Old Mar 23, 2012, 12:31 AM
Sean Oelofse is offline
Find More Posts by Sean Oelofse
.....till the wind drops.
Sean Oelofse's Avatar
Port Elizabeth, South Africa
Joined Oct 2006
You see rhysduk, you got plenty GOOD advice comming FOR FREE!!
Rocky is on the button!!.....a lazy elevator means too much nose weight!
Take some out to get the cg 10mm back and throw again....
Bare with as rhysduk, we'll get you flying this machine soon!
After watching the clip a few times, I think taking out nose weight will improve the performance plenty!! I can see it stalling from pulling on the elevator. I also think the wind was a tad light. But next time for sure!!......she will fly!!
Sean Oelofse is offline Find More Posts by Sean Oelofse
Old Mar 23, 2012, 02:34 PM
rhysduk is offline
Find More Posts by rhysduk
Rhys - Forever Learning
United Kingdom, Wales, Nelson
Joined Feb 2007
Cheers guys, there's hope yet then!
In order for me to build a new wing, I'd have to destroy the current wing (1. I have no spar spar material unless made from 4mm correx) but wouldn't this mean i'd have to make a new fuselage as the wing profile would be slightly different resulting in a new wing seat on the fuselage being required?
I don't think there's much wind planned for this weekend so testing will have to wait. boohoo
Thanks for all the help!
rhysduk is offline Find More Posts by rhysduk
Old Mar 23, 2012, 04:16 PM
JMSR is offline
Find More Posts by JMSR
JMSR's Avatar
Dunedin, New Zealand
Joined Dec 2010
I had to destroy my 1st wing to get the spar out. It turned out to be a good move as it enabled me to see test for weak points by twisting and pulling etc, and how strong the glue was, which I've always wanted to test. It gave me much more confidence in my build strength, allowed me to see errors to be corrected, and showed me what I could get away with in flight.
You could just make new doubler sections for the wing profile, like the ones you installed a few pages back. Cut out the old ones just above the seam. For the new doubler section, make the new inside layer (vertical flutes) slightly taller than the flush outside layer (horizontal flutes) to have a good spliced join. Don't go nuts with the hot glue though.
For the wing:
*Remember to get the flutes perpendicular to the fold line when cutting the wings out.
*Score well, and use a jig (check out argo-2s post #1480 for an easy fix).
*Double/triple/quadruple check the aileron set up and the rear centre tabs and layers (also pays to do this before cutting).
Good luck on your mission sir.
JMSR is offline Find More Posts by JMSR
Old Mar 24, 2012, 01:29 AM
Joined Oct 2006
Yes!
Use what you got...... a total rebuild can come later.
Old Mar 24, 2012, 05:17 PM
Bakkie is offline
Find More Posts by Bakkie
I think I'm Mode 2
Bakkie's Avatar
South Africa, Eastern Cape, Port Elizabeth
Joined Sep 2010
3meter Correx Mig
BIG MIG (4 min 15 sec)
Bakkie is offline Find More Posts by Bakkie
Old Mar 25, 2012, 03:18 AM
Joined Oct 2006
Awesome clip Bakkie!
Amazing how cool it looks flying in the first person with the other Migs buzzing around!
FYI, those that were'nt at the event, this footage was from the day before the start. The conditions started GOOD and just got BETTER!
Old Mar 26, 2012, 02:48 PM
JMSR is offline
JMSR's Avatar
Joined Dec 2010
Amazing vid! By the looks of it the mig7 is a popular choice. I'm still surprised it hasn't caught on big time outside of SA, electric or slope. Sure there's the odd group and a couple of randoms, but not the popularity this amazingly diverse plane deserves. I guess the rep SPADs have of being heavy, ugly, hard to glue and tricky to set up is a hard one to shake. One guy at the field thought it was factory made until he was standing right next to it!
Old Mar 26, 2012, 02:57 PM
Joined Oct 2006
Yes JMSR!
The same here!
I have built with balsa,.....plenty, but find corro the best for our slope flying antics!
People here also frown on corro cause its "cheap"
I think above all though.......it's not as easy (in the beginning), to build (understand), corro! ........... IMHO!
Old Mar 26, 2012, 03:09 PM
johannlochner is offline
Find More Posts by johannlochner
Stirring the pot
johannlochner's Avatar
Port Elizabeth South Africa
Joined Jun 2008
Originally Posted by Sean Oelofse View Post
Yes JMSR!
The same here!
Who could possibly think that?
johannlochner is offline Find More Posts by johannlochner
Old Mar 27, 2012, 10:40 PM
Bakkie is offline
I think I'm Mode 2
Bakkie's Avatar
Joined Sep 2010
Mig = fun
Sean and Bakkie Mig7 Slope Fun (7 min 20 sec)
Old Mar 27, 2012, 10:56 PM
lemuel is offline
Find More Posts by lemuel
Australia, QLD, Brighton
Joined Sep 2006
great fun. I had a smile from ear to ear just watching that. Thanks!
lemuel is offline Find More Posts by lemuel
Old Mar 28, 2012, 06:43 AM
Joined Oct 2006
Yes!
Was good fun!
Old Mar 28, 2012, 08:07 AM
rhysduk is offline
Joined Feb 2007
After doing some digging (read as tidying) I found 4 wings I had cut out when doing the originals... And IIRC the flutes are the correct way (perpendicular to the fold line)....
Old Mar 28, 2012, 02:26 PM
JMSR is offline
JMSR's Avatar
Joined Dec 2010
Major bonus! I wish I found ready made stuff lying around my house.
Old Mar 29, 2012, 11:16 AM
Mewgun is offline
Find More Posts by Mewgun
Mewgun's Avatar
Russian Federation
Joined Sep 2008
Hello! I ask to forgive for my English!
I write by means of Google Translator. With its help read almost all subject. I am delighted! Simply there are no words!
You build tremendous planes!
Tell, strengthenings are made of what material? Plywood? What thickness?
Thanks!
Mewgun is offline Find More Posts by Mewgun
Build Log first scratch-build! :D ClippedWings78 Foamies (Scratchbuilt) 7 Nov 01, 2010 07:45 PM
Build Log MiG-15 in 1/10th scale for PSS: A Scratch-Build John Rood Slope 4 Sep 17, 2010 08:41 PM
