USA, AZ, Buckeye
Joined Feb 2010
Since the inside form of the inlets as they are now are fairly square, is it recommended to make something round rather than following the existing lines inside the frame? I really didn't want to get into fiberglassing or molding something...any other ideas or materials that could be used?
High Orbit.....
Joined Jun 2009
But I agree its a head ache and a dropped ball on LXs part for not making even a thin walled simple duct. They could have even created a foam sleeve later but my guess is the low performance turned everyones interest away from the model to the point that they don't even bother. |
USA, AZ, Buckeye
Joined Feb 2010
I kept my old crashed airframe that is split apart. it looks as though if I can make a transition so the air turns towards the fan rather going straight back and hitting a dead stop, that might help out. maybe one piece that is turned at a 45 or so and curved up to the fan. I don't think I can muster up the interest to build formed full length intakes.
USA, AZ, Buckeye
Joined Feb 2010
Well I took a look down the intakes on the F35 right around where the rear gear is things open up quite a bit and then goes to the back of the plane with a dead stop. So what I thought I would do is build some sort of transition piece that would curve the airflow from the outer edges of the intake inward and direct it to the intake of the fan. This would essentially cutoff the entire open back area of the plane. So take a look at the small transition piece I made from depron...you can really see how it will curve the airflow. I am just not sure how I am going to get it in a finished and built plane.
USA, AZ, Buckeye
Joined Feb 2010
I worked abit more on m F35 last night and got the deflectors mounted inside. It looks like I was able decrease the intake volume overall by 50%....closer to the intake area at the front of the intakes. I pulled the 2750KV motor and installed a new 3000KV longer can motor and used a different intake lip on the fan. Was able to balance out the fan so it ran much smoother. Hopefully I can get it out tomorrow and see how it runs.
| Thread Tools | |
| New Product Banana Hobby F-35 JSF 3D Vectored Thrust | xplaneguy | Foamy EDFs | 504 | Apr 06, 2013 12:08 AM |
| Question Banana Hobby F-16 70mm LX model | Aero12 | Banana Hobby | 5 | Mar 28, 2011 08:45 PM |
| Discussion Airfield RC F-35 vs Blitz RC F-35? | ZeroRaven | Foamies (Kits) | 7 | Dec 28, 2010 10:54 AM |
| Sold Blitz/LX 5S 70MM fan/motor esc/bec | truevine77 | Aircraft - Electric - Jets (FS/W) | 1 | Apr 20, 2010 10:54 PM |
| New Product LX Blitz Bananahobby F-35 TV retracts gear doors missiles | FOX ONE! | Foamy EDFs | 2 | Nov 10, 2009 11:34 AM |
