Old Mar 02, 2011, 02:12 PM
EATHIS is offline
Find More Posts by EATHIS
EATHIS's Avatar
South Africa, EC, Port Elizabeth
Joined Sep 2009
Hi Fuzzyb,
Flipping cool colours, should look really good in thr air.
EATHIS is offline Find More Posts by EATHIS
Old Mar 02, 2011, 10:49 PM
juan_camilo is offline
Find More Posts by juan_camilo
Joined Aug 2010
hi sean,
http://static.rcgroups.net/forums/at...g?d=1290176324
to this model, we did this procedure, or not? as is better? recommend that for aesthetic or performance?
thanks
Originally Posted by Sean Oelofse View Post
Today I made the canopy, mounted the elevator servo and closed up the back, top and bottom. The wing is now complete with two HXT900 servos.
Juan,
To mark the cut-outs to make the fuzz fit the wing, lay the fuzz on the wing. Then mark out at former F2. Cut this out about 10mm into the wing. Fit the wing and now mark out at F5. Cut this out....your wing should fit.....if not trim a little more.
Refer the pics.
juan_camilo is offline Find More Posts by juan_camilo
Old Mar 02, 2011, 11:26 PM
daristiz is online now
Find More Posts by daristiz
Joined Feb 2011
Originally Posted by juan_camilo View Post
saludos,,, que pena repsodner tan tarde, pero estos ultimos dias he estado muy ocupado... la construccion la inicio la otra semana.. por que hasta esta semana no quedo libre,,,
con respecto al plywood,, aca muchos le llaman asi.. pero entonces nos entendemos entre nosotros.. el plywood es simplemente madera contrachapada,, o tambien llamado triplex..
el correx,, es plastico corrugado,, o conocido en algunos lugares como coroplast, en home center venden blanco, negro y gris de 4mm y 2mm, pliego o medio pliego.
hasta pronto
Hola Juan, gracias por contestar. Te pregunto, que material es el del wingspar? dice yardstick o lath.... con que lo estas haciendo vos?
Otra pregunta, vos ya empezaste a armar el tuyo?no te queda facil grabar el procedimiento ?
y lo vas a hacer con motor eléctrico? cuando lo termines me compartis que electronica vas a usar? ( motor, esc, servosetc)
daristiz is online now Find More Posts by daristiz
Last edited by daristiz; Mar 02, 2011 at 11:34 PM. Reason: a mistake in the type of motor
Old Mar 02, 2011, 11:32 PM
Joined Feb 2011
Juan,
Refer the pics.
sean, great job, what a shame that I found this Thread so late, because the video of you building that plane would have been great for us newbies .
Problably next weekend I´ll cut mi pieces ( with a laser cutter ) and hope to start trying to assemble
Old Mar 03, 2011, 05:47 AM
Sean Oelofse is offline
Find More Posts by Sean Oelofse
.....till the wind drops.
Sean Oelofse's Avatar
Port Elizabeth, South Africa
Joined Oct 2006
Originally Posted by EATHIS View Post
Hi Sean,
Your colours look superb. As you seem to get the eye-catching colours and patterns. You also trying slightly different c olur schemes. Looks REALY cool.
Sorry, but its Bretons....He must still color his Mig-7.....as must I...
Can you post the link to that aircraft designs site again so I can get some ideas.
Sean Oelofse is offline Find More Posts by Sean Oelofse
Old Mar 03, 2011, 07:34 AM
johannlochner is offline
Find More Posts by johannlochner
Stirring the pot
johannlochner's Avatar
Port Elizabeth South Africa
Joined Jun 2008
Yeah Sean!
Us correx newbies would like a video!!!
Bakkie will do the Go Pro footage and FB the voice over.
Heheheh...
johannlochner is offline Find More Posts by johannlochner
Old Mar 03, 2011, 10:35 AM
Joined Aug 2010
hola, yo tenia la misma duda,, sean me dijo:
A Yardstick is a piece of wood 1 yard long by 1 inch by about 3 or 4mm thick.
Un Yardstick es un pedazo de madera de 1 yarda(0,9144 metros) de largo por 1 pulgada(2,54 centimetros) por unos 3 o 4 milimetros de espesor.
no especifica que madera.. pero supongo que debe ser madera dura,, es el alma del ala...
probablemente en estos dias inicie la construcion,, pero sera un planeador,, no llevara motor.. vuelo en ladera 100%,,,
hasta pronto
Old Mar 03, 2011, 10:59 AM
EATHIS is offline
EATHIS's Avatar
Joined Sep 2009
http://www.bandegraphix.com/
Hi Sean,
Here is the graphics site for ideas.
Old Mar 03, 2011, 01:11 PM
Fuzzy B is offline
Find More Posts by Fuzzy B
Fuzzy B's Avatar
Joined May 2009
Sean, any chance you might make a few more of those spinners for us?. Name your price!
Fuzzy B is offline Find More Posts by Fuzzy B
Old Mar 03, 2011, 01:13 PM
Flying Beagle is online now
Find More Posts by Flying Beagle
...missing the PE Slope Rebels
Flying Beagle's Avatar
United States, MI, Manchester
Joined May 2004
+ 1
Flying Beagle is online now Find More Posts by Flying Beagle
Old Mar 03, 2011, 01:46 PM
Blackrat is offline
Find More Posts by Blackrat
Registered Loon
Blackrat's Avatar
South Africa, WC, Knysna
Joined May 2006
+9 65mm diameter
Blackrat is offline Find More Posts by Blackrat
Old Mar 03, 2011, 03:46 PM
Joined Oct 2006
Can do!
R50 to cover glass/resin/buckshot?
Old Mar 04, 2011, 12:04 AM
Fuzzy B is offline
Fuzzy B's Avatar
Joined May 2009
Yes thanks I'll have one !
Old Mar 04, 2011, 06:14 AM
Joined May 2004
R50
+ 1, plus another one
spare
Build Log first scratch-build! :D ClippedWings78 Foamies (Scratchbuilt) 7 Nov 01, 2010 08:45 PM
Build Log MiG-15 in 1/10th scale for PSS: A Scratch-Build John Rood Slope 4 Sep 17, 2010 09:41 PM
