Old Apr 05, 2012, 11:27 PM
pistnbroke is offline
Find More Posts by pistnbroke
absolutely maybe
pistnbroke's Avatar
Australia, WA, Currambine
Joined Apr 2011
Hi Miggers,
I am getting a little frustrated when building the wing. I don't know why it is going so wrong. I cut everything and mark everything as per the plan but when I fold the wing on my jig, the TE does not meet up like the ones in your construction pics, it is way off!
I will post some pics of a half wing soon, maybe you can tell me where I am getting it wrong.
Thanks for the info Sean, I have started the original sized Mig but am not sure whether to make it electric or for the slopes.
Regards
Ian Pics to follow a little later.
pistnbroke is offline Find More Posts by pistnbroke
Old Apr 06, 2012, 12:31 AM
Flying Beagle is offline
Find More Posts by Flying Beagle
...missing the PE Slope Rebels
Flying Beagle's Avatar
United States, MI, Manchester
Joined May 2004
Ian, we cut out the top half of the wing with extra material. After the spar is glued to the bottom wing, fold the top wing over using the jig. With the ailerons hanging over the edge of a table, reach underneath the wing and mark the inside of the top wing using the outline of the bottom wing as a guide. Then cut the top wing to those marks. hope that makes sense
Flying Beagle is offline Find More Posts by Flying Beagle
Old Apr 06, 2012, 03:21 AM
Mewgun is offline
Find More Posts by Mewgun
Mewgun's Avatar
Russian Federation
Joined Sep 2008
Sean, thanks for the video!
This MegaCool! It provide inspiration!
After reviewing the video have any questions.
1. What are the settings used by the transmitter? What was mixed with what?
2. The sound of the motor ... Such a nice, not shrill, soft ... What is the motor?
3. Based on the video, the plane could fly slowly enough. And this exactly is not stalling. This is due to the design or with additional electronics?
One more question.
Drawing on the angle of the elevator is 1 degree this is true?
Mewgun is offline Find More Posts by Mewgun
Old Apr 06, 2012, 04:13 AM
absolutely maybe
pistnbroke's Avatar
Joined Apr 2011
Hi Flying Beagle,
Thank you for your quick reply to my wing building troubles, it makes perfect sense! I thought that maybe I was doing something wrong. When I get the right wing shape I can then make myself a template and get "perfect" wings each time.
Would I be right in assuming you have all experienced the same problem?
Thanks again!
Ian
Old Apr 06, 2012, 08:51 AM
ScienceGuy is offline
Find More Posts by ScienceGuy
United States, NY, Marion
Joined Sep 2001
Originally Posted by pistnbroke View Post
Hi Flying Beagle,
Thank you for your quick reply to my wing building troubles, it makes perfect sense! I thought that maybe I was doing something wrong. When I get the wright wing shape I can then make myself a template and get "perfect" wings each time.
Thanks again!
Ian
Jim is an excellent resource guy for these due to the time he has put into the other designs. We're putting one together right now ....well Jim is doing 99% of the niggly stuff and there are many places where your mind would be blown if you hadn't seen one done before or been helped along.
Sean says to cut the bottom of the wing to plan and oversize the perimeter of the top one by ~ 1 cm or so. Also over size the aileron. As Jim said once the spar is glued to the bottom skin and the crease is rolled into the wing leading edge but before contact cement is applied to to close the wing,,,,,, you should fold the top over to shape and trace a line on it from below to match it to the bottom surface. Unfold and cut the top to nicely traced outline. Fit the aileron the same way. Glue aileron......then top wing.
Sean will step in if that's wrong ....right ?????
ScienceGuy is offline Find More Posts by ScienceGuy
Old Apr 06, 2012, 10:51 AM
johannlochner is offline
Find More Posts by johannlochner
Stirring the pot
johannlochner's Avatar
Port Elizabeth South Africa
Joined Jun 2008
Huh, You
What's going on here?
Another Mig build party?
johannlochner is offline Find More Posts by johannlochner
Old Apr 06, 2012, 12:10 PM
Joined May 2004
was last night, just two yanks and some Correx
Old Apr 06, 2012, 03:37 PM
Bakkie is offline
Find More Posts by Bakkie
I think I'm Mode 2
Bakkie's Avatar
South Africa, Eastern Cape, Port Elizabeth
Joined Sep 2010
kinky
Bakkie is offline Find More Posts by Bakkie
Old Apr 07, 2012, 02:05 AM
Sean Oelofse is offline
Find More Posts by Sean Oelofse
.....till the wind drops.
Sean Oelofse's Avatar
Port Elizabeth, South Africa
Joined Oct 2006
Yes!....Very Kinky!! .......and he has only been in the country a few days!
pistnbroke, all the above is correct!....we do all get the same result when folding a wing. Remember, when you score the fold line, if you go out by half a mm on one end, it can throw the TE out by 10mm. So do as Jim says, leave extra on to trim off later.
Sean Oelofse is offline Find More Posts by Sean Oelofse
Old Apr 07, 2012, 02:12 AM
Joined Oct 2006
No mixing Mewgun. If you want you can, but I have no mixing.
It is an Axi 28??....I will go look
No additional electronics. Just good plane.
One more question.
I do not measure degree! Just make straight/flat.....0 degree.
Old Apr 08, 2012, 01:22 AM
Mewgun is offline
Mewgun's Avatar
Russian Federation
Joined Sep 2008
Sean, hello!
If possible, show pictures engine mount and its mounting in the fuselage.
Interested in a way to strengthen the attachment.
Thank you.
Old Apr 08, 2012, 04:48 AM
Joined Oct 2006
I will go look for photo's of the engine mount and post them.
Old Apr 10, 2012, 11:22 PM
SCREWYFITS is offline
Find More Posts by SCREWYFITS
As SCREWY as I wanna be!!!
SCREWYFITS's Avatar
United States, CA, Livermore
Joined Feb 2011
Hello, my name is Dirk and I'm a Mig-7 addict...
Hey all, I'm loving this thread, took me apx a week and a half to get from the beginning to here, that being said you all have me HOOKED!!!
I have 4 in the works, I'll try and post some pics soon, I have quite a few sheets of corro on order to build many more, also try to share photos here!!!
Thanx, Dirk
SCREWYFITS is offline Find More Posts by SCREWYFITS
Old Apr 11, 2012, 12:42 AM
Joined Oct 2006
Welcome!
Great to have you in our classroom Dirk!!
You have done well to catch up in a week and a half!
This thread works best when you "show and tell"!
Pull up a chair and make yourself comfortable!!
Old Apr 11, 2012, 01:39 PM
SCREWYFITS's Avatar
Joined Feb 2011
Hey Sean, when you do your graphics do you freehand cut them or do you use a plotter?
funny story; on my third fuse I realized I could put the cuts (flutes) on the inside and thought I was gonna have something really kool to share, then realized everyone was doing that already... DOOOAH!!!
I'll keep trying to share something really kool, don't know if it'll happen but I'll try...
Build Log first scratch-build! :D ClippedWings78 Foamies (Scratchbuilt) 7 Nov 01, 2010 07:45 PM
Build Log MiG-15 in 1/10th scale for PSS: A Scratch-Build John Rood Slope 4 Sep 17, 2010 08:41 PM
