Old Nov 08, 2010, 05:18 PM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
Mini-HowTo
Ultra Micro 1S lipo warmer packs (socks)
I have decided to try to make some socks if you will to keep my 1S lipo batts warmer in colder temps.
I am using that thin packing foam as the insulator and simply making a cylinder and gluing together - well this as far as I have gotten now.
I have rolled the pieces over to accomodate for the different batt sizes I used
one will be for 500 MAH Blade SR 120 batts
one for any single cell stick lipos such a the Hyperion 160 MSH
one for the hyperion 180 MAH batts.
I have secured with foam safe CA and pins to hold in place.
Once this is dry, I will trim, glue the ends of each sock and then use a tiny bit of velcro maybe where the battery connectors will come out of.
See pics below of current progress.
Has anyone else done anything like this before, and if so how?
thanks
Ryan
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Nov 09, 2010, 09:54 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
First Batch
Well the Foam safe CA didn't hold the foam - so I ended up using a tiny bit of low temp hot glue, which will in fact melt this foam wrap, if you're not careful.
I used velcro to seal the connector end of the sacks on all but the 150 lipo sack.
These sacks aren't pretty by any mean, and they're untested thus far, BUT I will report my findings when I have time to test them.
Here are the weights
Hyperion 180 MAH 1S without sack = 5.84
Hyperion 180 MAH 1S with sack = 6.44
a difference of = .6 grams.
EFlite 150 MAH 1S without sack = 4.62
EFlite 150 MAG 1S with sack = 4.98
A difference of = .36 grams
EFlite 500 MAH 1S without sack = 13.85
EFlite 500 MAH 1S with sack = 15.0
A difference of = 1.15 grams.
As you can see, the weight gain isn't really all that bad.
Hopefully I can test them soon.
R
Old Nov 10, 2010, 05:58 AM
flypaper 2 is offline
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
I've been using these for a few yrs. Pretty much the same as yours but held together with hockey tape. Batts come out at about the same temp as in the summertime.
Gord.
flypaper 2 is offline Find More Posts by flypaper 2
Old Nov 10, 2010, 06:26 AM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
Well, did you weight the battery without sack, with a velcro on it? Because that's what you would have to do, since you cannot the battery alone without a velcro. So basically, the only added weight is the sack itself, since in both case, you need velcro.
I've been using mits as well since last winter, and I love it. Mine are made of neoprene which does glue better, and hold together longer. Velcro also stick better. But they are heavier. Still better than not being able to fly my 1S models during winter because the battery freeze, so welcome to the club!
RealGambler is offline Find More Posts by RealGambler
Old Nov 10, 2010, 07:01 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Not only for 1S Micros. I started using the same type pockets on flat plate foamies using 3S 1320 over 5 years ago.
Charles
Old Nov 10, 2010, 07:17 AM
QuAd FaNaTiC
Canada
Joined Aug 2009
Sweet and they work well I guess
Good news.
Gord.
Old Nov 10, 2010, 07:18 AM
QuAd FaNaTiC
Canada
Joined Aug 2009
No I left Velcro in the 180 batts because use it indoors as well.
Old Nov 10, 2010, 07:19 AM
QuAd FaNaTiC
Canada
Joined Aug 2009
Good point
Charles
Old Nov 11, 2010, 08:04 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
Great news
I just tried my lipo sock warmer on my 120 SR which had previously been hard to fly in colder temps, and now has no issues.
Current temps are 43 F or 4 Celsius
Old Nov 11, 2010, 08:36 PM
outngo is offline
Find More Posts by outngo
E-Gliders
outngo's Avatar
South Carolina
Joined May 2009
saran wrap anyone?
outngo is offline Find More Posts by outngo
Old Nov 11, 2010, 08:49 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
haven't tried that
Old Nov 12, 2010, 07:53 AM
Woody_99 is online now
Find More Posts by Woody_99
Too much is just not enough...
Woody_99's Avatar
Joined Jan 2009
Do you think if you could keep the batteries warm prior to use, that they would work OK?
We did some of that last fall and it seemed to help. If the battery gets cold, prior to use, they don't work so well.
Woody_99 is online now Find More Posts by Woody_99
Old Nov 12, 2010, 09:23 AM
QuAd FaNaTiC
Canada
Joined Aug 2009
I have read that BUT didn't work for me.
Old Nov 12, 2010, 10:06 AM
jkettu is offline
Find More Posts by jkettu
Joensuu, Finland
Joined Mar 2002
That would depend on the battery's internal resistance and how many amps you pull from it. It is a balancing act between heat generated by discharge current and heat lost to surrounding air. As long as the the temperature stays within battery's comfort zone, it will work just fine. On low-power applications some additional thermal insulation can be a significant help. Definitely do keep the batteries warm before use.
jkettu is offline Find More Posts by jkettu
Old Nov 12, 2010, 10:16 AM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
One of the guys in the club uses one of those foam cooler/ heaters that plugs into a cigarette lighter to keep the batts warm. At the field he plugs it into his 12V charger power supply. We use a 110 volt generator plugged into an outlet outside to power the wiring in the clubhouse.
Gord.
Yippee! Parkzone Ultra Micro FPV - 5.8ghz 200mw FPVhobby TX - 40g without lipo's :D chancesAU FPV Equipment 2069 Jan 01, 2016 03:07 PM
Sold 3 Wowhobbies 20C 1S 3.7V 600mah packs boom Aircraft - Electric - Helis (FS/W) 5 Oct 30, 2010 12:51 PM
For Sale 12 Tenergy and 4 Parkzone 110mah 3.7v 1S 8C Lipo's For Ultra-Micro's speedster239 Aircraft - Electric - Batteries & Chargers (FS/W) 2 May 06, 2010 12:30 AM
Sold Celectra 4-Port 1S ultra-micro lipo charger Roswalt Aircraft - Electric - Batteries & Chargers (FS/W) 6 Feb 28, 2010 12:28 PM
Sold 1s parkzone 3.7v 1s charger with five 1s lipo packs hacker002 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 5 Dec 11, 2009 03:56 PM
