Old Aug 11, 2011, 07:09 PM
Crazy Cessna Owner
Robbie d's Avatar
Australia, SA, Windsor Gardens
Joined May 2001
@Zootster Indeed there is, PZ UM planes and Eflite.
Was thinking about a raptor 50 E conversion, <$200 on 8S. Cheap if I can get a s/h airframe without smelly motor.
Robbie d is offline Find More Posts by Robbie d
Old Aug 11, 2011, 09:58 PM
AdMan's Avatar
Australia, SA, Ingle Farm
Joined Feb 2010
Originally Posted by Zootster View Post
Is there any OMP products there? It could be .................................................. ......... CHUCKIES shop
Well... No dramas out there whatsoever, just had to wait a little while for the bloke to return and I got what I needed.
There was another bloke there who wanted to start learning to fly... Then he told me what he was going to learn with. He opted for a Spitfire, I told him how hard they are to fly, especially for a beginner. But that didnt change his mind.
Ive just soldered the ESC up... some reason I couldnt get the damn programming card working. Now, the heli wont even spool up, it starts to but just quits. It looks like the positive wire from the windings on the motor has broken, and smells burnt. Something is not happy right now, I wont be when dad finds out.
AdMan is offline Find More Posts by AdMan
Old Aug 12, 2011, 04:12 AM
Joined Dec 2010
Originally Posted by AdMan View Post
Unfortuantely, my dad wont buy anything thats got a Turnigy sticker on it....
As far as Im aware Dualsky is the same exact thing as Hobbywing and Turnigy, I have Turnigy 100a HV in my 600 and it is the same as the Dualsky in every way.....apart from the drug money price the LHS wants for it. You would be surprised how much of this hobby gear is flogged off to us at huge price hikes thanks to a sticker
Paradude is offline Find More Posts by Paradude
Old Aug 12, 2011, 04:15 AM
addicted rc'er
acky's Avatar
Adelaide, Australia
Joined Dec 2009
had no luck with the f-86 today - grass runway full throttle for about 50m then the motor cut out, now intermittently works to about half throttle and dies, or at 1/4 throttle cuts out see the vid below, any ideas???? motor or esc??
(all connections tight!)
fan f 86 (0 min 40 sec)
acky is online now Find More Posts by acky
Old Aug 12, 2011, 05:01 AM
The return of the spity
spityman's Avatar
Adelaide, South Australia
Joined Feb 2005
Hi Acky,
I've had this hapen to me before, on one occasion changing the ESC timing mode and PWM setting together worked, timing mode alone was not enough.
On the second time with a different model, could no nothing but change ESC's. ESC was fine and I am still using it, just in a different combo with a different motor.
Hope this helps.
Bruno
spityman is offline Find More Posts by spityman
Old Aug 12, 2011, 05:11 AM
Life begins at transition
Australia, WA, Perth
Joined May 2007
Looks ESC related to me... Each time I've killed a motor, they either just don't run, or get reeeeaaaallllyyyy hot.
Can you check with another speedy without completely removing the fan?
Odysis is offline Find More Posts by Odysis
Old Aug 12, 2011, 05:13 AM
Ozzie Express wiggy pilot
SON OF PALEFACE's Avatar
YANKALILLA , SOUTH AUSTRALIA.
Joined Nov 2002
Originally Posted by aeromaniac View Post
Why it could of been worse, Yankalilla
Doesnt matter where it is...too rich for me...
SON OF PALEFACE is offline Find More Posts by SON OF PALEFACE
Old Aug 12, 2011, 05:33 AM
addicted rc'er
acky's Avatar
Adelaide, Australia
Joined Dec 2009
Too late I've pulled the fan, tried checking with a Hyperion 50 amp that was in a 3s prop plane, I get the arming tone but no power to the motor - is that cos the esc is setup for 3s?
Old Aug 12, 2011, 06:03 AM
Joined May 2007
How many cells are you trying to run it on?
Old Aug 12, 2011, 06:06 AM
Glow 😡 no no no
Australia, SA, Evanston Park
Joined Mar 2010
I tried to put 6s into a 5s hyperion esc and had the same thing, maybe your esc isnt rated to that number of cells ?.
aeromaniac is online now Find More Posts by aeromaniac
Old Aug 12, 2011, 06:39 AM
addicted rc'er
acky's Avatar
Adelaide, Australia
Joined Dec 2009
Whoops, i need to run 4s and on the back of the Hyperion esc 1-3 cells ..... Anyone got a 50+ amp esc for sale or swap???
Old Aug 12, 2011, 06:57 AM
Zootster's Avatar
Paralowie, South Australia
Joined Jul 2007
DOH
Zootster is offline Find More Posts by Zootster
Old Aug 12, 2011, 10:51 PM
jbc
WHO's your DADDY!!!
jbc's Avatar
Australia, SA, Adelaide
Joined Sep 2009
Try the fan/motor on your 1-3S hyperion ESC on 3S and see if she spools up to full throttle. Also reset your throttle point from 0-100%. Check your timing on low, med, and high.
Looked to me, especially at the 7 second mark, that she was horribly out of balance. Might be something as simple as the rotor rubbing and getting stuck on the shroud when it hits a specific RPM.
I used to have a horrible vibration at one specific rpm setting on one of my motors, shaft was straight, prop was balanced and I couldn't get rid of it. My only solution was to make sure I didn't keep the throttle at that setting, above and below it was fine and very smooth.
If you still can't sort it I got a test stand you can try it out on here at home. I also got a 4S 50A speedy here which I pulled out of my FMS P47, it's brand new and I never used cos it pulled 49A from the get go and just went and stuck a 60A in it for the maiden.
jbc is offline Find More Posts by jbc
Old Aug 12, 2011, 11:51 PM
Joined Jun 2011
Maybe the shaft was displaying mechanical resonance, matched to the frequency of the motor at that specific troublesom RPM?
lofi is offline Find More Posts by lofi
Old Aug 13, 2011, 12:35 AM
addicted rc'er
acky's Avatar
Adelaide, Australia
Joined Dec 2009
Cool will try it with the 3s, if it's ok I will order a turnigy plush 60, will let ya know Jbc
Discussion Adelaide & sa flying & chat Zootster Australia 12333 Nov 08, 2010 11:33 PM
Discussion Electric Flying in Adelaide...? retiredVTT Electric Plane Talk 21 Jan 04, 2008 07:54 AM
Question electric flying sites in adelaide mustang mad Australia 6 Oct 18, 2006 10:04 PM
Discussion Electric Flying in Adelaide learner Australia 4 Sep 20, 2006 02:11 AM
Indoor flying in Adelaide Maxcat Micro Helis 0 Jul 23, 2004 06:12 PM
