Old Apr 20, 2011, 11:41 AM
Sean Oelofse is offline
Find More Posts by Sean Oelofse
.....till the wind drops.
Sean Oelofse's Avatar
Port Elizabeth, South Africa
Joined Oct 2006
Cool!
We have our Easter Holidays this weekend aswell!
So how does the correx get to you?..Did you order it on-line?..does it come rolled up??...What thicknesses did you order?...color?...straight flutes I hope?
Sean Oelofse is offline Find More Posts by Sean Oelofse
Old Apr 20, 2011, 01:28 PM
rhysduk is offline
Find More Posts by rhysduk
Rhys - Forever Learning
United Kingdom, Wales, Nelson
Joined Feb 2007
Happy Holidays! as they say across the pond
I've ordered a couple of sheets of 1.22m2 4mm Correx (white) which SHOULD be delivered tomorrow as it was despatched today by next day courier! (I've got 2mm coming from Ebay - Not sure about delivery on that)
I'm hoping it does arrive tomorrow in time for my long weekend (I've been playing with scaling and tiling the plans and need to print and stick page/sheet3 out to check the dimensions on the fuz. Fingers Crossed!
Can someone give me the length of the BOTTOM line on the ailerons when scaled to 116% for a WS of 1320mm? I can then check if the scaled and tiled version of my plans are correct before taking to the correx.
The start is looming....
rhysduk is offline Find More Posts by rhysduk
Old Apr 20, 2011, 02:22 PM
Joined Oct 2006
Hey rd!
I dont have my templates with me.
Have I understood your Q correct?
Thought I would try this for you and hope it helps. If not, shout again, I will try something else.
Old Apr 20, 2011, 02:37 PM
rhysduk is offline
Joined Feb 2007
Thanks Sean.
Is the TE of the aileron measuring 155mm to 590mm giving a TE aileron length of 435mm or thereabouts?
Sorry, had a mind blank earlier and couldn't think of the correct terminology!
Old Apr 20, 2011, 03:05 PM
johannlochner is offline
Find More Posts by johannlochner
Stirring the pot
johannlochner's Avatar
Port Elizabeth South Africa
Joined Jun 2008
Originally Posted by Sean Oelofse View Post
Hey rd!
Hehehehe
Try....
Inches!
They don't understand metric like I don't imperial!
johannlochner is offline Find More Posts by johannlochner
Old Apr 20, 2011, 03:58 PM
Joined Oct 2006
Originally Posted by rhysduk View Post
Thanks Sean.
Yes!...spot on!
Sorry about the mm.....
Old Apr 20, 2011, 04:23 PM
rhysduk is offline
Joined Feb 2007
Mm/inches.... It's all the same
Ok, so my TE aileron edge is 444mm. 1cm off what yours is Sean.
This is from the tiled 116% sheet I made from the original plans in Adobe Acrobat 9.
I'll post a picture if you want, I'm measuring from the start if the aileron (left on plan) right up to the aileron cut line. This measures 444mm.
What you think guys?
Old Apr 20, 2011, 04:28 PM
Joined Oct 2006
I think it will work just fine!
Old Apr 21, 2011, 10:45 AM
rhysduk is offline
Joined Feb 2007
So arriving home I come across these two packages waiting for me
2 sheets of 4mm white correx.
A big roll of 2mm correx black. I'm sure I ordered white. going to have to flatten it before I use it.. bugger.
I can't be bothered to send the black back for white, it won't make much difference.. Will have to spray it white or something for the colour scheme probably.
Oh well.
Off to try and get these plans sorted
Old Apr 21, 2011, 11:00 AM
GreenAce92 is offline
Find More Posts by GreenAce92
Physics hate's my ideas
GreenAce92's Avatar
USA, NY, Dunkirk
Joined May 2007
wow what a great design, its incredible that you guys use that stiff chloroplast like stuff, the "VOTE for MAYOR" material... anyways I really like the wing design it's like an SBD Dauntless, from an under side view.
GreenAce92 is offline Find More Posts by GreenAce92
Old Apr 21, 2011, 11:57 AM
EATHIS is offline
Find More Posts by EATHIS
EATHIS's Avatar
South Africa, EC, Port Elizabeth
Joined Sep 2009
Hey Rhysduk,
You really are having a tough time to get your build started.
Here, we just drive a few K`s and buy over the counter. As much as we want and any size and various colours. The same place slles the vinyl we use to cover the plane with the woderful `skins`you see onthe web. I think we don`t realise how lucky we actually are.
I mean you could decide `now` to build a Mig and virtually have it done in 1-3 days if you work at it. Persevere there pal you will enjoy it when it`s finished.
EATHIS is offline Find More Posts by EATHIS
Old Apr 21, 2011, 12:15 PM
rhysduk is offline
Joined Feb 2007
Thanks Eathis.. You sure do have it easier out there! Always fancied the idea of emigrating to Oz or SA, you never know!
Ok so.. I used ACrobat Pro 9 to scale the plans up to 116% and tile them. (I've attached the pdf for sheet 3 that i did this way).
BUT, when I print them im missing about 0.25inch or less from the edge. EG; take a look at the last sheet in the pdf, I'm missing the Y completely from the word AWAY.
I've tried bordless printing, nothing.
Any idea's guys?
Old Apr 21, 2011, 01:26 PM
Joined Oct 2006
WoW rd!!
So much happening!
Remember....I would prefer 3mm for the fuzz, tailfeathers and ailerons....its a slopie you building, not powered plane. ....but if you have a great slope, 4mm is cool!
The black 2mm is ok!....just makes it harder to see your construction lines...but once complete....black does look awesome with some white for depth!!
I'm starting to get excited for you!!
PFD????....again....sorry I cant help you there other than print you a copy and POST it to you!!
Keep them pics comming!!
Rigwell, hope you dont mind me posting some pics of your Very Pretty Mig!!??
Old Apr 22, 2011, 06:21 AM
EATHIS is offline
EATHIS's Avatar
Joined Sep 2009
Mig plans
RD,
I don`t know if this will help but take it anyway.
Old Apr 22, 2011, 06:43 AM
rhysduk is offline
Joined Feb 2007
Thanks Eathis. But I already had that, it's what I used to scale and tile page 3 in my attempt above.
On the verge of giving up
Build Log first scratch-build! :D ClippedWings78 Foamies (Scratchbuilt) 7 Nov 01, 2010 07:45 PM
Build Log MiG-15 in 1/10th scale for PSS: A Scratch-Build John Rood Slope 4 Sep 17, 2010 08:41 PM
