posts by whichwaysup
Old Jul 02, 2012, 11:56 AM
dazza44 is offline
dazza44's Avatar
Joined Jun 2010
axactly the thing i tell others learning to fly,
seen it enough times,or actually plug em in
Old Jul 02, 2012, 12:13 PM
Joined Apr 2012
I'm pretty experienced but I drilled this thing into the ground about 12 times before I thought to check it. It was such an obvious mistake I never thought about it. When I pre flighted I just looked for wiggling ailerons and didn't pay attention to the direction.
Old Jul 02, 2012, 01:01 PM
dazza44 is offline
dazza44's Avatar
Joined Jun 2010
had my p51 since spring last year.
just was not having it when hand launching,nosed after a stall,left in box since.
just decided to fix it n get it flying,first thing was a change of prop.
lot of nose weight, shall look at motor upgrade next to lose that some of that dead weight..
Old Jul 02, 2012, 06:13 PM
oldsneakers is offline
Find More Posts by oldsneakers
oldsneakers's Avatar
United States, CT, Hamden
Joined Jul 2011
My very first RC plane launch (last year) I had the elevator reversed and smashed into the ground. Later I managed to have the alerons reversed which made for a short flight. I got a FMS 800mm Hellcat a while back and unsucessfully hand launched it three times I think. Down and left into the ground. Last week I threw it up at about a 45 degree angle and pretty hard. Made it up all three times. Maybe when all else fails, try that.
oldsneakers is offline Find More Posts by oldsneakers
Old Jul 02, 2012, 07:00 PM
dazza44 is offline
dazza44's Avatar
Joined Jun 2010
i got fms 800 hellcat too,lovely plane hand launches no probs on apc 7x6.
Old Jul 02, 2012, 10:18 PM
bladefan is offline
Find More Posts by bladefan
bladefan's Avatar
United States, OR, Portland
Joined Jun 2006
oldsneakers,
what kind of scale is that? a fish scale? how accurate is it? i looked on amazon, and the ones I'm seeing have about 10gm resolution. seems too coarse.
I bought another prop to try on the corsair because those EP-6030's break very easily. That led me to youtube and a video on how to measure thrust with a fish scale. So I bought a $15 scale and tested the props. This method works really well.
Original 3 blade - 190 grams of thrust
APC 6x3 - 230 grams of thrust
EP-6030 - 280 grams of thrust
This corsair is so fast, I bet any of these will work fine.
bladefan is offline Find More Posts by bladefan
Build Log FlyFly Mirage2000 with NEW Inverted/Knife Edge/High Speed Videos! SkylineFlyer Foamy EDFs 105 Mar 05, 2011 11:26 PM
For Sale FlyFly 90mm F-4 ARTF SkylineFlyer Aircraft - Electric - Jets (FS/W) 0 Nov 08, 2010 12:00 PM
Rave Huge FlyFly Sale Mix and Match 2 for $299.99 SkylineFlyer Foamy EDFs 0 Aug 31, 2010 09:20 PM
Discussion Which is best to buy for his flying behaves between FLYFLY MIRAGE or FLYFLY RAPTOR ? FedericoA Foamy EDFs 3 Jan 24, 2009 09:48 PM
