Old Mar 18, 2011, 05:26 AM
Flying Beagle is offline
Find More Posts by Flying Beagle
...missing the PE Slope Rebels
Flying Beagle's Avatar
United States, MI, Manchester
Joined May 2004
as an example of battery weight "refinement"
instead of adding an ounce of lead into the nose of a MIG,
HydriMax Ultra 4.8V NiMH 2000mAh AA Receiver Flat Battery Pack
Weight: 122g (4.3oz)
HydriMax Ultra NiMH 6V 2000mAh Flat Receiver Battery Pack
Weight: 152g (5.4oz)
Hobbico HydriMax NiMH 4.8V 3600mAh Sub-C Receiver Pack
Weight: 273g (9.6oz)
Flying Beagle is offline Find More Posts by Flying Beagle
Old Mar 18, 2011, 05:34 AM
Drusky is offline
Find More Posts by Drusky
just a rumour
Drusky's Avatar
South Africa, EC, Port Elizabeth
Joined Jun 2006
Makro has packs of 4 NimH "2700mah" for R179 odd. The Energizers "+-2000mah" were the same price. I like FB's idea of adding energy instead of lead for nose weight... to a point of course.
Drusky is offline Find More Posts by Drusky
Old Mar 18, 2011, 05:41 AM
Fuzzy B is offline
Find More Posts by Fuzzy B
Fuzzy B's Avatar
Port Elizabeth, South Africa
Joined May 2009
Originally Posted by Flying Beagle View Post
obviously.
but why not replace some useless lead weight, which has absolutely no value,
with a 5 cell pack, which provides more servo power,
or a larger cell size which provides longer time between charges ???
thus my question
Sean
I will just install a std 4cell pre-built pack, thanks
Jim
No need to solder on to the batteries, just get a plastic battery holder at Builders w/house and solder your wires on to the terminals. I used 4 AA 2200mAh batteries (I think!) which cost around R180 including a charger! Gave me ample flight time
Fuzzy B is offline Find More Posts by Fuzzy B
Old Mar 18, 2011, 06:06 AM
DudleyLeRoux is offline
Find More Posts by DudleyLeRoux
scratch build everything
DudleyLeRoux's Avatar
South Africa, KwaZulu-Natal, Botha's Hill
Joined Aug 2009
Originally Posted by Fuzzy B View Post
Jim
No way i would trust those holders, high-G turns will just push those springs down and possibly pop a battery out.
DudleyLeRoux is offline Find More Posts by DudleyLeRoux
Old Mar 18, 2011, 07:13 AM
aimrah2000 is offline
Find More Posts by aimrah2000
What goes up must come down
aimrah2000's Avatar
Joined Aug 2009
I feel the same about the battery holders. Donít trust them fully.
If you are going to solder tags or wire onto the battery just remember to use a large solder tip with high heat for a short time. Too much heat for a too long time will damage the batteries seal and reduce the capacity/output or damage the battery completely.
Here is another tip for soldering batteries: First clean the battery contacts with clean fine sanding paper and then use some kind of soldering past on the contacts. Tin the contacts first, then only solder the tags/ wire as described above
Use it donít use it
aimrah2000 is offline Find More Posts by aimrah2000
Old Mar 18, 2011, 08:27 AM
Sean Oelofse is offline
Find More Posts by Sean Oelofse
.....till the wind drops.
Sean Oelofse's Avatar
Joined Oct 2006
Yes Dudley,
High heat, quick on..quick off!
Sean Oelofse is offline Find More Posts by Sean Oelofse
Old Mar 18, 2011, 08:35 AM
Joined Oct 2006
Jim
Fuzzy B,
I did this for years!!...never had a problem!!...just duck the cells with tape to keep them in place for those ""high G's"".....but like any aspect of this wonderfull hobby, preventative maintance will keep you safe!!
FB,
I like your thinking!!!....Those larger capacity packs would be my first option!!
Old Mar 18, 2011, 09:24 AM
Fuzzy B is offline
Fuzzy B's Avatar
Joined May 2009
We are talking about a Correx Mig here! Just put insulation tape around to keep the batteries in
Old Mar 18, 2011, 01:03 PM
Joined Oct 2006
Exactly!!
Howeeever.....
Safety first!!.....of the public... an elderly couple driving along enjoying the view at Maitlands, on thier Sunday drive!
Enough of that!!
Relax and enjoy the weekend,
See you in a while!
May the wind blow in your favour!
Old Mar 18, 2011, 01:39 PM
aimrah2000's Avatar
Joined Aug 2009
Enjoy your break in Plett boet!!!
Old Mar 19, 2011, 02:50 PM
rhysduk is offline
Find More Posts by rhysduk
Rhys - Forever Learning
United Kingdom, Wales, Nelson
Joined Feb 2007
Having some problems printing this out with Acrobat.
Can anyone help please?
When i print it out it is not as shown on screen. I have a border around the edge where it should be flush to edge (borderless). Page SCaling is set to NONE and I have unticked AUTO ROTATE AND CENTER.
What am i missing?
rhysduk is offline Find More Posts by rhysduk
Old Mar 19, 2011, 07:02 PM
simon16 is offline
Find More Posts by simon16
Born again modeller
simon16's Avatar
United Kingdom, England, Durham
Joined Mar 2009
Borders
That's exactly what I got, but the dimensions are correct.
There are very few printers that can print right up to the edge.
I found that the over lap is about 1/4. I found the two that run together that have the 6 inch ruler on them, line them up with a straight edge, obviously with the inch markings on and build your sheets from there.
It's just like "Dot to Dot" then and join the lines up.
If you use really cheap A4 paper, you can see through to the lines below and just join them up. Even easier with all those "Flute" lines all over the place for reference.
I selotape all the seams back and front, total 15 minutes work.
Regards
Simon
simon16 is offline Find More Posts by simon16
Old Mar 19, 2011, 07:08 PM
rhysduk is offline
Joined Feb 2007
Thanks Simon.
My printer does do bordless printing, but when I try bordless printing with normal A4 paper it gives me a message about smudging on the ends of the paper and other things... I'll go print out the other 2 sheets of plans now and see if the dimensions are ok.
Do you cut the edges with the borders? I was thinking of using a metal ruler and cutting these borders off so they match up as perfectly and then selotaping them.
Old Mar 19, 2011, 10:14 PM
Mig Man is offline
Find More Posts by Mig Man
David Drowns
Mig Man's Avatar
Southern California
Joined Nov 2010
I believe the borders are suppose to be there. Use scissors to cut up to the lines to get a perfect fit. it also allows a little overlap on the underside to keep the template stiff.
Mig Man is offline Find More Posts by Mig Man
Old Mar 20, 2011, 01:12 PM
simon16 is offline
Born again modeller
simon16's Avatar
Joined Mar 2009
Rhys,
As Mig Man said, I leave them on but where you have a line to line up with the next sheet, I cut in a little at the line only. I leave the rest of the border alone so I have plenty of meat around it to tape up.
Simon
Build Log first scratch-build! :D ClippedWings78 Foamies (Scratchbuilt) 7 Nov 01, 2010 07:45 PM
Build Log MiG-15 in 1/10th scale for PSS: A Scratch-Build John Rood Slope 4 Sep 17, 2010 08:41 PM
