Netherlands
Joined Oct 2010
FMA PL8 field charger software ?
Hi
Sneak preview, because of some post in this thread http://www.rcgroups.com/forums/showthread.php?t=1176112 I have now for a while 2 PL8's and I like then a lot. The CSS software works perfect for setting up the PL8's. But it is really not user friendly when you want to use this software in the field for charging your lipo's dislikes ( as field charger software ) - it take more then a minute to start. eeepc T91I - It uses 100 MBytes of memory, ( Why you tell me ) - Window to big for eeepc - Need to type name of file every time ( I want all charges stored, in file ) - to much pushing buttons - For every charger a window - one file if cycling, for charge, discharge and wait So how to solve this problem, try to Analise the protocol and make the field charger software my self. Peace of cake ![]() I thought. Here a small movie of what I already have accomplished.
Some High level requirements that I wanted - support for 1 to 4 chargers - Automatic logfile generation ( date, time, Action, preset, charger name ) - simple start and stop by one click, no repetitive conformation, selection of action) - More flexibility for cycling, different delay's for before charging and discharging. - Separate files for charging monitoring, discharging in cycle mode. - needs to fit on eeepc display and should be able to use only touch screen. ( no mouse and key board, needed ) - possibility to extend to other measuring devices, Digitalmultimeter for temperature. - expand will only be a selection in the UI. State, is already pretty far. Everything is written in python 3.1.2 (32bit), using pySerial for communication - Protocol is not so simple to revers-engineer, but a lot is already know ( see movie ) - CRC, IR still needs some more revers-engineer - need to look at NiMH NiCd charges/discharge - accurate discharge didn't show mAh. It will be open source, after I fixed some small problems don't know how I am going to do this Don't hope that FMA doesn't like this revers engineering. Because there help with the CRC is welcome, I can't figure it out. DB, |
Netherlands
Joined Oct 2010
So first version is available, I can't test all the configurations, tested a lot with
Lipo's. ![]() it can be found here https://sourceforge.net/projects/fieldcharger/ Small installation description, https://sourceforge.net/projects/fie.../topic/3964919 If you find a bug, please post it in here https://sourceforge.net/projects/fie.../topic/3966239 questions can be handled here DB, oh btw DB, are also my normal initials. |
Netherlands
Joined Oct 2010
Logfile output
prefix;action;sec;fuel;cap;Vout;Aout;Wout;Cell1V;C ell1ir;Cell2V;Cell2ir;Cell3V;Cell3ir;Cell4V;Cell4i r;Cell5V;Cell5ir;Cell6V;Cell6ir;Cell7V;Cell7ir;Cel l8V;Cell8ir;crc logview can't load logfiles yet, will change in the near future, but the format file can be downloaded here http://sourceforge.net/projects/fiel...8.ini/download This file needs to be placed in Windows 7 : C:\Users\"useraccount"\AppData\Roaming\LogView\Ger aete\OpenFormat Windows XP :C:\Documents and settings\"useraccount"\Application Data\LogView\Geraete\OpenFormat DB, |
| Thread Tools | |
| Sold Hobbico Quick Field DC Charger MkII $22 shipped | blueretro | Aircraft - General - Miscellaneous (FS/W) | 4 | Nov 13, 2010 07:37 AM |
| Sold Hobbico Quick Field DC Charger MkII $22 shipped | blueretro | Aircraft - Electric - Batteries & Chargers (FS/W) | 1 | Nov 03, 2010 05:22 PM |
| Help! PL8 - Charger address? "in beta testing" | G64 | FMA Direct | 2 | Sep 07, 2010 10:19 AM |
| Sold 2-FMA Cellpros and 1 Hobbico Quick Field Charger | crazyflyin | Aircraft - Electric - Batteries & Chargers (FS/W) | 17 | Jan 13, 2010 06:59 PM |
| For Sale FMA 250s, quick field charger and lipo charger | hoofhearted | Aircraft - Electric - Batteries & Chargers (FS/W) | 3 | Apr 13, 2008 03:49 PM |
