Old Nov 21, 2010, 04:26 PM
beginner4life is offline
Find More Posts by beginner4life
beginner4life's Avatar
United States, MD, Ellicott City
Joined Mar 2008
I appreciate the confidence and support jasmine
Flew an msr for 4 packs today and felt totally comfortable with it. I know the Blade 400 is on another level but still. :I have about 5+ hours of simtime on CP helis as well.
As for the Blade 400 bible, my girlfriends father who is the one getting me into helis sent me a copy today
beginner4life is offline Find More Posts by beginner4life
Old Nov 21, 2010, 05:30 PM
tedwearsahat is offline
Find More Posts by tedwearsahat
Can't-Get-Right
tedwearsahat's Avatar
Souf' East UK
Joined Aug 2008
I'm sure flying 3D planes you'll get along fine if you take your time.
Ensure your setup is good and then go through the Radds steps. Once you are happy with that establish the muscle memory for a good tail in hover and advance from there.
Good luck and enjoy your new rotary winged bird.
tedwearsahat is offline Find More Posts by tedwearsahat
Old Nov 21, 2010, 05:40 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
Keepin it real, bro
You'll probably do ok - the simulator is super helpful. I don't think time has anything to do with it, but if you can hover and fly around a bit on the sim, you should be fine with the real ones.
jasmine2501 is offline Find More Posts by jasmine2501
Old Nov 21, 2010, 05:44 PM
Joined Mar 2008
Yeah i can do some okay 3d on RF G5.5 but i still get out of control sometimes but hovering and flying around is fine on a 3d heli
Old Nov 21, 2010, 07:39 PM
bdp3822 is offline
Find More Posts by bdp3822
bdp3822's Avatar
Honolulu, HI
Joined Jun 2007
Hi All!!
Anyone flying the B400 with a Scorpion 2221-6 or any other 4400kv motor? Just wondering which pinion would work best.
Bryon
bdp3822 is offline Find More Posts by bdp3822
Old Nov 21, 2010, 10:00 PM
Stenz28 is offline
Find More Posts by Stenz28
Utah
Joined Sep 2009
well according to darkhorse site: http://dhrc.rchomepage.com/calc.htm
at 100% RPM and 85% efficiency:
09 tooth = 2669
10 tooth = 2965
11 tooth = 3262
12 tooth = 3558
13 tooth = 3855
Ciao
Stenz28 is offline Find More Posts by Stenz28
Old Nov 21, 2010, 10:41 PM
bdp3822 is offline
bdp3822's Avatar
Honolulu, HI
Joined Jun 2007
09 tooth = 2669
10 tooth = 2965
11 tooth = 3262
12 tooth = 3558
13 tooth = 3855
Ciao
I wonder if 12T is too much? Thanks for the info!!
Old Nov 22, 2010, 03:38 AM
hedgeheli is offline
Find More Posts by hedgeheli
hedgeheli's Avatar
Bournemouth - UK
Joined Feb 2009
Tail mounted rudder servo
Anyone have any good solutions to this?
I was planning on just buying another rear servo mount EFLH 1458 and then cut down the current tail linkage pushrod. The reason I am hesitating is I dont think it would be very secure.
Anyone got good piccys or some advice.
Cheers
hedgeheli is offline Find More Posts by hedgeheli
Old Nov 22, 2010, 10:54 AM
dbennettya is offline
Find More Posts by dbennettya
Joined Apr 2009
I'm not sure what that would buy you other than a little COG change. You could use Align tail servo mounts if the boom is the same diameter on the B400. My T-Rex 250se uses two boom mounted servo clamps and it is real secure, but they are beefier than the rear B400 mount so I wouldn't try using two of those EFLH1458 mounts.
YMMV, Don
Cheers
dbennettya is offline Find More Posts by dbennettya
Old Nov 22, 2010, 11:01 AM
Rocket Programmer
Joined Jul 2007
It would reduce the play and wobble in the linkage significantly, but it would really throw off the balance. Also would require a fairly long servo cable.
Old Nov 22, 2010, 11:59 AM
FR4-Pilot is online now
Find More Posts by FR4-Pilot
That's Pretty Neat!
FR4-Pilot's Avatar
United States, IL, Lombard
Joined May 2009
It also allows you to tweak the tightness of the belt without having to re-do the pitchrod/tail setup (if you want to keep your tail centered in rate mode, servo at 90/neutral, etc.). Many pilots do this - especially if they've upgraded to a larger servo that won't fit in the stock location.
Can't comment on the ruggedness of the servo mounts though ...
-John
FR4-Pilot is online now Find More Posts by FR4-Pilot
Old Nov 22, 2010, 02:35 PM
hedgeheli's Avatar
Bournemouth - UK
Joined Feb 2009
Thanks for all the replies. I think I will try a few other ideas first then see if I can find the align mounts.
Old Nov 22, 2010, 03:09 PM
Can't-Get-Right
Souf' East UK
Joined Aug 2008
I use two plastic E-Flite mounts to boom mount a 30g tail servo with no noticeable issues with flex. At the same time I changed the stock tail control rod for a Furion tail control rod so I didn't have to mess with cutting the stock item down to size, it is a lot stiffer than stock.
Old Nov 22, 2010, 04:48 PM
killsdeer4fun is offline
Find More Posts by killsdeer4fun
With great pwer comes great 3D
killsdeer4fun's Avatar
Globe, USA, Clemson, SC
Joined Jun 2010
Did my first rolls today too. Does them decently well. Stock gyro at least makes it somewhat easier to fly the tail during loops and rolls.
killsdeer4fun is offline Find More Posts by killsdeer4fun
Old Nov 22, 2010, 06:57 PM
Mike_Then is offline
Find More Posts by Mike_Then
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
I can't seem to get rid of the slop in my Blade 400 head, and most of the parts are new. The o-rings in the head seem especially sloppy. Are there stiffer o-rings that can drop into the Blade 400 head? Better yet, is there a plug-n-play metal head that can be purchased for this heli? I was looking on Hobbypartz.com but I can't tell the difference between the $40 head and the $80 head.
Mike_Then is offline Find More Posts by Mike_Then
Latest blog entry: F-14 resurrection
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 04:51 PM
Yippee! Official Parkzone P-51 Owner's Thread Part 2 Ferocious Franki Parkflyers 15 Apr 02, 2014 11:22 AM
Cool The Official Blade 400 Thread - Questions - Support - all you need to know! blade strike Mini Helis 20639 Nov 08, 2010 09:41 AM
Discussion another Bible, creation, science thread Part 2) martin richards Life, The Universe, and Politics 131 Nov 07, 2010 01:00 AM
Discussion new AXE 400 official thread. raptorddd Micro Helis 0 Sep 08, 2008 03:29 AM
