Old Mar 06, 2012, 01:38 PM
JMSR's Avatar
Dunedin, New Zealand
Joined Dec 2010
Yeah, mine is 3mm for that piece. Had to slice inside each flute associated with the radius, like the main fuselage, to get it to work. No probs, smooth curves, still strong.
JMSR is offline Find More Posts by JMSR
Old Mar 07, 2012, 09:30 AM
Rhys - Forever Learning
Rhondda. South Wales, UK
Joined Feb 2007
Does anyone have a picture of the underside front fuselage please?
I would like to see how you all mount/attach the Rx and battery and keep it in place.
rhysduk is offline Find More Posts by rhysduk
Old Mar 07, 2012, 10:24 AM
What goes up must come down
aimrah2000's Avatar
South Africa, EC, Port Elizabeth
Joined Aug 2009
Swap meet
Hey Guys:
PERF is going to have another SWAP MEET
Date: 14 March 2012
Place: Moregrove Primary School Hall (Same place as last time)
Time: 7:00PM till late
We also are going to have an auction and refreshment will be on sale too.
Hope to see you all there.
Please spread the word..
Markus
aimrah2000 is offline Find More Posts by aimrah2000
Old Mar 07, 2012, 01:14 PM
.....till the wind drops.
Sean Oelofse's Avatar
Port Elizabeth, South Africa
Joined Oct 2006
This is how I secure my receiver......its got some give for those forced arrivals!!
Its the foam used to insulate piping.
Glue with contact adhesive.
Sean Oelofse is offline Find More Posts by Sean Oelofse
Old Mar 07, 2012, 01:17 PM
Joined Feb 2007
Thanks Sean
PS: Why do you ZOMBIE written on the Receiver?
Old Mar 07, 2012, 01:21 PM
Joined Oct 2006
Thats the receiver I TRUST to fly my large scale Crop Duster with!
..well I used to!.................not anymore!........since I now fly COMBAT with it!
I know.......STUPID of me!!
Old Mar 07, 2012, 01:39 PM
JMSR's Avatar
Joined Dec 2010
Here's my insides. Just a piece of scrap 5mm balsa I had. On the top side there are a couple of little gussets at each former but nothing full on. I just used velcro to hold everything in place, plus an elastic loop for the battery.
Sean, that Ag Wagon is a mean piece of kit, love the camo. I've got an E-star Ag Tractor kit sitting under my desk waiting it's turn. Always loved crop dusters. The performance coupled with looks only a mother could love make them the greatest underdogs.
Old Mar 08, 2012, 11:44 PM
Joined Oct 2006
Great stuff JMSR!!
Your contruction is spot on!
How do you find the CA glueing on the corro?......I tried it a few times with little success!......maybe it's just the type corro we have here?!
Thanx for the words on the AgWagon. Took a year to scratch from a .40 size plan.
Old Mar 09, 2012, 03:16 AM
Maiden>Confident>Cocky>Crash!
argo-2's Avatar
New Zealand
Joined Feb 2010
Originally Posted by Sean Oelofse View Post
Great stuff JMSR!!
Hi Sean I hope JMSR does not mind me answering, but I beleive he uses Loctite 406 CA with 770 primer. The trick is the 770 as it prepares the plastic chemically with special magic . Here's some info:
LOCTITE 770 100ml
LOCTITE 770 is used to make polyolefin and other low energy surfaces suitable for bonding with Loctite cyanoacrylate adhesives. On such treated surfaces the cured performance of Loctite cyanoacrylate adhesives is generally similar to that
described in the TDS for the relevant adhesive. It is only recommended for difficult to bond substrates which include polyethylene, polypropylene, polytetrafluoroethylene (PTFE) and thermoplastic rubber materials.
By the way my MIG building has ground to a halt for the simple reason I can't get away for even an hour during a weekday to get more material Bruddy frustrating it is!
Cheers.
argo-2 is offline Find More Posts by argo-2
Old Mar 09, 2012, 03:55 AM
Joined Oct 2006
Ok!
Thanks for the info argo-2!
I will ask around and see whether the 770 is available locally and give it another try!
Old Mar 09, 2012, 04:42 AM
JMSR's Avatar
Joined Dec 2010
The Loctite is the go all right. I've made a couple of correx planes before this one using just 406 and it works well enough on its own but no where near as good as with the 770. It also cuts down the bloom effect. You do have to be accurate though because the correx will rip before the glue that's for sure!
Old Mar 09, 2012, 06:06 AM
Joined Feb 2007
What CG are you guys using?
Old Mar 09, 2012, 09:28 AM
Joined Oct 2006
Start with as per the drawing, shown on the fuzz. I have moved it back about 8mm to be able to throw the plane around nicely. But the position of the wing is important. But again, go heavy in the nose then lose some as you go.
Saw your comment about a manual during the build, sorry, but not gona have time for that,. ..........unless someone comes along just to scribe and not build!
Old Mar 09, 2012, 11:58 AM
Joined Feb 2007
Thanks Sean, I stupidly left it off the fuselage
Has anyone measured it from the LE of the inside of the wing nearest the Fuselage?
Just about to weigh her up in a bit (battery inc)....
Old Mar 09, 2012, 02:21 PM
JMSR's Avatar
Joined Dec 2010
I move my battery around for different results but If I remember rightly it's about the same as what Sean is saying. CG at the rear edge of the main spar for acrobatics and dog fighting. CG at the front edge of the main spar joiner for low passes and smooth cruising.
Measurements from the inside face of the LE fuselage slot are 76mm to 86mm. From the tip of the LE where it meets the fuselage it's 81mm to 91mm.
Build Log first scratch-build! :D ClippedWings78 Foamies (Scratchbuilt) 7 Nov 01, 2010 07:45 PM
Build Log MiG-15 in 1/10th scale for PSS: A Scratch-Build John Rood Slope 4 Sep 17, 2010 08:41 PM
