Feel free to ask questions. Also go have a look at our Blog site. Many photos and building tips can be found there. http://correxmig.blogspot.com/ Enjoy the Mig experience Markus
This one had a OS .46 http://www.rcgroups.com/forums/attac...mentid=3114426 and electric a Axi 2814/12. |
![]() I use hot glue for 95% of the construction....I then only use contact for the ailerons and to close the wing. Goop is a very good glue, so I read all over the net,......but not available here in ZA! ....but yes, Bostick 123 will work if its a contact type glue!So, how far are you TRex99?
Joined May 2011
I also spoke to another correx basher and he said that he build all his planes
With CA medium , he heats up or just blow over the part he wants to go with a Plumbers heat just to remove any oil trace and them he places drops 2-3 cm apart That is the trick , he said that if you place to much CA then it does not hold , According to him he has build , and I have seen pick of his planes , Many crashes and the correx brake not the glue joint , Will give it a try as well Billy |
| Thread Tools | |
| Build Log first scratch-build! :D | ClippedWings78 | Foamies (Scratchbuilt) | 7 | Nov 01, 2010 07:45 PM |
| Build Log MiG-15 in 1/10th scale for PSS: A Scratch-Build | John Rood | Slope | 4 | Sep 17, 2010 08:41 PM |
